Bustercat65 Samba Member
Posted: Fri Jun 15, 2018 12:04 pm Post subject: Re: What did you do to your Beetle this week? |
Cleaned many connections, installed a phone charger, replaced all body seals other than the bumpers, reinstalled my repaired OG radio upgraded with an AUX and FM, fixed a nonfunctional dome light, learned how to adjust my carburetor, learned how to use a multimeter to check wires and to check RPMs.
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2645 Location: Long Island, NY
Posted: Fri Jun 15, 2018 12:42 pm Post subject: Re: What did you do to your Beetle this week? |
I just finished a brake adjustment. I now have a high-normal pedal. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
79SuperVert Samba Member
Joined: May 31, 2002 Posts: 9758 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Sat Jun 16, 2018 4:35 pm Post subject: Re: What did you do to your Beetle this week? |
Adjusted my worm and sector steering. Much easier than I thought it would be. _________________ Central Jersey VW Society
Wanted: Art Collins VW (Savannah, Georgia) items - license plate surrounds and other items. Also ivory "AM", "FM" and "SW" buttons for a US Blaupunkt Frankfurt. |
67CarGuy Samba Member
Joined: April 01, 2017 Posts: 46 Location: Boston area, USA
Posted: Sat Jun 16, 2018 6:45 pm Post subject: Re: What did you do to your Beetle this week? |
Installed new battery, new coil, removed the rear seat, and determined I still have a very long way to go before I'm driving safely and having fun (I'm already having fun, though! ). _________________ 1967 Beetle (Family car - 2nd owner) ...What have I gotten myself into?!
1967 Plymouth Barracuda (Family car - 2nd owner) ...See a pattern yet?
rcooled wrote: |
On the other hand, if what the OP really wants is a project that'll take up all of his free time for a couple of years, relieve his bank account of many thousands of dollars and frustrate the living hell out of him, then this car is a good place to start. |
Morganwerk Samba Member
Joined: December 30, 2000 Posts: 496 Location: Sacramento Valley
Posted: Sat Jun 16, 2018 10:23 pm Post subject: Re: What did you do to your Beetle this week? |
New German wheel cylinders. Getting ready for Dubs Around the Lake next week. _________________ Gary
1966 1300 Sea Sand
2003 GTi VR6 |
Envixy Samba Member
Posted: Sun Jun 17, 2018 5:26 pm Post subject: Re: What did you do to your Beetle this week? |
Split my stock 1600 dp and leaning towards buying a super case from CB Performance due to bearing numbers hammered into case. It's gonna need a line bore and blah blah blah. GO BIG OR GO GOME. (not too big lol) |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9663 Location: Oregon
Posted: Sun Jun 17, 2018 5:57 pm Post subject: Re: What did you do to your Beetle this week? |
Blew out the carb jets. Like 5 times this weekend.
Damn things keep getting clogged making the car no fun to drive.
Worked on a friends 66, new PP clutch, TOB. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
DurocShark Samba Member
Joined: April 05, 2004 Posts: 6624 Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
Posted: Sun Jun 17, 2018 6:04 pm Post subject: Re: What did you do to your Beetle this week? |
67rustavenger wrote: |
Worked on a friends 66, new PP clutch, TOB. |
Need new fuel lines or fuel pump diaphragm? _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
Posted: Sun Jun 17, 2018 7:22 pm Post subject: Re: What did you do to your Beetle this week? |
DurocShark wrote: |
Need new fuel lines or fuel pump diaphragm? |
Fuel pump is ok. Likely a new filter along the trans would help.
It's been a frustrating week to be sure.
Thanks. _________________ I have learned over the years.
Buy Once, Cry Once!
Fozzy Samba Member
Joined: August 22, 2012 Posts: 209 Location: United States
Posted: Sat Jun 23, 2018 8:39 pm Post subject: Re: What did you do to your Beetle this week? |
Pulled the carb and the hideous spacer.. bent the manifold a bit, reassembled everything, put on the stock air cleaner.. drove it around town.
Ordered some new headlight globes..
