Stockholm VW Samba Member
Posted: Sat May 06, 2023 1:42 pm Post subject: Re: What did you do to your Beetle this week? |
65'1300Deluxe wrote: |
After 15 years of sitting next to my folks house, I dragged the carcass of my 65' to my own garage, ready to tackle the bodywork that stalled me out in Highschool! |
Congratulations! Enjoy your bug. It’s never too late to go broke. 😜
That engine looks clean. ✨✨ _________________ 1966 Volkswagen Sedan 1300 (now 1641), 6 volt, L456 Ruby Red, Platinum leatherette. |
65'1300Deluxe Samba Member
Joined: November 24, 2009 Posts: 584 Location: Auburn, Washington
Posted: Sat May 06, 2023 4:38 pm Post subject: Re: What did you do to your Beetle this week? |
Stockholm VW wrote: |
That engine looks clean. ✨✨ |
Thankfully I rebuilt the chassis and engine years ago, it just needs some TLC... and a battery, because I fully intend to drive this thing around with the body off at least once _________________ 1965 Deluxe Beetle "Camilla"
1972 Super Beetle Barnfind "Roland"
2001 GTI 1.8L Turbo |
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2664 Location: Long Island, NY
Posted: Sun May 07, 2023 7:38 am Post subject: Re: What did you do to your Beetle this week? |
Last week I replaced my rear shift coupler and solved an inconsistent hitting 3rd gear issue.
Then, a couple of days ago, during the course of my driving during the day, my shifter felt like rowing through the large economy sized tub of Cool-Whip. I was also able to get reverse without pushing down.
That last part made think of the reverse lockout plate. I have a spare so I changed it. Everything is back to normal once again. Shifting is even tighter now than when I first put in the new coupler.
Before I put the new one in I examined them side by side. Aside from color they don't look any different. Apparently, they wear out, however. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
EverettB Administrator
Joined: April 11, 2000 Posts: 69823 Location: Phoenix Metro
Posted: Sun May 07, 2023 1:23 pm Post subject: Re: What did you do to your Beetle this week? |
They can wear out, especially if they are not greased but the wear is usually very obvious compare to a good one.
Here's 2 styles, both with wear on the right-hand sides
Not the greatest pic but no serious wear on the right side of this one:
_________________ How to Post Photos
Posted: Sun May 07, 2023 10:47 pm Post subject: Re: What did you do to your Beetle this week? |
Thanks, Everett, I saved the old one. The next time I have the shifter out I'll take a closer look at them both.
In other news, I decided to clean up the rust on my original headlight rings using a combination of a wire wheel in my drill (where there was pitting), and 0000 steel wool by hand. I wiped the area I'd be treating with a damp rag before getting on it with either one. Then I dried and waxed them.
They came out fairly spectacularly. I'm gonna remove the aftermarket rings that are on the car now and do those next. Then the bumpers, original to the car. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
mikelars Samba Member
Joined: February 27, 2019 Posts: 238 Location: North Carolina
ryans65 Samba Member
Joined: February 16, 2016 Posts: 1263 Location: Yulee FL
Posted: Thu May 25, 2023 5:19 am Post subject: Re: What did you do to your Beetle this week? |
fixed my dome light, still can't see anything
far rider Samba Member
Joined: August 30, 2005 Posts: 771 Location: Rutland, VT
Posted: Sat May 27, 2023 4:16 pm Post subject: Re: What did you do to your Beetle this week? |
61 replacement tire well. Starting to replace the rusted parts on my 61 ragtop.
_________________ 67 zenith blue sunroof
Contentment; when what you have is what you want. |
VWNate Samba Member
Joined: October 04, 2016 Posts: 357 Location: Sunny So. Cal.
Posted: Fri Jun 02, 2023 7:45 pm Post subject: What Did I Do To My Beetle this week |
I chafed at the cool & damp weather here in So. Cal., I took the engine and tranny out Memorial Day and will be performing a laundry list of "Might As Wells" whilst I replace the tranny's big main shaft bearing .
It's tough to look out the window and see it just sitting there in the rain.... _________________ -Nate
One last Beetle : 1959 #113 DeLuxe survivor ~ 36HP & full synchro tranny, 6 volts etc. |
Posted: Thu Jun 15, 2023 12:01 pm Post subject: Re: What did you do to your Beetle this week? |
The regular stuff:
-Valves adjusted.
-Oil change.
-Transaxle oil change.
-Brakes adjusted.
-Clutch adjusted.
-Steering box adjusted.
The not so regular stuff:
-New starter, starter solenoid, and ignition switch.
-New tail pipes (Lost one on the highway. Searched far and wide... no luck.) _________________ 1966 Volkswagen Sedan 1300 (now 1641), 6 volt, L456 Ruby Red, Platinum leatherette. |
VWNate Samba Member
Posted: Thu Jun 15, 2023 2:41 pm Post subject: Piece By Piece |
I spent most of one day putting the transaxle back into my '59 Bug, over 1/2 the time was spent on 'Might as Wells' and cleaning, de rusting and re painting various this ans that, it's nice to be able to use those 14MM A.T.F. 8X1.25MM nuts and their slightly different washers.....
