73slammed Samba Member
Joined: May 11, 2009 Posts: 10 Location: firestone colorado
Posted: Sat Jul 18, 2009 7:01 pm Post subject: looking for around 120-160 hp |
i am building an autocross engine i am looking for 120-160 hp want to build a 1914 with forged crank rods pistons. light flywheel flowed heads, fuel injected, t28 turbo, megasquirt engine management.
do you guys think that ill put out hat im looking for with a berg trans
thanks |
The Noof Samba Member
Posted: Sat Jul 18, 2009 7:06 pm Post subject: |
Yes, you can.Just curious though:it appears you're willing to spend a fair bit of money.Why 1914?With all your doing/spending, a longer stroke will be an advantage. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15278 Location: Deep in the 405
Posted: Sat Jul 18, 2009 7:11 pm Post subject: |
Before you get into turbo do some price comparisons. You can build a 160 HP 2110cc with carbs and drive it on the street. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76761 Location: Sneaking up behind you
Posted: Sat Jul 18, 2009 7:15 pm Post subject: |
vwracerdave wrote: |
Before you get into turbo do some price comparisons. You can build a 160 HP 2110cc with carbs and drive it on the street. |
That's what i say.. .stroke it for torque and n/a will give instant response. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Jul 18, 2009 8:11 pm Post subject: |
i want the low end tq of the n/a and i want the boost to have really good lo end tq. what stroke will i need for a 2110 |
sturgeongeneral Samba Member
Joined: June 23, 2005 Posts: 2460 Location: Sacramento, California
Posted: Sat Jul 18, 2009 8:23 pm Post subject: |
82 stroke by 90.5 jugs. _________________ Street legal fiberglass rocket ship
2005 Lotus Elise supercharged
1974 Chevy Corvette
My fiberglass car collection!
In honor of bowtie56jw:Another victim of the nasty "C" Praying for ya Jeff!
My exwife said if I towed home one more bug she would leave me. You know, every once in a while I miss her |
krusher Samba Member
Joined: September 24, 2002 Posts: 7652 Location: europe
Posted: Sun Jul 19, 2009 1:39 am Post subject: |
73slammed wrote: |
I think if you start looking at what other autocross guys use you wont find made turbos, to much lag out of corners.
You could make your 120hp with a basic 1914 na.
A good auto cross engine combo is a thing unto its self , find some vw autocrossers and ask _________________ (06:31:07) RoachGhia: "i drink dick way too fast" |
Posted: Sun Jul 19, 2009 6:33 am Post subject: |
krusher wrote: |
73slammed wrote: |
A good auto cross engine combo is a thing unto its self , find some vw autocrossers and ask |
Agreed.Stroker for sure.Even a quick spool config will give way to the hard,fast pull of an NA 2110 or bigger engine in autocross. |
MinamiKotaro Samba Member
Joined: July 18, 2008 Posts: 1039 Location: Somewhere in TN
Posted: Sun Jul 19, 2009 8:16 am Post subject: |
I'm a 100% pro-turbo but I agree with others. For autocross, you'd be better served by a snappy, NA stroker. _________________ 1967 VW Beetle
2276cc
MegaSquirt-extra v3.57
Check out my ongoing story. |
Posted: Sun Jul 19, 2009 12:33 pm Post subject: |
i plan on useing a very small turbo if i use on so how bout a stroked 2110 with the small turbo running about 5psi so id have the na power then the added power from the turbo. if no one thinks its a good idea ill just go for the 2110. and none of the autocrossers know about bugs im alone on this one |
Posted: Sun Jul 19, 2009 12:37 pm Post subject: |
Sounds like you need to do a lot of reading on turbo's and their theory before you start your project. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Sun Jul 19, 2009 12:51 pm Post subject: |
i know how turbos work and have tuned with turbos for a long time. just dont know if its worth the time to put one on a 1914 or a 2110. i already have the turbo and manifolds. i need max tq all the time at almost all ranges of rpm at speeds from 20-60 thats the only reason i would go turbo cause i can get the low end tq of the 1914 or 2110 and have the turbo be spooled up beyond 2000 rpms and hold lots of tq |
Posted: Mon Jul 20, 2009 12:21 am Post subject: |
What you need to be looking at is the autocross spec cams the companys have for NA vw engines, they are made for the TQ spread to want. _________________ (06:31:07) RoachGhia: "i drink dick way too fast" |
Unkl Ian Samba Member
Joined: September 11, 2008 Posts: 288 Location: Near Toronto
Posted: Mon Jul 20, 2009 8:01 am Post subject: Re: looking for around 120-160 hp |
73slammed wrote: |
i am building an autocross engine... |
Do the rules dictate max displacement ? |
Posted: Fri Jul 24, 2009 1:05 am Post subject: |
im running in e mod class and can virtually do anything to my bug so engine the sky is the limit |
madmike Samba Member
Joined: July 11, 2005 Posts: 5291 Location: Atlanta,Michigan
Posted: Fri Jul 24, 2009 5:57 am Post subject: |
Torque Monster= 2332cc is 94x84,W120 cam,42x37.5 valved heads with 10 to 1 CR, 44 IDF's merged 1 5/8 header, and a good dist. like the Bosch 010 ,"Then go spank the ricers" _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
