irvanm Samba Member
Joined: January 09, 2008 Posts: 609 Location: Lawrence, Kansas
Posted: Mon Feb 06, 2023 6:59 pm Post subject: Re: What did you do to your Beetle this week? |
I had a sticking rear brake so we put it on Pats lift and he changed the rear brake hoses, fixed the problem.
hobthebob Samba Member
Joined: December 08, 2021 Posts: 375 Location: Austin, TX
Posted: Mon Feb 06, 2023 7:43 pm Post subject: Re: What did you do to your Beetle this week? |
Great job! I had to switch out my rubber lines as well when my master cylinder leaked out and left me with only front brakes... Then one of my wheel cylinders was leaking, too!
If your rear hoses were shot, I suggest replacing the master cylinder as well as all your wheel cylinders, because they might not be far behind! Safety first, my friend. A few hundred bucks and some of your time, or your very life itself... |
72alpinewhitebus Samba Member
Joined: July 04, 2016 Posts: 77 Location: Eugene, Oregon
Posted: Sun Mar 19, 2023 2:45 pm Post subject: Re: What did you do to your Beetle this week? |
I started Bubba (1960 w/40hp) up after 3yrs on stands.
Blew through some really bad gas.
Static timing, mutiple belt tightenings and a clutch cable adjustment (that wing nut system always makes me chuckle). Just got him up to 55mph for the first time and after working out the kinks, he's gonna be my dd.
Tons of help getting here from The Samba community - many thanks!
_________________ "What's the difference between a pro and an amateur? A pro doesn't think they're an amateur."
72 Westy
60 Sedan
79 Vert |
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2666 Location: Long Island, NY
Posted: Sun Mar 19, 2023 8:42 pm Post subject: Re: What did you do to your Beetle this week? |
New ignition switch with new keys. No longer fearful of breaking off the only remaining key, which was a 'close' blank, modified by a professional locksmith, in the ignition. _________________ If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them on some level there's no rational grounds for it.
D. Tartt, 'The Goldfinch' |
ZEKE65 Samba Member
Joined: December 16, 2018 Posts: 334 Location: Right Coast, Florida
Posted: Tue Mar 21, 2023 8:58 am Post subject: Re: What did you do to your Beetle this week? |
Added 1966 turn signal lever and dimmer relay system to my 65 this week. The foot dimmer under the clutch petal was a real pain. _________________ 1965 VW Sedan, 1968 C10 Step BB, 99 C5 |
bigdog1962 Samba Member
Joined: August 11, 2010 Posts: 1586 Location: Augusta, Georgia
Posted: Tue Mar 21, 2023 3:21 pm Post subject: Re: What did you do to your Beetle this week? |
Wondered why my generator light wasn't coming on....and thinking the worst. Researched possible causes here on the Samba. Checked the bulbs first, both were good. Went around to the engine and lo and behold, a loose wire. Squeezed the connection to make it a little tighter going on, hooked up and and the light is working as it should.
_________________ Oprn wrote: I'm getting to the age that any self propelled woman (no wheel chair or walker) looks HOT!! Oooo! look at that Babe! She made it from the dining room all the way to the TV room without help!! Hubba, hubba!! |
LALA4Fire Samba Member
Posted: Fri Mar 31, 2023 8:44 pm Post subject: Re: What did you do to your Beetle this week? |
I
refurbished my OG running boards and installed my engine. 1960 beetle. |
VWAdam Samba Member
Joined: February 14, 2002 Posts: 3331 Location: Birmingham, Alabama
Posted: Wed Apr 05, 2023 4:16 pm Post subject: Re: What did you do to your Beetle this week? |
This was technically a week and a half ago but I took my '59 Euro (the one in the garage) to my cousin in Chattanooga, TN for some long overdue metalwork. The red Bug is his '60. He's new to VWs but a welder so we are trading out metalwork for me teaching him some things about working on the aircooleds.
