scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2666 Location: Long Island, NY
Posted: Mon Jul 03, 2017 9:42 pm Post subject: Re: What did you do to your Beetle this week? |
Last weekend I began a hard start relay installation, ran into another problem, and completed the install yesterday.
Replaced my wipers today. Got 'em at my flaps.
Also replaced the rubber gaskets under my front and rear lids. The front is fine, although the lid needs adjustment because some of the rubber sticks out, and I can now see some unevenness in the gaps. The rear lid won't latch now because the new rubber holds the bottom of the lid out too far.
I'll do those adjustments tomorrow.
Next weekend, hopefully I'll get to the turn signal, tail light, and license plate light rubber. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
Posted: Tue Jul 04, 2017 6:08 pm Post subject: Re: What did you do to your Beetle this week? |
Adjusted the front and rear lids. The front is nice and even now. The rear edge comes right up to the steel piece that holds the rubber in place.
The engine lid handle wouldn't latch because it wouldn't turn all the way open for some reason. It's fine now.
Replaced the license plate light rubber. A bit of a PITA, as the piece is just a little too small. After much fiddling, it is still not perfectly even all around, as one edge looks like it wants to crawl under the nose. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
67ctbug Samba Member
Posted: Tue Jul 04, 2017 7:43 pm Post subject: Re: What did you do to your Beetle this week? |
Started the tough process of deciding whether I want to sell it or not.... _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
catfish 44 Samba Member
Joined: July 09, 2008 Posts: 12 Location: Rockaway NY
Posted: Fri Jul 14, 2017 7:49 pm Post subject: Re: What did you do to your Beetle this week? |
New battery |
79SuperVert Samba Member
Joined: May 31, 2002 Posts: 9758 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Sun Jul 16, 2017 2:38 pm Post subject: Re: What did you do to your Beetle this week? |
Swapped out the coil when the car died at a traffic light. _________________ Central Jersey VW Society
Wanted: Art Collins VW (Savannah, Georgia) items - license plate surrounds and other items. Also ivory "AM", "FM" and "SW" buttons for a US Blaupunkt Frankfurt.
stale air Samba Member
Joined: August 23, 2007 Posts: 5155 Location: Senoia Ga, formally NorCal
Posted: Sun Jul 16, 2017 5:31 pm Post subject: Re: What did you do to your Beetle this week? |
Actually, a few weeks back, but I installed a set of Nos 60's aftermarket exhaust tips.
_________________ WANTED: Henry Veale Santa Rosa plate frames
swharris Samba Member
Joined: September 10, 2010 Posts: 502 Location: N. Orange County
Posted: Sun Jul 16, 2017 9:16 pm Post subject: Re: What did you do to your Beetle this week? |
Pulled the motor on my '67 bug. Non original '68 motor that is unbelievably caked with oil/dirt. 1/4" thick in places. This thing must have just been puking oil out of somewhere...oil cooler?? I lived it's life in the desert so the fine silt and oil did a number on everything! I've never seen one this bad.
Car is straight and rust free(thanks desert!), so for now I'll just clean it up and reseal everything and put new tar boards, engine compartment seals, and all the rubber bits. Drive it for a while. Still a long way to go though.
https://www.flickr.com/photos/50514559@N05/albums/72157664450079650
Posted: Sun Jul 16, 2017 9:30 pm Post subject: Re: What did you do to your Beetle this week? |
I hit it...Multiple times...with a large hammer...in anger... _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Laguna1116 Samba Member
Joined: October 04, 2016 Posts: 36 Location: Southern California
Posted: Tue Jul 18, 2017 2:43 pm Post subject: Re: What did you do to your Beetle this week? |
swharris wrote: |
What is that snorkel on the top of the air filter?
I have a hole like that in the top of the air filter on my 68 and thought that the PO had put the hole in there for some reason.
