Cliff@BrownBags Samba Member
Joined: June 14, 2007 Posts: 649 Location: glen burnie maryland
Posted: Thu May 08, 2008 7:37 pm Post subject: HID install, how to. step by step. |
i recieved a bunch of emails about how you put these kits in, and i figured i would make it easier on me and you if i showed this . this shows how easy it is........
i took out the headlight. the plug for the headlight now plugs into the ballast in the kit. the ballast has a new plug from it that goes to the light bulb. i was able to even fit the ballast behind the light
then i just put the light back in. its tight but it fits.
by far one of the best things i ever did, and easiest lol. any questions at all feel free to post up, or pm me, or email me @ [email protected]
thanks guys
then you just turn them on
and here is a decent shot at them. these are the 12k that most people get.
Fattie I'd roll it
Joined: November 27, 2005 Posts: 5582 Location: louisiana
Posted: Thu May 08, 2008 7:47 pm Post subject: |
nice post..
BTW: your bug is clean _________________ Donate and help me get another aircooled dub to share with you guys www.paypal.me/WhosCare |
Posted: Thu May 08, 2008 7:59 pm Post subject: |
thanks man, i just waxed it lol. |
zoti Samba Member
Joined: December 26, 2007 Posts: 2060 Location: Plano, TX USA
Posted: Thu May 08, 2008 8:03 pm Post subject: |
Where did you buy it from? |
Posted: Tue Jan 06, 2009 12:46 pm Post subject: |
bump |
Hoodrat Samba Member
Joined: April 02, 2006 Posts: 111 Location: Louisiana
Posted: Tue Jan 06, 2009 2:16 pm Post subject: |
mmmm yess HIGH INTENSITY DISCHARGE DELIGHTFULNESS........heh heh
Da Rat
_________________ Run it Till it Pukes!!!!! |
westcoast-paul Samba Member
Joined: January 31, 2006 Posts: 822 Location: CanadaYaHoser
Posted: Tue Jan 06, 2009 4:02 pm Post subject: |
wow - $99 for the whole kit? _________________ - Paul |
chris&laura Samba Member
Joined: December 28, 2008 Posts: 27 Location: SACRAMENTO
Posted: Tue Jan 06, 2009 4:49 pm Post subject: |
I was wondering the same thing...... $99 bucks? |
fast Ed Samba Member
Joined: October 29, 2008 Posts: 164 Location: Caledon, Ontario Canada
Posted: Tue Jan 06, 2009 5:40 pm Post subject: |
Does a stock generator make enough juice for these, or is an upgrade needed on that beforehand?
cheers
Ed N. |
mack519 Samba Member
Posted: Tue Jan 06, 2009 6:01 pm Post subject: |
fast Ed Canuck wrote: |
cheers
Ed N. |
Wondering this too, I also have a fairly hefty sound system in my super. Do HIDs drain more or less power than normal headlights? _________________ 1973 super beetle |
Posted: Tue Jan 06, 2009 6:53 pm Post subject: |
i have a generator and i have had no problems with my HID's _________________ Run it Till it Pukes!!!!! |
Zach Thomas Samba Member
Joined: August 12, 2008 Posts: 929 Location: Lake Stevens, WA
Posted: Tue Jan 06, 2009 6:56 pm Post subject: |
Are these still being sold? Cause his ad isn't there.
But, those look NICE! |
MyLeftLugNut Samba Member
Posted: Tue Jan 06, 2009 7:46 pm Post subject: |
mack519 wrote: |
cheers
Ed N. |
Wondering this too, I also have a fairly hefty sound system in my super. Do HIDs drain more or less power than normal headlights? |
With HID's the power draw when they initially turn on is pretty big but not going to cause a problem. After they are "warmed up" the power draw is less than a 35w bulb. If you see a kit fired up you can see the "warming up" process. The lights will kick on and get brighter in the first few seconds. Kinda neat. Had a HHR with someretro-fitted Infiniti projectors and HID's on it. Amazing clarity at night. And if done right you ahve little to no glare. |
Mygfsbug Samba Member
Posted: Wed Jan 07, 2009 1:32 pm Post subject: |
I have a question. My classic Mustang has a headlight bulb and connector VERY similar to Beetles, would you think these would work on this application? If so, I know loads of people on my other forums would want these. |
Posted: Wed Jan 07, 2009 1:57 pm Post subject: |
all i need is the make , model, and year and i can look it up. i get them in all bulb types. its not limited to h4's. just let me know. thanks.
also keep in mind if it is a 'sealed' beam now you need 'non sealed' headlights that allow you to remove just the bulb not the entire light. i can get those too. |
Posted: Wed Jan 07, 2009 2:02 pm Post subject: |
How much for 1964-66 Stang, with the housing? I may have a group that would want to buy from you. |
Fab4Fan Samba Member
Joined: June 17, 2005 Posts: 703 Location: Claremont, So-Cal
Posted: Wed Jan 07, 2009 2:44 pm Post subject: |
can you post a pic of your beam aimed at a wall/garage door with those aftermarket housings on the green bug |
Posted: Wed Jan 07, 2009 2:56 pm Post subject: |
Wait...aren't HID lights illegal for road use? |
Posted: Wed Jan 07, 2009 3:15 pm Post subject: |
they are not illegal as far as i know. any car that costs 50k or more has them as a luxary item. i dont see the differance.
i cant do the light against the wall right now because the bug is on stands lol |
