jroymcd Samba Member
Joined: April 18, 2005 Posts: 1053 Location: Bay Area
Posted: Sun May 18, 2008 7:38 pm Post subject: What am I missing? Shift rod guide |
is there a bracket, hanger or something after the shift rod guide on a 60 bus? was told something was missing. what is it called and where can I find one? _________________ www.cultwagen.com
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Sun May 18, 2008 8:00 pm Post subject: |
There is a shift rod tube guide or "hanger" that holds the front end of the front shift rod up. _________________ Don't worry; be happy. (Baba) |
Posted: Sun May 18, 2008 8:02 pm Post subject: |
yeah, thats what I need.
is it hard to find? anyone got a picture of one. how will it affect shifting without it? _________________ www.cultwagen.com |
Campy Samba Member
Posted: Sun May 18, 2008 9:37 pm Post subject: |
The hanger holds the shift rod up and supports it so the ball on the end of the shift lever can go into the cup at the end of the rod. Without a hanger, the shift rod would flop down and the ball on the shift lever wouldn't be in the cup (no shifting). _________________ Don't worry; be happy. (Baba) |
Posted: Sun May 18, 2008 9:44 pm Post subject: |
yeah, the shifter sits kinda high in the cup. the shift rod giude holds it up enough to shift but it makes it very hard to find 1st and 2nd
dont even know what it looks like. _________________ www.cultwagen.com |
dstefun Samba Member
Joined: February 20, 2002 Posts: 3338 Location: Sacratomato
Posted: Sun May 18, 2008 9:50 pm Post subject: |
I have the "E" piece. i was told there is a second hanger that mounts to the body. there is a cross member with a cut out and two holes in it. _________________ www.cultwagen.com |
Posted: Sun May 18, 2008 9:56 pm Post subject: |
jroymcd wrote: |
I have the "E" piece. i was told there is a second hanger that mounts to the body about 5 inches in front of it. there is a cross member with a cut out and two holes in it. |
AFAIK, the other front hanger was only used 1966-67 when they changed the design of the front shift tube. Note bushing "H" in the lower drawing - that mounts in the later front hanger. For 1960 you should just have E & G to support the front tube. |
62Baido Samba Member
Posted: Sun May 18, 2008 9:58 pm Post subject: |
You're looking for this right?
Which connects like this?
_________________ 1962 Kombi Bus - My rolling project!
http://www.norcalaircooledgroup.org/ |
Posted: Sun May 18, 2008 10:05 pm Post subject: |
something should go here?
Posted: Sun May 18, 2008 10:08 pm Post subject: |
I got the guide and a beat up M clip. I was told I was missing something here? its a early bus (60)
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Sun May 18, 2008 10:37 pm Post subject: |
jroymcd wrote: |
Nothing goes there. |
Posted: Sun May 18, 2008 10:40 pm Post subject: |
than whats this? found the pic in the gallery
Posted: Sun May 18, 2008 10:47 pm Post subject: |
jroymcd wrote: |
Same thing as yours, except it's a '59 & earlier bus so the forward shift guide is moved back ~ 6" further than yours. |
quartermilecamel Samba Member
Posted: Sun May 18, 2008 10:57 pm Post subject: |
I need the bushings that hold the "N" rod at both ends. Or I just need to redesign better less friction ones |
here is my shifter with guide behind it. pin sits very high and the whole thing seems to kind of twist when you try to get 1st. is this normal? the shift coppler seems good.