Where does the hose connect? _________________ 1961 Sedan Two Fold Ragtop - Recent restoration completed
1968 99.9% Original Sedan - Driver Sold
1971 Super Beetle Convertible - Wife's Driver
1973 Karmann Ghia Convertible - Work in Progress |
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Wed Jul 19, 2017 7:53 pm Post subject: Re: What did you do to your Beetle this week? |
Hi. Laguna, that "snorkel" was part of the Calif's NOX EGR retrofit device that was required on later '60's cars pursuant to initial registration. I believe it had to be installed for parts and labor- $35. The manufacturer was STP.
The long term damage to the outside components was a drilling into the pre-heat tube of the intake manifold and the air cleaner hole that you see. There was a plate mounted under the carb. I believe it was for '68 thru '70. |
trektider60 Samba Member
Joined: October 30, 2012 Posts: 73 Location: SE Indiana
Posted: Fri Jul 21, 2017 12:35 pm Post subject: Re: What did you do to your Beetle this week? |
Today I got my new windshield in, no more scratches to look through, and polished the rust off the rear view mirror with Al and lemon juice. I took Wilma out for a drive to town and back to check out my savemybug dip stick. Ten mile trip at 87 degrees air temp and there was a 1/4" to go before it would have signaled 225 degrees oil temp. The 2-55 AC worked pretty well. _________________ 1960 Indiana Red T1 |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Fri Jul 21, 2017 2:05 pm Post subject: Re: What did you do to your Beetle this week? |
trektider60 wrote: |
The 2-55 AC worked pretty well. |
You need to step up your game. My 2-80 AC runs much cooler _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Fri Jul 21, 2017 2:08 pm Post subject: Re: What did you do to your Beetle this week? |
When I got home from work today, a big box was on my doorstep. Inside are my interior parts - carpeting, door cards, and other assorted goodies.
You know what I'll be doing this weekend. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
far rider Samba Member
Joined: August 30, 2005 Posts: 773 Location: Rutland, VT
Posted: Sat Jul 22, 2017 6:53 am Post subject: Re: What did you do to your Beetle this week? |
Drove it! Last registered in 77. I bought it in 86 and put it away as a retirement project. Been working on it for the past few years. Now its on the road again and its fun
_________________ 67 zenith blue sunroof
Contentment; when what you have is what you want. |
Posted: Sat Jul 22, 2017 10:25 am Post subject: Re: What did you do to your Beetle this week? |
That's^ a beauty! _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
wcfvw69 Samba Purist
Posted: Sat Jul 22, 2017 10:45 am Post subject: Re: What did you do to your Beetle this week? |
scottyrocks wrote: |
That's^ a beauty! |
I agree. Gorgeous vert. _________________ Contact me at [email protected]
The Samba member since 2004.
lovethatconvertible Samba Member
Joined: August 22, 2008 Posts: 1434 Location: Las Vegas N. V.
Posted: Sat Jul 22, 2017 2:20 pm Post subject: Re: What did you do to your Beetle this week? |
far riders convertible
[/quote]
I agree, that is a beautiful Convertible right there, Nice job breathing some air back into that one. Love the color. _________________ 1960 Convertible |
Posted: Sun Jul 23, 2017 2:12 pm Post subject: Re: What did you do to your Beetle this week? |
Hey Thanks for the compliments. They are appreciated. Will admit that the paint looks better in the pic
Already racking up the miles hitting some beautiful Vermont backroads. _________________ 67 zenith blue sunroof
type1abody Samba Member
Posted: Sun Jul 23, 2017 5:53 pm Post subject: Re: What did you do to your Beetle this week? |
Picked up new wheels, after battling leaking rivets I have them ready to go when the new lug nuts show
jwp67 Samba Member
Posted: Fri Jul 28, 2017 5:02 pm Post subject: Re: What did you do to your Beetle this week? |
Finally got all the pieces for the rear seat lobster claw seat belts for the 67. Very happy with them _________________ 21 million of these cars were built,and everyone of them were sold...kinda astounding given how unreliable they are.---johhnypan |