I've still got lots to do, it turns out I can no longer lay on my back and simply hoist it into place using a creeper . _________________ -Nate
oldslow Samba Member
Posted: Sat Jul 08, 2023 8:59 am Post subject: Re: What did you do to your Beetle this week? |
I made this box from an air cleaner years ago. This weekend I repainted it. All nice and shiny now.
_________________ - better to drive a slow car fast than fast car slow - |
_osb Samba Member
Posted: Sun Jul 23, 2023 11:59 am Post subject: Re: What did you do to your Beetle this week? |
Boris (Gulf Blue 61 Delux model) came to us on Thursday and joins Nutkin (Chianti 71 So67-R Westfalia). Boris is numbers-matching.
Boris’s previous custodian thought he was running on three, which I’m not convinced is correct, but there is a hole in a heat riser, fuel in the sump and some really coked up plugs.
I have carb and fuel pump rebuild kits arriving tomorrow. Once these have been refurbed, I’ll drain and rinse the oil and compression test. |
alex857 Samba Member
Joined: December 26, 2010 Posts: 714 Location: Stuttgart/Germany
Posted: Thu Aug 03, 2023 11:38 pm Post subject: Re: What did you do to your Beetle this week? |
Drove my 1961 ragtop near the sky laser installation celebrating the jubilee of the Trumpf company near Stuttgart.
VWNate Samba Member
Posted: Fri Aug 04, 2023 10:53 am Post subject: Re: What did you do to your Beetle this week? |
Lovely photos ! .
I wish I knew how to take good pix like this . _________________ -Nate
bandi Samba Member
Joined: August 24, 2005 Posts: 1064 Location: Campbellford, Ontario, Canada
Posted: Sat Aug 05, 2023 6:54 pm Post subject: Re: What did you do to your Beetle this week? |
Finally got around to putting hubcap clips on the '60.
Took it into town, noticed when I slowed down that it was misfiring and noisy. Limped it home, found the #4 exhaust valve spring was in three pieces.
I managed to replace the spring using a universal "on the car" spring compressor I've had for 20 years that definitely wasn't designed for a VW. Since taking it to a bench grinder, now it's sort of designed for a VW. She's purring like a kitten again.
Even being down a cylinder and with the noise of the combustion coming straight out the exhaust, it still sounded better than the Harley I got stuck behind on the way home! _________________ '60 Canadian Standard, '64 Bug, another '64 Bug, '66 Bug, '69 Sunroof Bug, '69 GT3 Bug, '71 Super, '72 Super, '73 Canadian Custom, '74 Love Bug, '83 Mexi Bug, '85 Cabrio, '94 Mexi Bug, '99 New Beetle, '02 New Beetle Turbo S, '03 New Beetle VR6. And some Fieros. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9769 Location: Oregon
Posted: Sat Aug 05, 2023 9:29 pm Post subject: Re: What did you do to your Beetle this week? |
Finished my 2276 build Wednesday evening.
AA 82mm forged crank
JPM Ductile iron 94mm cylinders, stuffed with JE forged pistons
Scat 5.7 H beam rods
FK-10 camshaft with Engle lifters
Smith Brothers custom 3/8" chromo PR's
Scat 1.4 rockers
CB Wedgeport heads with 42cc combustion chambers
CB Bigbeef intake manifolds, topped with 48 IDA clones
CB magnaspark distributor
CSP 42mm EVO Comp SS exhaust, dual muffler
12.2:1 CR, race gas only for this build.
Rotating assembly, repaired and balanced @ DPR, Thanks Jose.
A rough estimate of the power on this build, 187HP, 167trq.
Hoping to get the engine installed tomorrow, 8/6/23. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
lhd65bug Samba Member
Joined: September 04, 2020 Posts: 49 Location: United Kingdom
Posted: Mon Aug 14, 2023 3:24 pm Post subject: Re: What did you do to your Beetle this week? |
Fitted a Cornett Sun visor. Once fitted, it made the wiper arms look rusty and shabby, so I refurbed 'em andfinished 'em in silver.
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Wed Aug 16, 2023 12:57 pm Post subject: Re: What did you do to your Beetle this week? |
Took the front wheels off and washed the wheel wells. And what to my wondering eyes should appear?----yellow crayon inspection mark from August, 1965. I stopped cleaning for fear of scrubbing it off.
Posted: Wed Aug 16, 2023 4:23 pm Post subject: Re: What did you do to your Beetle this week? |
The factory inspection code, should stay in place. If you just rinse the fender wells with water.
Use a solvent or soapy spray cleaner, and it will take off the hand written code. _________________ I have learned over the years.
Buy Once, Cry Once!