_________________ All he needed was a wheel in his hand and four on the road.
'59 Euro Beetle ragtop
'63 Standard Microbus
Come to my show! www.volksjam.com
Looking for badge/sticker/frame from Western Motors in Great Falls, Montana |
mikelars Samba Member
Joined: February 27, 2019 Posts: 238 Location: North Carolina
shano63 Samba Member
Joined: October 06, 2006 Posts: 3596 Location: Stormville NY
Posted: Sun Apr 09, 2023 5:24 pm Post subject: Re: What did you do to your Beetle this week? |
Just an oil change and a valve adjustment. Time to wake her up for another season! I've put almost 19k on her since I put her on the road back in Aug of 08 _________________ 63 T1 Ragtop Gulf Blue
08 Civic 5spd
22 Wrangler 6spd
78 F250 4x4 4spd
Chris
Take it as it comes-- Morrison |
eglene Samba Member
Posted: Fri Apr 21, 2023 12:15 pm Post subject: Re: What did you do to your Beetle this week? |
I just got my carpet kit in for my 1966 Bahama blue bug from WW.
I'm going with the synthetic charcoal with black rubber mats. It looks better than I thought.
I hope to be installing it this weekend. Just have to buy some glue and maybe sound deadener. |
agramer1966 Samba Member
Joined: October 17, 2010 Posts: 151 Location: Northern Poland
Posted: Tue Apr 25, 2023 10:26 pm Post subject: Re: What did you do to your Beetle this week? |
Weather at last got nice so I have '66 a first spring wash and sundrying😀
_________________ 1966 VW1300
1973 VW1302
1974 VW Trike
1984 924
Bunch of old Jap motorbikes
Instagram & YT: #agrameroldoctane |
Posted: Wed Apr 26, 2023 5:58 am Post subject: Re: What did you do to your Beetle this week? |
I reset the timing again recently. I was popping out the carb for some reason, accompanied by a stumble from idle whenever it popped. And the car was taking longer to start (turning over more than normal), so I realized it could be a timing issue and did it.
Turns out the last time I changed my points, I forgot to check the timing! WAY off, the car was running sluggish as molasses before, now it starts right up and runs like a clock. No pops or stumbles noted yet... |
Posted: Wed Apr 26, 2023 8:10 am Post subject: Re: What did you do to your Beetle this week? |
I replaced the shift coupler that I had thought I already replaced. Hey, 3rd gear every time! _________________ If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them on some level there's no rational grounds for it.
Stockholm VW Samba Member
Posted: Wed Apr 26, 2023 8:52 am Post subject: Re: What did you do to your Beetle this week? |
New door and quarter panels. 66 only style from Wolfsburg West (TMI). I hate those damned clips with a passion. 😤 _________________ 1966 Volkswagen Sedan 1300 (now 1641), 6 volt, L456 Ruby Red, Platinum leatherette.
Big Bull Shooter Samba Member
Joined: April 28, 2018 Posts: 460 Location: Canadian Rockies
Posted: Wed Apr 26, 2023 12:35 pm Post subject: Re: What did you do to your Beetle this week? |
Stockholm VW wrote: |
New door and quarter panels. 66 only style from Wolfsburg West (TMI). I hate those damned clips with a passion. 😤 |
I feel your pain - literally! I just did that last week, and my fingers are still sore. I used as many of my original clips as I could. _________________ Where would this hobby be if no one shipped parts.
crukab
Feb. 11, 2021
Smokey says.... only you can prevent Bug fires!
zerotofifty
May 16, 2023 |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Sat Apr 29, 2023 3:53 pm Post subject: Re: What did you do to your Beetle this week? |
Very nice. It looks exactly like original. Except yours is wrinkle free.
Posted: Sat Apr 29, 2023 4:11 pm Post subject: Re: What did you do to your Beetle this week? |
iowegian wrote: |
Yeah, the TMI door cards replicate the originals very well. Im pleased. Heres what the old one looked like. 🫣 Pretty rough.
_________________ 1966 Volkswagen Sedan 1300 (now 1641), 6 volt, L456 Ruby Red, Platinum leatherette. |
Posted: Wed May 03, 2023 5:27 pm Post subject: Re: What did you do to your Beetle this week? |
Today I cleaned up and painted the VW accessory roof rack on my '66 Beetle using Dupli-Color "High Performance Wheel Coating" #HWP101 silver.
I am satisfied with the result.
65'1300Deluxe Samba Member
Joined: November 24, 2009 Posts: 584 Location: Auburn, Washington
Posted: Sat May 06, 2023 12:31 pm Post subject: Re: What did you do to your Beetle this week? |
After 15 years of sitting next to my folks house, I dragged the carcass of my 65' to my own garage, ready to tackle the bodywork that stalled me out in Highschool! _________________ 1965 Deluxe Beetle "Camilla"
1972 Super Beetle Barnfind "Roland"
2001 GTI 1.8L Turbo |