_________________ 65 Sedan..
Adopted 07/15/17
this is the bug I've been looking for..
71 Tin Top Westy
Adopted Dec or so 2017 |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Wed Jul 04, 2018 3:47 pm Post subject: Re: What did you do to your Beetle this week? |
Pulled my '67 out of storage a few weekends ago, been taking it on longer and longer drives to make sure things are working well.
Issues:
* I noticed it had been pulling to the right during hard braking. Turned out the front right brake was adjusted a little too tight -- fixed!
* Engine runs a little hot, leaks oil from the top while running, and has low oil pressure at idle. I recently installed a VDO oil pressure gauge, which ruled out a flaky idiot light sender. The (original) engine has all of its tin and runs strong, but is probably worn and in need of a rebuild. In the meantime, I've been checking ancillary things: there's no junk in the fan, the timing is correct, the oil pressure relief valve moves freely for the most part, though the bore isn't perfectly smooth. Today I replaced the oil with 20W50 to bump up the pressure a little (yes this is a band-aid, but it's also been over 90°F a lot recently.) My plan is to check the cylinder compression soon, pull the engine, and replace the oil cooler seals as well as to check the oil pump for wear.
I'm tempted to replace the grooved oil pressure relief valve with a solid one to claw back a little oil pressure at idle, but haven't gotten around to it yet. _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
Posted: Wed Jul 04, 2018 5:14 pm Post subject: Re: What did you do to your Beetle this week? |
Single? Or dual relief case? Makes a difference.
Dual relief cases work best with two non-grooved oil relief pistons.
Towel Rail wrote: |
Issues:
I'm tempted to replace the grooved oil pressure relief valve with a solid one to claw back a little oil pressure at idle, but haven't gotten around to it yet. |
Buy Once, Cry Once!
Posted: Wed Jul 04, 2018 5:18 pm Post subject: Re: What did you do to your Beetle this week? |
Drove the crap outta my 67 as usual.
Ordered a set of Tims stage 2 heads for the 2180 that I built over the winter months and only made it 100+ miles before a head failure. Different vendor was sourced for the first set of heads.
Car Saturday in Camas, Wa. _________________ I have learned over the years.
Buy Once, Cry Once!
wcfvw69 Samba Purist
Posted: Wed Jul 04, 2018 6:06 pm Post subject: Re: What did you do to your Beetle this week? |
If the tired 67 engine is the original case, that thick 50 weight oil may increase your oil temps. The small oil passages in those single port engine cases don't really like the thick oil.
It will take much longer for the oil to reach temperature and thin out enough to let the oil go through the cooler. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Wed Jul 04, 2018 10:33 pm Post subject: Re: What did you do to your Beetle this week? |
Dual relief cases work best with two non-grooved oil relief pistons. |
Single relief, original H0 engine. I know (and agree with) the theory behind the grooved piston, but in my case, I think it's throwing away oil flow that could be better used at the bearings.
wcfvw69 wrote: |
It will take much longer for the oil to reach temperature and thin out enough to let the oil go through the cooler. |
My gauge is telling me that the cold pressure at startup (fast idle) is about 40psi, and it never gets much above that in normal driving, so I don't think I'm spending much time bypassing the oil cooler.
All of the admonitions against using thick oil and oversized oil pumps and "booster" kits make total sense when dealing with a healthy engine. I'm just trying to find ways to achieve my 10psi/1000rpm until I have the bandwidth to rebuild the engine or install a replacement. Experience has shown (see the Thing thread in my sig) that once a project car is no longer in a driveable state, my motivation goes out the window. _________________ 1974 Thing -- under the knife
Posted: Sun Jul 08, 2018 9:27 pm Post subject: Re: What did you do to your Beetle this week? |
More tweaking of my oil pressure relief valve.
I said before that the relief bore isn't completely smooth, but it seems to be smooth and straight except for a very slight ledge/step partway up. From my searches, it appears the ledge has been known to show up due to the way cases are machined and usually isn't a problem, but when testing the movement of the piston in the bore with my finger, sometimes the piston would stop and not want to move at that point. Perhaps the bore is worn just enough that the piston will tilt and jam if its edge catches the ledge during its movement.
