67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9770 Location: Oregon
Posted: Mon May 16, 2022 7:13 pm Post subject: Re: What did you do to your Beetle this week? |
The thermostat down rod can be installed, with the engine in the car.
But you have to lift the fan shroud high enough to get the down rod through the head.
And doing so might cause you to have to remove the decklid, spring and the attaching mounts.
If it a stock engine. It might be less hassle, to remove the engine and do it without all the fiddly bits fighting you. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Crew Dad Samba Member
Joined: January 12, 2018 Posts: 39 Location: Nashville/TN
Posted: Wed May 25, 2022 8:18 pm Post subject: Re: What did you do to your Beetle this week? |
Added LED tail lights to the old 67 housings and
And mounted to the fiberglass fenders... |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9830 Location: Somewhere between Dubuque and Keokuk
Posted: Sat May 28, 2022 4:48 pm Post subject: Re: What did you do to your Beetle this week? |
After 17 years of talking about it, I finally had my '66 Beetle's driver seat upholstery repaired. The original vinyl was in decent shape but seam stitching had given up the fight (and 56 years of flatulence had discolored the "basket weave" portion of the cushion beyond the point of cleaning it).
The backrest just needed to be re-stitched (but it got new pad.)
The passenger seat was fine so I left it alone.
BEFORE
A retired local auto upholstery guy agreed to do the job, so I ordered new pads from Wolfsburg West. Fortunately I had a very good used rear seat cushion cover from a Platinum '66 in the garage that could be used as donor material.
AFTER
Posted: Sat May 28, 2022 10:22 pm Post subject: Re: What did you do to your Beetle this week? |
Did a proofing run in my recovered 67 today.
Drove a 50 mile round trip to my SIL's ranch and back home.
The car ran well for what it currently has for an engine.
I enjoyed the drive.
The next run will be to the NW Bug Run June 4th.
Hell! I even signed up for Saturday racing.
Frenchroast will likely beat me to the line, every time we meet up at the lights. _________________ I have learned over the years.
Buy Once, Cry Once!
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1782 Location: Santa Rosa, Ca
Posted: Sun Jun 05, 2022 3:16 pm Post subject: Re: What did you do to your Beetle this week? |
New running boards today. Picked them up at Bug-O-Rama last Sunday along with a few odds and ends that are in better shape than the ones on the car. These are the supposed HD units...the fit was just OK but much better than the roached out ones that were on it.
hobthebob Samba Member
Joined: December 08, 2021 Posts: 375 Location: Austin, TX
Posted: Tue Jun 07, 2022 9:00 pm Post subject: Re: What did you do to your Beetle this week? |
Took my 67 out for a ride tonight with the wife and baby. Been a few days since it ran, but once it got up and running it drove like a dream. One girl in her SUV next to us at a stoplight started taking pictures and ooing/aaahing at it. Fun! |
Posted: Sun Jun 12, 2022 8:27 pm Post subject: Re: What did you do to your Beetle this week? |
I adjusted the choke for the first time after reading up on it.
I am still very new to cars, much less classic cars, and for about a month now, since I cleaned and rebuilt my carburetor, the car would start up (only on cold starts), struggle to stay running, often pop when I pressed the accelerator down, and then frequently die. I figured he was running lean due to the pop out the exhaust, as I had just replaced the exhaust a few months ago, so exhaust leaks were out of the question. Why could he be running lean? I tried everything, and finally realized it must be the choke.
Seemed simple enough, so I read up on it online, and after adjusting it to close almost fully on cold startup, he started RIGHT up, and idled smooth as can be.
Morals of the story: 1. Chokes are essential, at least for my car, because running rough for 30 seconds isn't an option. 2. I can rise to these challenges with this car. Ever since I got it 10 months or so ago, it's been one thing after another. I figured I finally had it sorted after I rebuilt the carb, when the starting issue happened. Never give up. God hasn't given up on me yet. |
62RagTopBug Samba Member
Joined: April 10, 2022 Posts: 12 Location: MidMichigan
Posted: Fri Jun 17, 2022 12:10 pm Post subject: Re: What did you do to your Beetle this week? |
Removed old carpet, added insulation, rubber flooring, front hard plastic floor mats and a new shifter.
lhd65bug Samba Member
Joined: September 04, 2020 Posts: 49 Location: United Kingdom
Posted: Fri Jun 17, 2022 12:43 pm Post subject: Re: What did you do to your Beetle this week? |
62RagTopBug wrote: |
The Berg's a great shifter; run one in my '67.
