BYeaton Samba Member
Joined: November 27, 2007 Posts: 362 Location: El Segundo
Posted: Sun May 11, 2008 12:20 pm Post subject: American Eagle 5's |
Has anyone ever machined down the inside mounting surface on these wheels so the backspace was more like the original Empi's? Sorry I can't find the pics anymore but the Empi's mounting surface is much slimmer and the AE ones are wider. Just seeing if anyone has had this machined down before? |
flyinglow94 Samba Member
Joined: January 17, 2005 Posts: 1168 Location: Las Vegas, Nevada
Posted: Tue May 13, 2008 3:02 pm Post subject: |
The rocket alloy has about 7/16 less than the eagle alloy. This is the Rocket alloy have machined my eagles to fit better. So the answer is yes it is doable.
And here is the Eagle before I machined it.
_________________ "What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
"Socialism is a philosophy of failure,the creed of ignorance, and the gospel of envy,its inherent virtue is the equal sharing of misery.." |
Posted: Wed May 14, 2008 12:16 am Post subject: |
Exactly the pics I remembered. How much did it cost you? And is that the amount you took off? 7/16" Or did you just make it flush and take that step off? |
Posted: Wed May 14, 2008 3:05 pm Post subject: |
I had done these my self. I have a mill in the garage (or about $3500 as my wife would say). The step is about 1/2 or 13mm and the rocket alloys had the same step so I made them the same. _________________ "What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
