52brezelfenster Samba Member
Posted: Wed May 21, 2008 10:48 am Post subject: Lowlight body to heater box connection |
Hi,
What did low lights (specifically in 58/59) use originally when connecting the heater boxes to the body?
I've seen 2 different flavors. One is a flexible plastic tube that connects connects the two.
The other is a paper tube and a round canister (canister on towards attached towards the body side) and I think the canister is for noise reduction?
Thanks! |
Posted: Wed May 21, 2008 1:23 pm Post subject: |
Ah?
This sounds confusing to me...?
The earlier engines (pre 40 horse) with stale air heating systems usually have a flexible metal tubes connecting them to the body. Inside under the rear seat were some canister baffles that are sorta' clam shell like with metal tabs holding the top to bottom. _________________ jeff
http://www.revolks.com/ |
thom Samba Member
Joined: October 12, 2000 Posts: 5943 Location: Sacramento
Posted: Wed May 21, 2008 3:01 pm Post subject: |
The paper tube sounds like a hack.
The correct connector is a flexible metal tube made of spiraled steel, with an insulated vinyl cover. This connects to the small 'mufflers' which in turn connect to the body. Keep in mind we're talking about the bits on the outside of the car, forward of the engine.
CIP1 et all sell a ribbed plastic tube with fiberglass insulation inside. These pieces are much longer, so you would need to remove the heater muffler. _________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
Posted: Thu May 22, 2008 7:56 am Post subject: |
Thanks,
That's a perfect description. I have the 2 canisters, in perfect condition. Just need to find those steel / vinyl covered tubes to keep her original. |
JeffL Samba Member
Posted: Fri May 23, 2008 9:43 am Post subject: |
Did they always have the covers? My 56 was pretty original with 65,000 miles on it and there were not any covers on my flex tubes. Maybe they fell off. |
pbaptist Samba Member
Joined: January 02, 2005 Posts: 1204 Location: Netherlands
Posted: Fri May 23, 2008 10:14 am Post subject: |
Does someone has a picture about what we are talking?
Is it the round things shown here on this picture?
Patrick _________________ Dutch Karmann-Ghia and coachbuild lover.
1* Karmann Ghia Coupe (1966 Teak)
2* Karmann Ghia Convertible (1958, 1971)
4* Rometsch Lawrence (nr 534, 555, 558 and 561)
Karmann-Ghia Lowlight page and registry
Karmann-Ghia Collectibles database |
lonotch Samba Padrino
Joined: August 28, 2004 Posts: 3303 Location: So. Cal. Oceanside GFK!
Posted: Fri May 23, 2008 5:38 pm Post subject: |
pbaptist wrote: |
Patrick |
No Patrick, those canisters are in the interior under the backseat/stow area.
My 59 had no inslulated vinyl cover around them either, maybe a cold climate part? _________________ It's not about the window, it's about the people.
German Folks |
theghiagirl Samba Member
Joined: February 15, 2004 Posts: 537 Location: Near Portland, OR
Posted: Fri May 23, 2008 7:11 pm Post subject: |
[quote="lonotch"]
pbaptist wrote: |
Patrick |
I don't think so. You should be able to see these canisters when looking under the car. The only thing you'll see under the seat is the pipes that go to the heater tunnel(rockers).
The only tubes that I've seen covered with insullation are the ones that I've seen in Oval windows. I think these Oval window metal tubings are the same diameter as the Karmann Ghia tubes, but you'll need to cut them shorter to fit the Karmann Ghia.
Rich Kimball (Ovals Only) has these tubes available. |
Posted: Fri May 23, 2008 7:13 pm Post subject: |
theghiagirl wrote: |
DOH!, I was thought I was looking at something else. _________________ It's not about the window, it's about the people.
German Folks |
Posted: Fri May 23, 2008 7:15 pm Post subject: |
That's O.K. |
Posted: Fri May 23, 2008 7:28 pm Post subject: |
Here's a picture of the tube on my 1959 cabriolet. |
Posted: Fri May 23, 2008 7:29 pm Post subject: |
That is the same tube as on my 59. _________________ It's not about the window, it's about the people.
German Folks |
JeffL Samba Member
Posted: Sat May 24, 2008 2:00 pm Post subject: |
As you can see on the 56 there is no "silencer" under the car or under the back seat. Just one lone pipe. Another VW improvement towards more enjoyable driving. I don't have my records with me but this should follow the Beetle time line.
thom Samba Member
Posted: Sun May 25, 2008 7:34 pm Post subject: |
I think you're just missing yours...
JeffL wrote: |
1956 Single Cab
1963 Unimog 404
1965 E-Type |
JeffL Samba Member
Posted: Tue May 27, 2008 6:19 am Post subject: |
thom wrote: |
JeffL wrote: |
See what happens when you take something apart 13 years ago |
JeffL Samba Member
Posted: Tue May 27, 2008 6:22 am Post subject: |
When was the silencer moved under the back seat of the Karmann Ghia?
Maybe at the same time the kick board was added to enclose the area under the front seat. |
Posted: Tue May 27, 2008 8:41 am Post subject: |
Great shot Lisa! Thanks for sharing. |
villemi Samba Member
Posted: Sat Feb 17, 2018 11:47 am Post subject: Re: Lowlight body to heater box connection |
I have a 57 karmann ghia
I 've no silencer under the back seat.
I had this part between the engine and the body.
But i think that it's not the part for a 57 ghia.
is it this one ?
Or this part ?
I think that it is the last part but I'm not sure
Where do you find it ? |
Posted: Sat Feb 17, 2018 1:02 pm Post subject: Re: Lowlight body to heater box connection |
Yes, it is the last part that is correct for a 1957 karmann ghia _________________ Dutch Karmann-Ghia and coachbuild lover.
Posted: Sat Feb 17, 2018 1:12 pm Post subject: Re: Lowlight body to heater box connection |
Where do you find this part ?
What is the part number ?
Is it the same part than early bus mufflers ? |
