nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Wed Jun 01, 2016 6:18 pm Post subject: Re: Gas pedal linkage - parts and installation |
panel wrote: |
Is the push rod from pedal to lever straight or does it have a bend in it at all other than the two 90deg at either end ? |
Straight I believe.
panel wrote: |
Also is/does the lever under the bus have a 90deg 'V' shape to it or or are some less/more of and an angle ? |
55-67 are darn close to an "L" shape
68 - 79 Bay buses are a more pronounced "V" shape |
EverettB Administrator
Joined: April 11, 2000 Posts: 69823 Location: Phoenix Metro
Posted: Wed Jun 01, 2016 10:59 pm Post subject: Re: Gas pedal linkage - parts and installation |
nlorntson wrote: |
panel wrote: |
Straight I believe.
panel wrote: |
Yes, straight and 90 degree ends.
From earlier in this thread
_________________ How to Post Photos
edgood1 Samba Member
Joined: September 30, 2004 Posts: 2049 Location: Plymouth, MA
Posted: Mon Apr 22, 2019 4:39 am Post subject: Re: Gas pedal linkage - parts and installation |
Can someone point me in the direction of which is the correct boot/seal for the accelerator cable on a '63 bus?
Its #70 in this diagram, part number 111-721-551
The closest thing I could find is the bay window version but I don't know what the correct one is supposed to look like. _________________ 1987 Syncro Westfalia powered by Subaru
'65 Westfalia |
Posted: Mon Apr 22, 2019 11:09 am Post subject: Re: Gas pedal linkage - parts and installation |
ah ok. what I'm looking for is the little black boot that seals the steel tube that the cable goes through at the front of the bus. My new throttle cable has a little nipple on it for one (maybe I have the wrong cable). I figured there has to be some kind of seal there to prevent crud from getting into that cable tube. _________________ 1987 Syncro Westfalia powered by Subaru
'65 Westfalia |
Chuey Samba Member
Joined: October 18, 2010 Posts: 858 Location: Oceanside, California
Posted: Sun Apr 04, 2021 8:01 pm Post subject: Re: Gas pedal linkage - parts and installation |
Hello there, dragging an old thread into the light.
I recently saw an advertisement for an accelerator pedal/cable link that goes under the floor. It was a stout affair and was made by an aftermarket company in the UK. It had a sealed pivot bearing.
This link looks to be very nicely made. But, I can’t remember the name of the company or where I saw it.
Anybody out there know what it is that I saw? I would like contact info so I can order one. I will write a report when I get one.
Thanks, Chuey |
Mile High Puma Samba Member
Joined: November 11, 2009 Posts: 212 Location: Salida, Colorado
Posted: Sun Apr 04, 2021 8:15 pm Post subject: Re: Gas pedal linkage - parts and installation |
Buttys Bits _________________ 1965 Velvet Green DC |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Two Glove Boxes Samba Member
karl h Samba Member
Joined: October 10, 2005 Posts: 578 Location: austria
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Wed Apr 14, 2021 8:44 am Post subject: Re: Gas pedal linkage - parts and installation |
looks groovy, but does it work a million times better than a stock set-up (with added spring for comparison; I think a spring can be added to a stock set-up easily)? _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Wed Apr 14, 2021 8:55 am Post subject: Re: Gas pedal linkage - parts and installation |
tisius wrote: |
looks groovy, but does it work a million times better than a stock set-up (with added spring for comparison; I think a spring can be added to a stock set-up easily)? |
Night and day difference. easily the best aftermarket part out there. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
kafer60 Samba Member
Joined: January 17, 2005 Posts: 363 Location: Fredericksburg, Va
Posted: Wed Jul 20, 2022 6:29 pm Post subject: Re: Gas pedal linkage - parts and installation |
Bring up another older thread, I went out and looked at my 67 westy this evening the the L linkage is on the outside of the bracket. Just my .02 |
dlicious Samba Member
Joined: September 07, 2006 Posts: 245 Location: Spring(pronounced Sprang), TX
Posted: Sat Jun 03, 2023 6:21 pm Post subject: Re: Gas pedal linkage - parts and installation |
My J bracket is breaking at the pivot hole. It is one wiggle away from becoming two pieces.
What is the best way to fix this? There isn't a lot of room in the area to work. _________________ '63 Caravelle Camper
dLk |
Posted: Sat Jun 03, 2023 10:06 pm Post subject: Re: Gas pedal linkage - parts and installation |
dlicious wrote: |
What is the best way to fix this? There isn't a lot of room in the area to work. |
Are you referring to the J shaped channel with the bolt through it in this photo? If so, you need a welder.
_________________ nothing |
Posted: Sun Jun 04, 2023 8:15 am Post subject: Re: Gas pedal linkage - parts and installation |
cdennisg wrote: |
Yes, thats it. Ill post a picture up this afternoon when I take the linkage apart and clean it up to see what exactly is going on. _________________ '63 Caravelle Camper
dLk |
Posted: Mon Jun 05, 2023 4:22 pm Post subject: Re: Gas pedal linkage - parts and installation |
Pics as promised....
It split right across the hole. Previous owner had done some work on this as I remember. I installed the Butty's Bitz linkage about 7 years ago and love it.
Fast forward to last weekend wondering why I'm having binding and the carb linkage not returning fully to idle.
I took a dremel and cleaned everything up.
I'm waiting for my new welding helmet to show up and then I'll put a tack on each side of the hole. Needle nose pliers holds it in place nicely for the hot work.
dLk |
Bad Hippie Samba Member
Posted: Tue Jun 27, 2023 9:39 pm Post subject: Re: Gas pedal linkage - parts and installation |
Just popping in to say thanks for those who contributed to this thread. It was incredibly helpful. I finally got a repair kit to help correct shoddy repairs from 20 or so years ago. I can't believe this pile of soap metal heald together and even seemed to function ok, for that long.
Here are a few before and after photos.
Before. Note the nail that has bee holding thing together since my broth in laws, dad "fixed" it about 20 years ago.
My scrap pile. I may bag it up and hang it in the shop as a reminder to not ignore things so long even if they seem to get you by.
Old VS New
Final install. L arm correctly mounted on the outside of the J bracket.
I've still got some work to do before I can hit the road again, but hand operation feels much better.
Thanks again to all! |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14266 Location: Casa de Oro, California
Posted: Wed Jun 28, 2023 6:23 pm Post subject: Re: Gas pedal linkage - parts and installation |
Sanitary.
What year is your bus as your shifter looks like '66-'67 style. |
