cyclehobby Samba Member
Joined: August 29, 2013 Posts: 156 Location: North Jersey
Posted: Wed Sep 29, 2021 7:40 am Post subject: Re: What did you do to your Beetle this week? |
Adjusted the valves. While doing so, I replaced all the adjuster stud/locknuts with new ones from WW. I did this because a few of the original studs were worn to the point where it was difficult to get a good, accurate reading with my feeler gauge. All new, all adjusted and everything is working great.
I also checked and filled the transaxle oil. I have a small drip from one of the gaskets on the main housing so until I get around to fixing that, I try to keep it clean and checked. All good for now.
Put the Bug in a local car show and won a recognition trophy, so I'm super excited! _________________ 1967 Beetle
Northern NJ |
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1782 Location: Santa Rosa, Ca
Posted: Sat Oct 02, 2021 1:42 pm Post subject: Re: What did you do to your Beetle this week? |
Found the Key code for my door handles the other day. Got ahold of Gabe Keys and he supplied me with the correct Ignition switch and cut two keys, one key now does all the locks.
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Sun Oct 03, 2021 11:52 am Post subject: Re: What did you do to your Beetle this week? |
Installed a Hurst Trigger Shifter in the '66 Beetle. Although it shifted great with the stock shifter after replacing the shift-rod bushing and coupling, with the Hurst it is ( in the words of Linda Richman) "like buttah". Now just driving to the deli makes me all verklempt.
dustymojave Samba Member
Posted: Tue Oct 05, 2021 9:18 pm Post subject: Re: What did you do to your Beetle this week? |
Big Bill wrote: |
I need to ask you for a link or other contact info for this "Gabe".
Since with 955,000 miles on my '58 Baja Bug, it needs new tumblers and keys. The door handles have long since been replaced with early 60s units, and I don't know which year, and they might even not be the same. For several decades, one key worked for all 3 locks. But now the door locks won't work in the handles, although if I take them out of the handles, the key works on both doors as well as the ignition. And I'm down to one key anyway, no spare.
So I need to get hold of someone who can deal with making all 3 the same and add spare keys. _________________ Richard
SoCalBajas Member
Posted: Wed Oct 06, 2021 6:41 am Post subject: Re: What did you do to your Beetle this week? |
dustymojave wrote: |
Big Bill wrote: |
So I need to get hold of someone who can deal with making all 3 the same and add spare keys. |
Hey dusty this is Gabes e-mail address, [email protected] he does great work this isnt the first time I have used him. If you can get the codes like I did he can do it correctly for a fair price. After sending him an e-mail I had a response and had the switch and keys within a week. He is also a vendor on the Samba a good guy. Hope this helps. |
Posted: Sat Oct 16, 2021 4:28 pm Post subject: Re: What did you do to your Beetle this week? |
Big Bill wrote: |
Big Bill wrote: |
Thanks for that Bill. I'll contact him. _________________ Richard
SoCalBajas Member
BSheldon Samba Member
Posted: Sat Oct 16, 2021 8:00 pm Post subject: Re: What did you do to your Beetle this week? |
Pulled the motor with my wife and kids so we can install a new wiring harness.
_________________ "Betty" - 1966 L41 Sedan |
jaysurfs Samba Member
Posted: Wed Dec 08, 2021 8:34 pm Post subject: Re: What did you do to your Beetle this week? |
Purchased my first VW since 2001. Feels good to get back into it. The seller swore it ran a year ago the last time he tried it...Sure it did buddy. Carb clogged up with gunk. Gas was deconposing back to pregistoric state. Gas is coming out and new lines put in. I wanta drive the dam thing before I strip it down to rebuild.
Bug-nut Samba Member
Joined: December 20, 2015 Posts: 488 Location: Knoxville, TN
Posted: Fri Dec 10, 2021 3:50 pm Post subject: Re: What did you do to your Beetle this week? |
Painted my replacement regulator cover black instead of the standard (zinc?) plated finish. Looks more original now. _________________ 1959 Fjord Blue Volkswagen Beetle
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
1962 Austin-Healey Sprite
Snort wrote: |
A 59 Beetle is just an Oval-Window car with aspirations of modernity. |
Teehoovee Samba Member
Joined: January 15, 2016 Posts: 271 Location: Finland , kangasala city .
Posted: Mon Dec 13, 2021 11:40 am Post subject: Re: What did you do to your Beetle this week? |
Posted: Tue Dec 14, 2021 10:37 am Post subject: Re: What did you do to your Beetle this week? |
oldcarsguitars Samba Member
Posted: Thu Dec 16, 2021 3:01 pm Post subject: Re: What did you do to your Beetle this week? |
iowegian wrote: |
I recently bought a VW Thing with this shifter (first VW with one) and was totally amazed. I actually said the same thing when I came back from the test drive to the seller "Drives like buttah! A game changer!" |
hobthebob Samba Member
Joined: December 08, 2021 Posts: 375 Location: Austin, TX
Posted: Sat Dec 25, 2021 5:59 pm Post subject: Re: What did you do to your Beetle this week? |
This week I bled the brake fluid and replaced one of rear wheel cylinders.
Turns out after replacing one rear wheel cylinder because it had been leaking, the other one just failed as well. One side of the cylinder was seized.
I know I'll have to grease the front wheel bearings sometime soon, just not looking forward to it. Is it a very time consuming job? This is my first Beetle. |
aa390392 Samba Member
Posted: Mon Dec 27, 2021 10:51 am Post subject: Re: What did you do to your Beetle this week? |
Just an fyi, when replacing 1 cylinder its wise to replace them all , even the master as well...
Old ones give up. _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
Posted: Mon Dec 27, 2021 1:13 pm Post subject: Re: What did you do to your Beetle this week? |
Thanks man, the other set of brakes seem to be working fine. I adjusted the shoes on all 4 wheels, bled the system completely with fresh fluid, and I'm keeping an eye on the drums every time I drive for any leaks.
I know myself, and like other owners on this site, if I fix one thing I am tempted to do preventive "fixes" on about ten other somehow related items. That's kind of a slippery slope I'm not willing to go down right now. If it ain't broke don't fix it. I have a working emergency brake just in case! |
Posted: Mon Dec 27, 2021 2:22 pm Post subject: Re: What did you do to your Beetle this week? |
EM brake is a great solution....I forgot about that. _________________ .
55 ragtop
56 delux sedan
56 Kabriolet |
RBurn Samba Member
Joined: May 08, 2016 Posts: 115 Location: Northern Ca
Posted: Mon Jan 17, 2022 8:51 pm Post subject: Re: What did you do to your Beetle this week? |
Both in storage the last three years. Bought a lift to store them at home and be able to work on our vw’s.
_________________ 70 Karmann Ghia Vert
67 Beetle deluxe
62 Single Cab
70 T2 Model 221 *CARR FIRE Victim
70 T2 Model 231 *CARR FIRE Victim |
alex857 Samba Member
Joined: December 26, 2010 Posts: 714 Location: Stuttgart/Germany
Posted: Thu Jan 27, 2022 1:38 am Post subject: Re: What did you do to your Beetle this week? |
Pulled my 1961´s starter motor. It still works well but needs a brush up:
toxicavenger70 Samba Member
Posted: Thu Jan 27, 2022 9:42 am Post subject: Re: What did you do to your Beetle this week? |
Installed Toyota Koito H4 Headlights. Next I am rewiring the Toyota harness to integrate with the VW. That way I get use their relays and plugs. |
Buscowboy Samba Member
Joined: October 29, 2004 Posts: 402 Location: South Coast, England
