Engine Code AK question
themurdocks
themurdocks is offline
PostPosted: Thu May 08, 2008 8:00 pm    Post subject: Engine Code AK question Reply with quote
I recently purchased a 72 VW SB that has an engine code of AK157272.
VIN is 1122784068.
I have searched the forum and looked at the technical section under engine codes and have not found any AK codes.
Thanks.
Tim
Killeen, TX
mharney
mharney is offline
PostPosted: Thu May 08, 2008 8:28 pm    Post subject: Reply with quote
It's a replacement case.
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Fri May 09, 2008 7:31 am    Post subject: Reply with quote
AK's are good cases too... should be dual relief with big oil galley's and 8mm studs with factory case inserts.
turboblue
turboblue is offline
PostPosted: Fri May 09, 2008 7:47 am    Post subject: Reply with quote
AK should be a 73-74 vintage case with all the features Keith listed.
Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!"
themurdocks
PostPosted: Fri May 09, 2008 7:54 am    Post subject: Reply with quote
Thank you all for the information; very helpful
Tim
Killeen, TX
davidw99
davidw99 is offline
PostPosted: Tue Apr 17, 2018 11:39 am    Post subject: Reply with quote
I know this tread is old, but AK engines are not replacement cases. My '73 Super has an AK case and Wolfsburg confirmed that it is the original engine.
Dave
'73 Saturn Yellow Sports Bug that has undergone a full pan off restoration. "Herbert IV."
'67 Sedan. "Bellamy." Currently being "refreshed" and recently repainted.
neil68
neil68 is offline
PostPosted: Wed Apr 18, 2018 8:55 pm    Post subject: Re: Engine Code AK question Reply with quote
Yep, AK was a fairly common 1973 case, along with AH.
Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo
