MANNAXMAN Samba Member
Posted: Mon Mar 19, 2018 1:19 pm Post subject: Re: What did you do to your Beetle this week? |
Disassmbled my chassis and removed the passenger side pan half. Whoever installed the replacement pan half, did a continuous weld bead for about 6-8 inches along the tunnel toward the rear. That was a b*tch to deal with!
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2661 Location: Long Island, NY
Posted: Mon Mar 19, 2018 4:51 pm Post subject: Re: What did you do to your Beetle this week? |
I went to adjust my clutch this past weekend because 1st and 2nd were a little grunchy.
Coincidentally, I haven't been able to find one of my needle nose vice-grips for months.
So, when I jacked up the car, removed the wheel, and shined a light in there, guess what I saw clamped to the clutch cable. Yep, the vice-grips.
Anyway, I turned the wing nut one full turn - any more was too much. I drove the car around the block and got no grunching but I won't know for sure until I take a longer drive next weekend.
And this time I removed the vice-grips. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
trektider60 Samba Member
Joined: October 30, 2012 Posts: 73 Location: SE Indiana
Posted: Fri Mar 23, 2018 5:56 pm Post subject: Re: What did you do to your Beetle this week? |
With the nice weather today, 45 degrees and 3-5 inches of snow coming over night through noon tomorrow, I got my engine-body seal in. I didn't take the engine out, and installing the new seal was not bad at all. I straightened out the track and used spray silicone and it slid right in. I did have to cut the seal on the right side just forward of the curve, but there is no problem with the splice. No more looking at the ground around the breastplate.
_________________ 1960 Indiana Red T1 |
Posted: Mon Mar 26, 2018 3:36 pm Post subject: Re: What did you do to your Beetle this week? |
Today I installed new NGKs and plug wires. Wilma fired right up on the second crank after her winter rest. Took her down the road for a short drive. Glad the snow is gone and the temps are warm enough to drive a little.
67ctbug Samba Member
Posted: Mon Mar 26, 2018 4:20 pm Post subject: Re: What did you do to your Beetle this week? |
Cut out the front firewall. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
Sqrbckguy38 Samba Member
Joined: December 21, 2004 Posts: 415 Location: Tooele, ut
Posted: Tue Mar 27, 2018 7:16 am Post subject: Re: What did you do to your Beetle this week? |
Finally got my rebuilt engine back into the 67, now I get to finish installing it's bits and teach my daughter to drive the Vw, which my girls named Opal. She is really excited to drive the car. _________________ It's not the fall that hurts, it's the sudden stop at the bottom.
69 Square needs love, even after 15 years
70 Fasty former dd, now my daughter's
67 Beetle, Opal |
beeniebug Samba Member
Posted: Tue Mar 27, 2018 5:09 pm Post subject: Re: What did you do to your Beetle this week? |
I'm a couple weeks late posting here, but I'll try to catch up. Since buying this '67 I have:
Replaced master cylinder, along with the fluid reservoir and all the soft hoses connecting the two. (It already had new shoes, wheel cylinders, and drums.
All 4 soft brakes lines.
Rebuilt the carb.
Checked/cleaned the plugs, points, and re-timed ignition.
New front turn-signal lenses and seals.
New window felts, scrapers, and vent-wing seals.
Right-side mirror.
Wiper blades,
Windshield-washer squirter and seal
Fuse-panel cover.
Straightened out light wiring, so all lights, signals, work.
New running boards.
New rubber seals at door-limit straps, interior-light switches, door handles.
Interior panels on doors and rear quarters.
Shift-rod bushing.
Fresh-air hoses on engine.
Oil change.
Grease front beam.
New steering damper, and ends on right tie-rod.
Painted inside of both bumpers, mounting brackets, and backup light brackets.
New seal under gas tank.
Pretty sure SHE won't ever be able to track how much I'm gonna spend on her car. So far, I've only done the cheap stuff. Gotta lower that front end (drop spindles) and do something about that engine.
I'm tired. |
wesdub Samba Member
Joined: September 30, 2015 Posts: 1 Location: Signal Mountain, TN
Posted: Sat Mar 31, 2018 8:49 pm Post subject: Re: What did you do to your Beetle this week? |
Been making and installing hard brake lines today. |
Sarge11B Samba Member
Joined: November 19, 2017 Posts: 61 Location: Athens, GA
Posted: Sun Apr 01, 2018 1:36 pm Post subject: Re: What did you do to your Beetle this week? |
Got my chassis out of the shop!
HippyTom Samba Member
Joined: December 18, 2013 Posts: 676 Location: Florida, West Pasco
Posted: Wed Apr 04, 2018 8:04 pm Post subject: Re: What did you do to your Beetle this week? |
Installed (2) eight foot 4-bulb LED light fixtures in my garage tonight. WOW!!! Let there be light!!! I've got another 4 foot 2-bulb fixture, but don't really need it. Maybe I'll put it in the laundry room.
Murt Samba Member
Joined: October 01, 2017 Posts: 301 Location: Suffolk, England
Posted: Sun Apr 08, 2018 6:50 am Post subject: Re: What did you do to your Beetle this week? |
I just love that Flower Power Bug Hippy Tom ultra cool
I have just fitted a new rear bumper to my 66, I know it’s a 67 one, and I have the OG ‘towel rails’ that are for a 66, but I like the 67 ones, will run with them for a while, and see the reaction.
I also have 2 OG Hella Foglights, so I’ve bolted them on as well to see how they look.
_________________ 1966 VW Beetle ‘Jules’
1967 Kombi Splitscreen ‘Barney’
2018 VW Caddy Maxi R Line
2017 Golf GTD saloon
2008 VW EOS 2.0 TFSi |
Miklo ¡Chale!
Joined: August 27, 2008 Posts: 2058 Location: Antelope Valley, Ca
Posted: Tue Apr 10, 2018 7:23 am Post subject: Re: What did you do to your Beetle this week? |
Weather's warming up... Put on the Thermador.
_________________ ✠Miklo✠
'55 Type1 "Ozma"
'66 Type1 "Charlotte" RIP
Antelope Valley's Mobile Air-Cooled Guru
Dr OnHolliday wrote: |
As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche... |
Cali_Army_Guy Samba Member
Joined: March 19, 2015 Posts: 2094 Location: Stockton, CA
Posted: Tue Apr 10, 2018 6:50 pm Post subject: Re: What did you do to your Beetle this week? |
Removed some stuff. Installed some stuff.
_________________ 2015 VW Passat Wolfsburg Edition
1966 VW Beetle - Sold |
keary_lewis0303 Samba Member
Joined: March 18, 2003 Posts: 98 Location: St Petersburg FL
Posted: Sun Apr 15, 2018 2:45 pm Post subject: Re: What did you do to your Beetle this week? |
Prepped the 67 for primer and dropped it off at the shop.
79SuperVert Samba Member
Joined: May 31, 2002 Posts: 9758 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Sun Apr 15, 2018 4:56 pm Post subject: Re: What did you do to your Beetle this week? |
Gave the Beetle its spring wash, tuneup and brake adjustment while wearing shorts and sandals in 75 degree sun. The next day it was 40, rainy and windy. _________________ Central Jersey VW Society
Wanted: Art Collins VW (Savannah, Georgia) items - license plate surrounds and other items. Also ivory "AM", "FM" and "SW" buttons for a US Blaupunkt Frankfurt. |
MeeferMadness Samba Member
Joined: June 14, 2004 Posts: 305 Location: Eugene Oregon
Posted: Sat Apr 28, 2018 2:12 pm Post subject: Re: What did you do to your Beetle this week? |
Finished installing the bumpers, deck lid and vintage plate on my Oct 58 euro sunroof. I am hoping to be ready to drive by June 1st!
Bruce Ebling |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sat Apr 28, 2018 5:45 pm Post subject: Re: What did you do to your Beetle this week? |
I did something I thought I'd never do, but since I have three ragtop roof racks- I thought I'd see what one of them looked like in powder coat. The next step is bending the hooks around the bottom bar for the clamps. Intentional scratching and intentional beer required.
I also had to park near my bus in a way that obscures the horrendous rust on it. I like the look of as much original dove blue it has. _________________
EverettB wrote: |
FU#5 |
johnr156 Samba Member
Joined: April 06, 2013 Posts: 144 Location: Dixon, Ca.
Posted: Sun Apr 29, 2018 9:48 am Post subject: Re: What did you do to your Beetle this week? |
Started working on the interior. There is light at the end of the tunnel. |
Posted: Mon Apr 30, 2018 5:43 am Post subject: Re: What did you do to your Beetle this week? |
Well, my daughter and I worked on the 67 a little yesterday, and we got her to fire up and run for a few seconds. Seams I can't get fuel to the carb from the pump via a fuel can with a hose in it sitting on the ground. Not sure if the pump is good, but it was working on the other car. So now next weekend I'm going to finish all the brake hoses, and master cylinder, and run new fuel lines. Then I guess we'll see if she runs normal. _________________ It's not the fall that hurts, it's the sudden stop at the bottom.
67 Beetle, Opal |
Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Mon Apr 30, 2018 9:49 am Post subject: Re: What did you do to your Beetle this week? |
johnr156 wrote: |
....could be a train !!! lol _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