Look's good too !
trektider60 Samba Member
Joined: October 30, 2012 Posts: 73 Location: SE Indiana
Posted: Fri Jul 01, 2022 9:22 am Post subject: Re: What did you do to your Beetle this week? |
I was told Wilma had a respray in 1973, and her paint wasn't real bad. After watching AutoGeeks I gave her two coats of Meguiar's #7. The first coat was left on overnight and the second coat was applied and then polished off. I then applied a coat of Meguiar's GoldClass carnuba wax. It really brought out the Indiana Red color.
before
after
_________________ 1960 Indiana Red T1 |
Posted: Sun Jul 17, 2022 5:53 am Post subject: Re: What did you do to your Beetle this week? |
Replaced the cracked steering wheel and turn signal switch. Keeping old parts. |
Posted: Sun Jul 17, 2022 2:39 pm Post subject: Re: What did you do to your Beetle this week? |
Washed the pile of dirt in my driveway Friday. I found a 67 beetle under all the dirtiness!
Yesterday morning. I hopped in the car to attend the Yamhill Derby Day's parade.
Wouldn't ya know it. The damn generator idiot light came on and would not go away with some revs.
I drove my Tundra to the parade.
Later in the afternoon. I once again hopped in the 67 to go to the Pacific Office Automation Summer party. Started the car, red light on again.
While fiddling around getting ready to drive off, it's a short drive to the party. The light went out and never came back on. Weirdness!
EDIT: forgot today's activity.
Drove the car to the store to warm it up real good.
Got back home and adjusted the points. They were a little closed. Started the car and checked the timing, 10° BTDC. Perfect for the camshaft I'm running.
The went after the carb adjustments. It's been running rich.
Adjusted the mixture screw in until the engine stumbled a bit. Turned the screw back until the engine ran smoothly.
After that, I adjusted the idle speed to 1000RPM. Yeah, I know a bit high. But below that, the engine wants to die at idle. Another product of incorrect camshaft selection.
The engine runs great now and has a little better throttle response.
I'll run it like this for a while. _________________ I have learned over the years.
Buy Once, Cry Once!
Stock Steve Samba Member
Joined: April 10, 2005 Posts: 1963 Location: My Left Nutmeg State
Posted: Tue Jul 19, 2022 6:11 am Post subject: Re: What did you do to your Beetle this week? |
Stock Steve wrote: |
Those plastic floor mats look decent--where did they come from, if you don't mind my asking? Are you satisfied with their quality? Thank you. |
I purchased those from West Coast Metric, very happy, cleaning is easy, remove, spray and let them dry.
Part #: 111-401
Link: https://www.westcoastmetric.com/i-22964193-111-401.html |
Posted: Sat Jul 23, 2022 8:36 am Post subject: Re: What did you do to your Beetle this week? |
Fixed the kinked fuel line, added a seal between fuel tank and body, new horn, Found a cool vase mount on ebay.
Posted: Sun Jul 24, 2022 6:49 pm Post subject: Re: What did you do to your Beetle this week? |
Spent Friday installing the OG pedal cluster in the 67 Java Green beetle. Then the gas tank. It still needs the brakes bled. I'm not in any rush to get this car on the road.
This car will be up for sale later this year.
Went to the store. When I arrived back home, there was a package from WW on the porch.
New shock absorbers all the way around and front turn signal lenses.
These goodies got installed on the ZenithBlau 67 immediately.
After installing the shocks. I took a short spin through the neighborhood.
The car rides a little less harsh than with the KYB GR-2's that came on the car when I purchased it 6 years ago.
The ideal behind the shock installation is, to help with launching off the starting line during the peashooter drags. We'll see how that works out next Saturday night 7/30/22. _________________ I have learned over the years.
Buy Once, Cry Once!
RCJH77 Samba Member
Joined: March 27, 2022 Posts: 192 Location: Johnson County, KS
Posted: Mon Aug 01, 2022 7:01 am Post subject: Re: What did you do to your Beetle this week? |
After finally fixing all of the electrical issues, I got back to work on repairing the paint. I used rattle cans from PaintScratch, who matched the paint perfectly. I still need to put some rubbing compound on the clearcoat, but I'm happy with the results so far.
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1302 Location: North Carolina
Posted: Fri Aug 05, 2022 10:04 am Post subject: Re: What did you do to your Beetle this week? |
Got rid of these in favor of stock units!
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2666 Location: Long Island, NY
Posted: Fri Aug 05, 2022 10:40 am Post subject: Re: What did you do to your Beetle this week? |
To paraphrase Bugs Bunny, I re-re-re-adjusted my shifter yet again, as the slot for 2nd had gone on vacation.
Hopefully I did the bolts tight enough this time. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
