wyatt.bales Samba Member
Posted: Wed Aug 11, 2021 1:11 pm Post subject: Re: What did you do to your Beetle this week? |
I broke the car. Lol! I've been restoring the bug for quite some time now. I've done everything except the paintwork, that's a Macco special! Not bad, just really offset with terrible service but the paint turned out as a B- maybe a C+ job. Anyways, I rebuilt the engine. It's knocking. Everything is new except the rods and I feel like that's my issue. Thoughts?
- https://youtu.be/toCWKV67bFc |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Wed Aug 11, 2021 4:55 pm Post subject: Re: What did you do to your Beetle this week? |
wyatt.bales wrote: |
Did you have your bearings matched to your crankshaft? Was the crankshaft even machined? Why are you even trying to run without the generator/fan turning, and with tins missing? _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
mukluk Samba Member
Posted: Wed Aug 11, 2021 5:05 pm Post subject: Re: What did you do to your Beetle this week? |
The noise seems to be coming from the crankshaft pulley -- makes me think either the pulley is loose on the crank, the pulley bolt washer is loose, or maybe the oil slinger is rattling on the crank. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Wed Aug 11, 2021 7:05 pm Post subject: Re: What did you do to your Beetle this week? |
Cusser wrote: |
Did you have your bearings matched to your crankshaft? Was the crankshaft even machined? Why are you even trying to run without the generator/fan turning, and with tins missing? |
Did I have the bearings matched to my crank, as in a standard crank with a standard bearing? yes. My crankshaft is new and balanced. I'm running without the fan and gen to eliminate questions of "is the fan knocking?" Also, the tins missing don't make the engine run badly. I have the tins. Just getting it back together as it's being restored. |
Posted: Wed Aug 11, 2021 7:07 pm Post subject: Re: What did you do to your Beetle this week? |
mukluk wrote: |
The noise seems to be coming from the crankshaft pulley -- makes me think either the pulley is loose on the crank, the pulley bolt washer is loose, or maybe the oil slinger is rattling on the crank. |
I'll recheck the tightness on the crank pulley, but remember the fan belt is off and the high pitch noise is from that rattleing. I'll get a better video tomorrow. |
Posted: Wed Aug 11, 2021 7:09 pm Post subject: Re: What did you do to your Beetle this week? |
Cusser wrote: |
https://youtu.be/gRXcNQQxxf0, here with the fan/gen belt on. Yes, I will attach the vacuum line once my "T" comes in for it. |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 852 Location: South Florida
Posted: Thu Aug 12, 2021 8:22 am Post subject: Re: What did you do to your Beetle this week? |
Sounds alot like when I was a kid with a clothespin holding a baseball card slapping on bicycle spokes. Do you have a stethascope? A short piece of hose will due; put one end near your ear, other end can probe around to help locate where sound eminates from. (Be careful around moving parts!) |
The Posh Mushroom Samba Member
Posted: Tue Aug 24, 2021 7:37 pm Post subject: Re: What did you do to your Beetle this week? |
Well I started trying to replace a leaky wheel cylinder on my 66.
Turns out my rear axle seal was leaking too, so i replaced the rear axle seal, and both wheel cylinders. Adjusted and bled all the brakes too.
Then my handbrake cable snapped while readjusting it so i replaced the handbrake cables.
I had the car up on jack stands and the wheels off, so i put all new shocks on.
finally i drained and refilled the transaxle and I’ve been driving and enjoying it since
Next up is hooking up my windshield washer fluid reservoir and fixing my emergency flashers! |
dustymojave Samba Member
Posted: Fri Aug 27, 2021 12:11 pm Post subject: Re: What did you do to your Beetle this week? |
So you're saying you're having trouble getting enough blinker fluid and need to upgrade the reservoir?????
