sphet Samba Member
Joined: November 09, 2016 Posts: 345 Location: Vancouver, BC
Posted: Mon May 03, 2021 5:28 pm Post subject: Re: Solar panel in the luggage rack |
I love these mounds but they won't work on early luggage carriers.
Sodo wrote: |
This $250 pair is listed as 19.6" and the decal on the item looks very similar to my RNG-100D-SS.
https://www.amazon.com/dp/B01GKB6EAM/ref=cm_sw_em_...&psc=1
The partnumber appears to be HQST-100D-SS
If you could determine somehow that it's truly 19.6"....
And find a friend to buy the other panel.
I'm sure you can find someone if it's the only panel that fits in the Westy cargo area.
This is a total bummer for my buddy Ela who built about 20 aluminum drop-in mounts for the the 19.6" to click into the Westy cargo loops.
SAMBA Classified: Solar clip on mounts for Westy cargo loops |
_________________ 1982 Diesel Westfalia 1.6 NA - The Shellakabuukiee |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9613 Location: Western WA
Posted: Mon May 03, 2021 5:58 pm Post subject: Re: Solar panel in the luggage rack |
What’s different about the early luggage carriers? _________________
....KTMs, GasGas, SPOT mtb |
sphet Samba Member
Posted: Mon May 03, 2021 6:53 pm Post subject: Re: Solar panel in the luggage rack |
Sodo wrote: |
What’s different about the early luggage carriers? |
The mold was a different design. At least I assume my setup is stock. Everything else is. Here’s a terrible photo of my dirty carrier, but you can see the cleats are not on 45 degree chamfered cutouts but flat against the inside of the carrier.
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Mon May 03, 2021 9:13 pm Post subject: Re: Solar panel in the luggage rack |
sphet wrote: |
This early design might accept the 20" wide Renogy "Compact" panel.
The rear and front inside walls are more vertical. Definitely closer to 90° on the rear face.
The later style has them with more of an angle and it is that angle preventing the 20" panel from fitting lower into the rack.
It's hard to tell really from the pictures. I would have to have one in front of me to say for sure. _________________ This free advice is worth exactly what you paid for it.
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Tue May 04, 2021 8:07 am Post subject: Re: Solar panel in the luggage rack |
Interestingly the Amazon.com and Renogy.com panels differ in both specs, Amazon 20.0 Renogy 19.5, and appearances, at the junctions... Just for fun I ordered a panel from each in order to find out for certain. Inquiring minds what to know. And yes one or both of them may go back. _________________ Schau in das Buch |
Posted: Tue May 04, 2021 8:17 am Post subject: Re: Solar panel in the luggage rack |
dgbeatty wrote: |
Interestingly the Amazon.com and Renogy.com panels differ in both specs, Amazon 20.0 Renogy 19.5, and appearances, at the junctions... Just for fun I ordered a panel from each in order to find out for certain. Inquiring minds what to know. And yes one or both of them may go back. |
I'd definitely be interested!
The ACOPower panel is scheduled to arrive next week so hopefully it will be the 19.6"
HQST no longer is showing that panel size on their website. So I'm think the source vendor ran a production run at that size and it's over so the Solar vendors have run out.
Interestingly if there is a source vendor they are all using the Renogy panel I have looks as if Renogy has their name decal under the glass.
I doubt they took an outside vendor panel apart just to put a sitcker on it so maybe the source is just supplying the solar cells and the vendors assemble them. _________________ This free advice is worth exactly what you paid for it.
Posted: Tue May 04, 2021 9:45 am Post subject: Re: Solar panel in the luggage rack |
Funny things you find when you look.
A cargo rack with vertical front and rear insides.
https://www.thesamba.com/vw/classifieds/detail.php?id=2363000 _________________ This free advice is worth exactly what you paid for it.
pjn_wyo Samba Member
Joined: April 22, 2019 Posts: 181 Location: Bellingham, WA
Posted: Tue May 04, 2021 12:33 pm Post subject: Re: Solar panel in the luggage rack |
Ah crap. I have one of Ela's mounts but didn't pull the trigger on the a panel yet.
