GLHTurbo Samba Member
Joined: March 30, 2009 Posts: 1376 Location: New Jersey
Posted: Wed Mar 16, 2011 9:36 am Post subject: |
thanks! I actually have one for my oval, gonna steal it for the bus _________________ 1957 Beetle
1966 Bus |
angus_hanger Samba Member
Joined: July 20, 2002 Posts: 139 Location: Pinole, CA
Posted: Wed Mar 16, 2011 9:52 am Post subject: |
Mine is completely missing ... <adds 111 721 529A to shopping cart> _________________ His - 'Rosie' - '64 Westy
Hers - '66 Beetle
SST '04 -'06
"Why yes sir, Sheriff, I do like Fat Chicks." |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Wed Mar 16, 2011 9:57 am Post subject: |
GLHTurbo wrote: |
My throttle cable does not have a "hook" on one end, it is a solid circle.
Has anyone used a M6 bolt and nut to secure this to the lever? Or a clevis pin? If so, do you know the sizes I need to get?
Thanks |
Take the cable and lever to the hardware store, find a bolt that fits through the hole, find a nylock nut for it, go home and install it. Make sure to use grease on the pivot points. _________________ nothing |
redbug64 Samba Member
Joined: July 21, 2005 Posts: 513 Location: Fairfax/Essex, Vermont
Posted: Mon Mar 28, 2011 3:32 pm Post subject: |
Does anyone have a picture of how the gas pedal return springs are supposed to be installed? (The thin L shaped flat pieces of metal) Do they just jam under the hinge and against the floor? _________________ Jason Arms
Fairfax, Vermont
1954 Standard Beetle
1965 Firetruck Red Double Cab
1975 Porsche 911
1984 Rabbit L
1988 Scirocco 16v
Random Toyota daily drivers because winter. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
don.ville Samba YardMan
Joined: February 07, 2008 Posts: 2829 Location: West Palm Beach, FL
Posted: Mon Mar 28, 2011 9:56 pm Post subject: |
redbug64 wrote: |
Does anyone have a picture of how the gas pedal return springs are supposed to be installed? (The thin L shaped flat pieces of metal) Do they just jam under the hinge and against the floor? |
It's not really a return spring (the spring at the carb does that)
It's job is to make sure the hinge pin does not slide out.
The hing pin has a flat or narrower section in the middle for this leaf spring to sit in.
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
Posted: Mon Mar 28, 2011 10:07 pm Post subject: |
bill may wrote: |
you need part number 111 721 529A from wolfsburg west. the accelerater cable hooked end goes on this stud instead of hooking into L piece like that other guy (don.ville) did it wrong. $7 each.
111 721 529A That don't look like a bus part? Says it's for a Beetle pedal.
I had to go look this up, but for my 67 according the the Bentley book I don't use such a part...
Funny how Bently also shows L bracket inside the 'J' shaped bracket
I would just cut the loop near the end to make an opening for the cable to attach to the L bracket.
See the accelerator cable for my bus has the opening when new...
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211721555C _________________
Posted: Mon Mar 28, 2011 10:49 pm Post subject: |
EverettB wrote: |
The cable attachment was changed Nov. 4, 1960, VIN # 678 336
Accelerator cable
Now: Cable eye hooked directly
into the hole in pedal lever.
Formerly: Secure with bolt,
washer and cotter pin. |
There you have it. (I can only really speak for my bus, since I don't have the experience/wisdom from having many diff year buses.
Less parts, newer, better ?
Posted: Tue Mar 29, 2011 5:19 am Post subject: |
don.ville wrote: |
EverettB wrote: |
Accelerator cable
I dont have a pic handy of my cable end, but its beefy almost cast like - not just a complete circle of your version, even if I cut a slot it in, it still wouldnt hook into the hole, unless I made a giant hole. For the record, a M5 bolt fits the hole in the WW bracket perfectly, I bought the shortest length Lowe's had. I put a washer on the head side, and the nut side, with nylock nut. Good enough for now I suppose. _________________ 1957 Beetle
1966 Bus |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Tue Mar 29, 2011 5:44 am Post subject: |
EverettB wrote: |
Accelerator cable
in photo you posted of your 1961 it shows this part being used. is your 61 produced prior to nov 4,1960??
my 58 has it on it. my 65 had it ,so i put it back on. just wondering.not fighting about this,yes i have a 63-67 bentley. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2078 Location: Bulli Klinik, Colorado Springs
Posted: Tue Mar 29, 2011 7:23 am Post subject: |
59 Panel. Hole relocated for more throw at the carb linkage. Spring added for more snap at the pedal. Shimmed at the bracket so it doesn't wiggle. Washers welded to the pushrod so it doesn't slip through. Works perfectly!
Posted: Tue Mar 29, 2011 7:35 am Post subject: |
COBussmuggler wrote: |
nice picture. i guess vw stopped using the extra piece to save money. _________________ Admin note: Bill Passed away - July, 2017
www.sv2s.com
SBS #100
Posted: Tue Mar 29, 2011 7:38 am Post subject: |
don.ville wrote: |
bill may wrote: |
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211721555C |
i sincerly apoligize to you for saying you did it wrong. _________________ Admin note: Bill Passed away - July, 2017
www.sv2s.com
SBS #100
Posted: Tue Mar 29, 2011 8:53 am Post subject: |
bill may wrote: |
EverettB wrote: |
Accelerator cable
my 58 has it on it. my 65 had it ,so i put it back on. just wondering.not fighting about this,yes i have a 63-67 bentley. |
Yes, it's an August Bus. Super early '61.
To add another data point, the pin is pictured in my '59 shop manual. _________________ How to Post Photos
Posted: Tue Mar 29, 2011 9:48 am Post subject: |
bill may wrote: |
i sincerly apoligize to you for saying you did it wrong. |
OK, I'll put away the Kleenex .....
SkooobaSteve Samba Member
Joined: March 23, 2005 Posts: 3152 Location: Dothan Alabama
Posted: Tue Mar 29, 2011 3:10 pm Post subject: |
sweet thanks guys! _________________ Jason Arms
Fairfax, Vermont
1975 Porsche 911
1984 Rabbit L
1988 Scirocco 16v
2Pack Samba Member
Joined: September 20, 2005 Posts: 807 Location: Virginia
Posted: Tue Mar 29, 2011 6:11 pm Post subject: Accelerator pedal linkage and hardware |
Another vote for the side mounting.
October 1960 Single Cab with ~43k miles.
Original hardware. 1 month before the change in how the cable attaches to the L bracket.