Here's a picture from supersuk's '68 Fastback thread. Mine looks pretty much the same:
I thought about using sandpaper on a dowel to smooth out the ledge, but considering that pistons can be easily replaced while a messed-up bore could junk the case, I decided to work on the piston. In theory, if the piston tapers to a smaller diameter on each end, it will be less able to hang up on an irregularity in the bore. (For an extreme example, think about a bullet in a gun bore. Aerodynamic considerations aside, you would not want one of those to get stuck partway!)
So I filed each of the four chamfers (this is a grooved piston, remember) slightly deeper and then softened each of those edges by lightly filing at steeper and shallower angles to the chamfers. Then I polished up my work using 1500 grit sandpaper soaked in WD-40 on a rubber block before thoroughly cleaning the piston. The end result is much like a fillet, if I'm using my words right. The corners are now very smooth, and a test run with my finger had the piston going up each time without stopping. In some cases, I could feel a little "bump" as it passed the ledge, but it was easily getting around it now. Success! I also smoothed the ends of the relief spring to make sure there weren't any sharp corners to scratch the bore.
I drove the car around on a couple of errands today, and my gauge never got below about 5 psi at idle. That isn't necessarily proof of anything since I wasn't doing WOT runs on the highway at 100°, but I think I can rule out oil relief piston misbehavior now. _________________ 1974 Thing -- under the knife
Posted: Mon Jul 09, 2018 1:50 pm Post subject: Re: What did you do to your Beetle this week? |
Tried again to start her up, after bypassing the tank with some new fuel line.... Nuthin'!
So let's test the fuel pump... pulls fine, but it can't push anything out... ok, let's remove it.
Wellll, this here book tells me that it's easier to just remove the whole dang engine, and that doesn't seem right. I mean, the pump is just sitting right there, right? Let's have a look....
Remove dizzy, remove air cleaner assembly, then remove fuel pump. Discover that it's a crimped unit, with no obvious means of opening it up to R&R anything (see a soon-to-be upcoming thread about this - I'll add the link once it's up), and still no luck.
So we reassemble the whole mess, and now she won't even kick over. WTH?
Back to the book(s), crawl under the right rear and knock around on the starter and solenoid... ok, now we're cranking again, but it looks like we're going to need a new fuel pump. This time, one that can be fixed, rather than replaced.
Phew - and all that in one afternoon! _________________ 1967 Beetle (Family car - 2nd owner) ...What have I gotten myself into?!
rcooled wrote: |
Posted: Tue Jul 10, 2018 5:35 pm Post subject: Re: What did you do to your Beetle this week? |
Quick note on my oil pressure saga: got an oil pressure relief valve kit (you know the kind) in the mail, left the springs in the package, did my filing and polishing trick to the ungrooved piston and test-fit it in the bore. It moved nicely in both directions, so I installed it and did some driving today. At start-up, my oil pressure briefly rose to 50 psi before settling back down as it warmed up. Drove the car on a quick errand, and only saw the oil light come on (10psi with the VDO sender) toward the end of my trip. Very tempted to put my stock oil pressure sender back in and call it a day. _________________ 1974 Thing -- under the knife
67_13Deluxe Samba Resident Alien
Joined: February 18, 2005 Posts: 912 Location: Salt Lake City, Utah
Posted: Thu Jul 19, 2018 5:55 am Post subject: Re: What did you do to your Beetle this week? |
I didn't do a hell of a lot but I did get my horn fixed! |
Posted: Thu Jul 19, 2018 8:27 am Post subject: Re: What did you do to your Beetle this week? |
Installed new NOS rubber floor mats. I reluctantly discarded the old ones, which were original to the car. In addition to their color having faded, they were crumbling. Every time I moved them another piece would come off, or another tear would appear. I guess 50 year old rubber has but just so many years in it. _________________ Central Jersey VW Society
