nose cone swap
solow
solow is offline
PostPosted: Fri May 09, 2008 12:01 pm    Post subject: nose cone swap Reply with quote
got a extra trany but has a bus nose cone. that of course will not fit in my 61'. i have the nose cone from my old trany I'm going to swap with.. can someone give me a link or explain step by step how to do the swap?
OvalWindowBucket
OvalWindowBucket is offline
PostPosted: Sat May 10, 2008 1:15 pm    Post subject: Re: nose cone swap Reply with quote
take the nuts off on the nose cone and pull the nose cone off. Clean the gasket surfaces and install a new gasket. Put the new nose cone on with the hockey stick pulled out to get the hockey stick into the gear selectors. Slide the nose cone onto the studs on the trans case and torque to spec. My chilton said 11 ft/lbs so thats what value i used. I used gasgacinch on the mating surfaces and the gasket. Make sure the gear selectors are even or in neutral position.
Wanted OG Basalt & Silver Beige interior panels for '63 Deluxe
http://www.thesamba.com/vw/classifieds/detail.php?id=1041828
solow
solow is offline
PostPosted: Sat May 10, 2008 3:04 pm    Post subject: Reply with quote
how can i tell if the selectors are even or in neutral position?
solow
solow is offline
PostPosted: Sat May 10, 2008 3:05 pm    Post subject: Reply with quote
no one has pics of this process being done?
mrafindley
mrafindley is offline
PostPosted: Sat May 10, 2008 3:14 pm    Post subject: Reply with quote
Dude really it is simple there is nothing back there to hurt or go wrong if yo want i have one in the floor i will take apart and take pics russ is out of town or he would post a tech bulliten on it
73 THING
67 Beetle
http://w2.wolfsburgii.com/downloads.htm
solow
solow is offline
PostPosted: Sat May 10, 2008 3:27 pm    Post subject: Reply with quote
if you dont mind and have the time that would be cool
mrafindley
PostPosted: Sat May 10, 2008 3:29 pm    Post subject: Reply with quote
Transmission shift forks in "neutral" position. All 3 slots are in line and the same height.
When installing a nosecone on the tranny, make sure the shift rod moves smoothly in the nosecone bushings with no binding or tight spots. Lower the shift rod out of the bottom of the nosecone to engage the shift forks on the transmission. Also make sure the tranny is in "neutral", and that the end of the shift rod engages the forks while lowering the nosecone onto the transmission.
When installing a nosecone on the tranny, make sure the shift rod moves smoothly in the nosecone bushings with no binding or tight spots. Also make sure the tranny is in "neutral" (as seen in pic), and that the end of the shift rod engages the forks while lowering the nosecone onto the transmission.
(Note, this is a demonstration photo, with no gasket installed)
73 THING
67 Beetle
mrafindley
PostPosted: Sat May 10, 2008 3:30 pm    Post subject: Reply with quote
That fast enough
73 THING
67 Beetle
solow
solow is offline
PostPosted: Sun May 11, 2008 12:29 am    Post subject: Reply with quote
very.. thanks