Interested to see what 19.6 panels show up! |
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Tue May 04, 2021 5:26 pm Post subject: Re: Solar panel in the luggage rack |
For reference, my 4-year-old Renogy compact 100W panel is 19.72" (501mm) wide. To fit it down into my '84 Westy rack it'd mean chamfering a tiny bit at each corner. However, I have it mounted proud of the rack to leave room for the suitcase 100W to be stowed underneath. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Mon May 10, 2021 3:36 pm Post subject: Re: Solar panel in the luggage rack |
https://www.amazon.com/dp/B01G53TUIS?psc=1&ref=ppx_yo2_dt_b_product_details
100W ACOPower panel just showed up - measures 1.4x19.6x42.2 as advertised and drops in to the cargo area.
Sodo - I will check and make sure the panel fits your/Ela's mount later this week - they are in a box somewhere at the shop. |
Posted: Mon May 10, 2021 3:56 pm Post subject: Re: Solar panel in the luggage rack |
Somebody beat me to the posting!
The “dream” panel was not supposed to be here until Wed., but I got a notice that I had a package at the UPS Store.
To my delight, (mainly because I’m a lazy sod that did not want to modify the Luggage Rack to accommodate the 20” panels!) I received this “PowerEco” panel and it fits!
Amazon has it for $89.98
But wait, there’s more!
Renogy 100W Compact @ 21.25 volts
PowerEco 100W @ 23.17
Seems the Renogy is not as good as I thought it was.
BTW, the PowerEco panel has the 25yr Power Output Warranty and 5 yrs. on Material & Workmanship. _________________ This free advice is worth exactly what you paid for it.
sphet Samba Member
Posted: Mon May 10, 2021 4:33 pm Post subject: Re: Solar panel in the luggage rack |
Of course it’s already sold out!! _________________ 1982 Diesel Westfalia 1.6 NA - The Shellakabuukiee |
sphet Samba Member
Posted: Mon May 10, 2021 4:52 pm Post subject: Re: Solar panel in the luggage rack |
Oh thanks! Seller won’t ship to Canada so that’s why it doesn’t show up.
S _________________ 1982 Diesel Westfalia 1.6 NA - The Shellakabuukiee |
Sodo Samba Member
Posted: Mon May 10, 2021 7:06 pm Post subject: Re: Solar panel in the luggage rack |
Good news!!!
19.6 is a good number for Westfalias.
Steve M. wrote: |
Seems the Renogy is not as good as I thought it was. |
Voltage doesn’t tell you much. A 5 watt panel could put out 21 or 23 volts open-circuit.
Better to compare the short circuit amps.
Doesn’t look like that meter reads amps directly but if you short the wires can you sense DC amps?
7 amps is not very much.
But it makes a nice 100 watts at 14.3 volts! _________________
Posted: Mon May 10, 2021 9:02 pm Post subject: Re: Solar panel in the luggage rack |
Sodo wrote: |
Good news!!!
Steve M. wrote: |
But it makes a nice 100 watts at 14.3 volts! |
No, I agree with you. The voltage like that doesn't really tell you much. It's not enough to say "don't buy this panel".
Ya just have to think though- side by side at the same angle to the sun in the same sunlight...why aren't the voltages the same? 🤔😁 _________________ This free advice is worth exactly what you paid for it.
Rorke Samba Member
Joined: August 04, 2016 Posts: 255 Location: Traverse City, MI
Posted: Tue May 11, 2021 11:48 am Post subject: Re: Solar panel in the luggage rack |
Thanks Steve M. Great find. Hoping to get in on the next bracket run. |
stickerbush Samba Member
Joined: September 27, 2013 Posts: 2 Location: Vashon, WA USA
Posted: Mon Aug 09, 2021 7:35 am Post subject: Re: Solar panel in the luggage rack |
I was able to get the 20.1" wide panel to fit by cutting some notches in the frame where it contacts the bracket.
Pascal Samba Member
Joined: January 13, 2006 Posts: 825 Location: Fredericton, NB, Canada
Posted: Wed Feb 16, 2022 5:46 am Post subject: Re: Solar panel in the luggage rack |
stickerbush wrote: |
I was able to get the 20.1" wide panel to fit by cutting some notches in the frame where it contacts the bracket. |
So the only modification you had to make was a notch at the rear of the panel so it would close properly?
Thanks _________________ '84 Westy - 2.2wbx, GT Torque-Biasing Differential
'91 EA Cabby |
