67 Florida Deluxe Samba Purist
Joined: June 21, 2005 Posts: 7987 Location: Gainesville and Tampa, Florida
dmackustom Samba Member
Posted: Thu Aug 23, 2018 6:18 am Post subject: Re: What did you do to your Beetle this week? |
67 Florida Deluxe wrote: |
I dig the YOM license plates! |
And I get to pay $40 extra for providing my own plates!! _________________ 1969 bay window |
67_13Deluxe Samba Resident Alien
Joined: February 18, 2005 Posts: 912 Location: Salt Lake City, Utah
Posted: Thu Aug 23, 2018 2:42 pm Post subject: Re: What did you do to your Beetle this week? |
I gave the front end a lube job and put new oil filled shocks all around. |
Sqrbckguy38 Samba Member
Joined: December 21, 2004 Posts: 415 Location: Tooele, ut
Posted: Sat Aug 25, 2018 7:13 am Post subject: Re: What did you do to your Beetle this week? |
I finally got to putting the right door glass back in. I was remiss to put it together with new seals and felt and such, only to have to rip it all out again when I paint the car. So I just put the old felt in, and will leave the window up for winter. I ordered a piece to repair the bottom door hinge area. It's a bit rotted. I still have to figure out why one brake light doesn't work, left, and when I step on the brake with left turn signal on, it just blinks fast, step off brake and it works normal. _________________ It's not the fall that hurts, it's the sudden stop at the bottom.
69 Square needs love, even after 15 years
70 Fasty former dd, now my daughter's
67 Beetle, Opal |
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2664 Location: Long Island, NY
Posted: Sat Aug 25, 2018 8:23 am Post subject: Re: What did you do to your Beetle this week? |
I was able to determine, yesterday, that the coil is putting out spark. Still won't start, though. Lots of cranking but no hint of ignition.
I'm gonna check the valves for correct adjustment, check the point gap and static timing. If it doesn't start, the carburetor is next.
Fuel gets to the carb, but once there I don't know yet if there is a problem inside the carb. So i'll be looking for some sort of clog/obstruction. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Sat Aug 25, 2018 8:49 am Post subject: Re: What did you do to your Beetle this week? |
I installed a Carter P06504 electric fuel pump and tach sensing fuel pump relay.
I turn the key to the on position and hear a faint buzz of the FP for 3 seconds then it shuts off. Works as designed.
Have a great day. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
drsisbad Samba Member
Joined: February 20, 2010 Posts: 6 Location: Upland,California
Posted: Mon Sep 03, 2018 5:48 pm Post subject: Re: What did you do to your Beetle this week? |
Started to put my 1776 engine back into my 66. Does anyone know if there is supposed to be a lot of resistance when u crank by hand with a socket |
Cali_Army_Guy Samba Member
Joined: March 19, 2015 Posts: 2094 Location: Stockton, CA
Posted: Fri Sep 07, 2018 6:30 pm Post subject: Re: What did you do to your Beetle this week? |
Started putting my motor back together
_________________ 2015 VW Passat Wolfsburg Edition
1966 VW Beetle - Sold |
mukluk Samba Member
Posted: Fri Sep 07, 2018 8:56 pm Post subject: Re: What did you do to your Beetle this week? |
Cali_Army_Guy wrote: |
Might want to put the beer away until you're done as you seem to have put the flywheel on backwards.
_________________ 1960 Ragtop w/Semaphores "Inga" |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Sat Sep 08, 2018 6:58 am Post subject: Re: What did you do to your Beetle this week? |
mukluk wrote: |
Funny, but that makes a workable crankshaft stand. I just used an old gland nut in my bench vise. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Sat Sep 08, 2018 11:17 am Post subject: Re: What did you do to your Beetle this week? |
Which engine is this?
The old broken 40 horse? _________________ I have learned over the years.
Buy Once, Cry Once!
mukluk Samba Member
Posted: Sat Sep 08, 2018 12:47 pm Post subject: Re: What did you do to your Beetle this week? |
Cusser wrote: |
mukluk wrote: |
Funny, but that makes a workable crankshaft stand. I just used an old gland nut in my bench vise. |
It was meant to be a joke, hence the laughing emoticon.
I do use an attached flywheel when working on the crank as well, attached in the normal direction with the gland nut screwed in finger tight. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Sat Sep 08, 2018 1:50 pm Post subject: Re: What did you do to your Beetle this week? |
67rustavenger wrote: |
The old broken 40 horse? |
Nah. This is a 1641 that’ll have dual carbs and some other CB Performance goodies. Should be wrapped up by Wednesday. _________________ 2015 VW Passat Wolfsburg Edition
Posted: Sat Sep 08, 2018 1:52 pm Post subject: Re: What did you do to your Beetle this week? |
Nah. This is a 1641 that’ll have dual carbs and some other CB Performance goodies. Should be wrapped up by Wednesday. |
Sweet! That'll push your 66 down the hiway nicely.
What carbs are you planning using? _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Sat Sep 08, 2018 1:55 pm Post subject: Re: What did you do to your Beetle this week? |
Carbs are Weber 34 ICT’s
http://www.cbperformance.com/product-p/6427.htm _________________ 2015 VW Passat Wolfsburg Edition
Posted: Sat Sep 08, 2018 2:23 pm Post subject: Re: What did you do to your Beetle this week? |
I ran a set of 34ICT's on a 1776 I built 20years ago. I could never get them right. But they sounded cool. My dog could hear them from over a mile away and lope down the driveway to greet my wife as she came up the hill.
The link you posted is for a dual port head. So I assume that is what you're building.
Wanna try a set of 40IDF clones? I have a set that are just tucked away in a box that I ran on my 1679 for over a year.
The set is complete with filter bases, hex bar linkage, and intake manifolds (slightly match ported).
If your interested in trying them send me a PM. I can ship them to you with all the spare jets to get them working on your new engine.
If you don't like them. Send them back. If you do like them. Maybe we can work out a deal. But I'll want the unused jets back. I have several sets of Weber carbs and need the jets.
Wanna give them a shot? Lemme know.
Good Luck _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Sat Sep 08, 2018 2:30 pm Post subject: Re: What did you do to your Beetle this week? |
My motor is a single port. Probably just linked the wrongs ones. Thanks for the offer though. _________________ 2015 VW Passat Wolfsburg Edition
Posted: Sat Sep 08, 2018 2:39 pm Post subject: Re: What did you do to your Beetle this week? |
My motor is a single port. Probably just linked the wrongs ones. Thanks for the offer though. |
Well the ICT's will likely work well on an SP engine.
You're a good guy, and I was making a kind offer from one good guy to another.
I look forward to your first drive impressions with this new engine in your 66.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
glutamodo The Android
Joined: July 13, 2004 Posts: 26320 Location: Douglas, WY
Posted: Sat Sep 08, 2018 3:26 pm Post subject: Re: What did you do to your Beetle this week? |
I think Weber ICTs are a great low-key dual carb setup. Nice, rather simple carbs, not too big, and on an single port engine with it's inherent good port velocity at low speeds, a good match. _________________ Andy T.
Posted: Sun Sep 09, 2018 12:47 pm Post subject: Re: What did you do to your Beetle this week? |
Spent 15 mins pulling my motor out. Waiting on parts to arrive tomorrow to finish the new motor. Then that should be in no later than Wednesday.
