Fozzy Samba Member
Joined: August 22, 2012 Posts: 209 Location: United States
Posted: Mon Oct 09, 2017 12:44 pm Post subject: Re: What did you do to your Beetle this week? |
Fired it up, drove around in the sticks.. only had to get under it once to jump the solenoid.. _________________ 65 Sedan..
Adopted 07/15/17
this is the bug I've been looking for..
71 Tin Top Westy
Adopted Dec or so 2017 |
Socalpropertypro Samba Member
Joined: September 11, 2017 Posts: 20 Location: Santa Clarita
Posted: Wed Oct 11, 2017 7:59 pm Post subject: Re: What did you do to your Beetle this week? |
I took a drive up to deutshland metal & body to go check out progress of my 65 sunroof body. Its gonna be Bad a**! Its gonna be a rough 5 months waiting for it to be finished!
Ah Ill make it i think... |
mark tucker Samba Member
Posted: Thu Oct 12, 2017 7:32 am Post subject: Re: What did you do to your Beetle this week? |
if you cant make it right just keep it there and let them make it. |
Sqrbckguy38 Samba Member
Joined: December 21, 2004 Posts: 415 Location: Tooele, ut
Posted: Sat Oct 14, 2017 6:34 am Post subject: Re: What did you do to your Beetle this week? |
Had some time this week for my students to help install a "new" windshield in my 67. Used the old seal for now until we're ready to repaint it.
I pulled the glass from a 76 standard beetle in a junk yard. Hence the "new".
And the progress on refinishing the engine. Pulled this one out of our 74 super and we're just cleaning up this engine. I did use a different set of newer cylinders and different heads as there was some pretty severe damage. New rings and the Bahama coolers underneath with new pushrod tubes. I need to get a new crank pulley, as this one is bent. My students love building this car though. _________________ It's not the fall that hurts, it's the sudden stop at the bottom.
69 Square needs love, even after 15 years
70 Fasty former dd, now my daughter's
67 Beetle, Opal |
67ctbug Samba Member
Posted: Sat Oct 14, 2017 8:41 am Post subject: Re: What did you do to your Beetle this week? |
I actually did work... Started fixing the front apron.
_________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2664 Location: Long Island, NY
Posted: Mon Oct 16, 2017 11:30 am Post subject: Re: What did you do to your Beetle this week? |
After months of nursing along an ailing battery, it finally shit the bed Friday night, in the neighborhood, thank goodness. Wouldn't crank, bump starting did nothing. Luckily my daughter was a block away with her car. Amazing how quickly a 6v starter will spin on a 12v battery.
The battery was so dead it ran pretty roughly the few miles back to the house.
Got me a new one Saturday morning and I am back in business. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
chasepunx Samba Member
Posted: Thu Nov 02, 2017 8:51 pm Post subject: Re: What did you do to your Beetle this week? |
I replaced my axle boots, fixed my 2nd gear grinding problem and used a ton dereaser on the bottom of my engine to clean it up. _________________ 68' Bus
68' Bug
67' Bug
66' Bug (current)
08' Bug (current) |
Bomb Doctor Samba Member
Joined: August 15, 2017 Posts: 8 Location: Jackson, GA
Posted: Mon Nov 06, 2017 3:25 pm Post subject: Re: What did you do to your Beetle this week? |
Cut and buffed the rear deck and roof on Sunday. Even with the best cover I could find it is still a little rough on those spots. I cannot wait for the garage build. Seeing my lift sitting in boxes is frustrating to say the least. |
Edith64 Samba Member
Posted: Mon Nov 06, 2017 5:43 pm Post subject: Re: What did you do to your Beetle this week? |
A few weeks ago now, I spent some time doing a top overhaul on the 40 HP engine. 83 mm pistons and rebuilt F-heads make a huge difference.
Spent an afternoon out with a friend of mine and his '60 leaf viewing
Thanks to all who contribute their knowledge to The Samba so I could complete this project. |
66RubyBug Samba Member
Joined: February 14, 2017 Posts: 3 Location: St. Augustine Fl.