_________________ Richard
SoCalBajas Member
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Fri Aug 27, 2021 2:07 pm Post subject: Re: What did you do to your Beetle this week? |
Could be the thrust bearing as well. Did you check and dial in the endplay? _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Pops67Beetle Samba Member
Joined: January 03, 2021 Posts: 127 Location: Queens, NY
Posted: Sun Sep 12, 2021 7:39 am Post subject: Re: What did you do to your Beetle this week? |
Now that school has started it was time to stop taking the bug on long drives and start making some improvements. Today I got rid of the ugly third brake light and replaced it with a led strip. Nice and bright even in sunlight. I also started swapping the fixed quarter glass for original pop outs. Now the kids won’t melt when we get stuck in beach traffic!
One question I have is on a 67 with the “off white” interior should I go with the black hinge cover and interior window trim or should it be the white? Thanks for the help!
_________________ When I close my eyes I’m a little kid riding in the cubby..... Priceless!
13 y/o son’s quote while watching us replace the pedal cluster…. “Who says the Germans lost the war.”
67 Beetle bought new, 95% stock. |
mukluk Samba Member
Posted: Sun Sep 12, 2021 8:22 am Post subject: Re: What did you do to your Beetle this week? |
Pops67Beetle wrote: |
One question I have is on a 67 with the “off white” interior should I go with the black hinge cover and interior window trim or should it be the white? |
In my opinion, the hinge cover colour should match the pinch welt you use. If you have black pinch welt use black covers, and if you have off white pinch welt then use off white covers.
Black: Welt / Cover
Off White: Welt / Cover
There's also a chrome cover option if you want: Chrome Cover _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Sun Sep 12, 2021 8:24 am Post subject: Re: What did you do to your Beetle this week? |
Well……. I wasn’t sure which to use so I got both! I’m leaning towards black because it matches the rest of the window rubber in the car. It also hides dirt. Thanks for the info. _________________ When I close my eyes I’m a little kid riding in the cubby..... Priceless!
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1782 Location: Santa Rosa, Ca
Posted: Tue Sep 14, 2021 5:05 pm Post subject: Re: What did you do to your Beetle this week? |
I changed the shift rod bushing, and job I wasn't looking forward to but it wasn't that bad. The old bushing was shot but the hanger was in good shape, I thought the car shifted good before now it is 10 times better. I made a helper out of PVC to re-install the shift rod it worked out great I got the idea from a U-Tube video. It was more work removing everything that is in the way than it actual job itself, the inside of the tunnel looked brand new.
Posted: Fri Sep 17, 2021 8:09 am Post subject: Re: What did you do to your Beetle this week? |
Well I have been busy this past week installing parts I have had on the shelve for a few months. I put on KYB Gas shocks about 6 months ago and never really liked them, so I replaced them with Sachs brand Oil Filled shocks amd a Sachs steering damper I like this ride better, I also replaced the fender beading that the PO just painted over when he shot the re-paint . Lucked out all the bolts came out pretty easy ( I have been shooting them with PB Blaster the past few weeks) and there is one broken bolt from the PO. I will removed that one when I pull the fenders this Winter.
Hector65 Samba Member
Posted: Sun Sep 19, 2021 5:14 pm Post subject: Re: What did you do to your Beetle this week? |
New to the site and just bought a 65 with aftermarket rag top. |
Posted: Mon Sep 20, 2021 5:48 am Post subject: Re: What did you do to your Beetle this week? |
Welcome! I wish you lots of good luck with all of the projects that come your way. Post a picture or two so everyone can see the progress you make. _________________ When I close my eyes I’m a little kid riding in the cubby..... Priceless!
Posted: Tue Sep 21, 2021 7:14 am Post subject: Re: What did you do to your Beetle this week? |
I re -adjusted the Points and cleaned them up with a file, and also the terminals' inside the cap. Reset the timing with the light and checked the dwell and the RPM with a meter I got at a swap meet Sunday. Still need to check/adjust the valves, should they be adjusted before the Mini tuneup? This is the OG engine, it runs great for the mileage on it. |
smeag Samba Member
Joined: May 17, 2019 Posts: 70 Location: Cooper City, FL
Posted: Tue Sep 28, 2021 5:17 am Post subject: Re: What did you do to your Beetle this week? |
Put in a new solenoid, starter, bushing, and cables. Starts like a champ again. |