Posted: Sun Nov 12, 2017 1:02 pm Post subject: Re: What did you do to your Beetle this week? |
Had the original 66 1300 engine rebuilt by East Coast VW Restoration. They added 1600cc heads, pistons, and jugs. New Dual Weber 40's, new oil cooler and alternator. And last a brand new ceramic coated exhaust to give the bug an amazing sound. Fallon and team did an amazing job. I highly recommend East Coast VW Restorations.
Next I gonna drop the front-end, add disc brakes and put on a set of 17" smoothies.
MeeferMadness Samba Member
Joined: June 14, 2004 Posts: 305 Location: Eugene Oregon
Posted: Sat Nov 18, 2017 2:17 pm Post subject: Re: What did you do to your Beetle this week? |
Finished adjusting the shifter, now just need to install the throttle cable, steering wheel and be ready for a test ride! Soon after after nearly 3 years I will put the body and chassis together for the last time.
Bruce Ebling
mukluk Samba Member
Posted: Sat Nov 18, 2017 5:10 pm Post subject: Re: What did you do to your Beetle this week? |
Drove my '60 to work every day this week, 267 trouble free miles while netting 30mpg. _________________ 1960 Ragtop w/Semaphores "Inga" |
toddmin Samba Member
Joined: September 28, 2015 Posts: 34 Location: Atlanta, GA, United States
Posted: Tue Nov 21, 2017 6:32 am Post subject: Re: What did you do to your Beetle this week? |
chasepunx wrote: |
I replaced my axle boots, fixed my 2nd gear grinding problem and used a ton dereaser on the bottom of my engine to clean it up. |
What kind of degreaser did you use? I would like to clean mine up more, but don't want to use something that can harm the metal. |
Posted: Tue Nov 21, 2017 6:46 am Post subject: Re: What did you do to your Beetle this week? |
Edith64 wrote: |
Those are awesome photos! |
Buscowboy Samba Member
Joined: October 29, 2004 Posts: 402 Location: South Coast, England
Posted: Wed Nov 22, 2017 12:03 am Post subject: 1961 Swedish Deluxe OG Paint |
Moved my '61 out of storage to fix a few issues. Swap out the clutch, fix the steering lock and a few other minor jobs. _________________ 1962 Gulf Blue Patina Deluxe Beetle
1963 SubHatch Westfalia MG/PW
1967 Fastback RHD Regatta Blue
1970 FI Auto Squareback
1999 T4 Transporter 2.5 TDI Reimo
http://www.youtube.com/@BuscowboyClassics
https://www.instagram.com/buscowboy/ |
BM3Gross Samba Member
Joined: November 22, 2017 Posts: 10 Location: South Georgia
Posted: Wed Nov 22, 2017 2:34 pm Post subject: Re: What did you do to your Beetle this week? |
Got my Gas tank hooked up Yesterday:
https://youtu.be/_HL-ZnBAj80
trektider60 Samba Member
Joined: October 30, 2012 Posts: 73 Location: SE Indiana
Posted: Sat Nov 25, 2017 8:42 am Post subject: Re: What did you do to your Beetle this week? |
I painted the seat frames, gear shift, parking brake, and rear seat bar. Also redid the seats with new coconut pads from WW. What a difference from the 1" foam and wads of cotton padding that was there. I put the TMI seat covers back on since they are in great shape. I also installed a new shift rod coupler. What a difference that made; I didn't know the old one was so bad.
_________________ 1960 Indiana Red T1 |
nreslifer Samba Member
Posted: Sat Nov 25, 2017 4:27 pm Post subject: Re: What did you do to your Beetle this week? |
Changed the spark plugs,checked the fuel pressure,and dialed in the air fuel mixture/idle.Drove over to the gas station filled up with NON ethonal gas then the wife and I went for a drive
Cali_Army_Guy Samba Member
Joined: March 19, 2015 Posts: 2094 Location: Stockton, CA
Posted: Tue Dec 05, 2017 1:39 pm Post subject: Re: What did you do to your Beetle this week? |
Debating on doing valve adjustment and new points at work today, but it’s like 55* and I’m freezing my ass off. Have zero desire to be on my back under my car while being cold. _________________ 2015 VW Passat Wolfsburg Edition
1966 VW Beetle - Sold |
