Williamtaylor33 Samba Member
Joined: September 07, 2007 Posts: 1545 Location: Arkansas
Posted: Fri May 23, 2008 9:12 am Post subject: Lost keys for a vanagon |
I have lost the keys to my vanagon. And i have looked everywhere!
Now i need to move it and the steering wheel is locked.
Is there anyway to unlock the steering wheel w/o a key?
And more importantly how the heck do i go about getting a new set of keys? _________________ 89 Bostig powered syncro westy |
Wellington Samba Member
Joined: September 21, 2004 Posts: 1890 Location: Montreal
Posted: Fri May 23, 2008 9:35 am Post subject: |
Well it sounds like you have a door open, yes?
Remove one of the door handles and the key code is stampped on the hande. Hope your ignition is the same key, then you are good to go. Otherwise you will need to remove the ignition cylinder for that code as well. The dealer can cut a key from the code as well as a good locksmith. |
Posted: Fri May 23, 2008 10:00 am Post subject: |
[quote="Wellington"]Well it sounds like you have a door open, yes?
quote]
Yeah all the doors are open.
This is a project van so it isnt like i need keys just to get to work or something. _________________ 89 Bostig powered syncro westy |
Posted: Fri May 23, 2008 11:09 am Post subject: |
The screw that holds the door handle on is hidden under the rubber of the door gasket. Kind of a PITA, you can just stick a screwdriver through the gasket to access it. |
danfromsyr Samba Member
Posted: Fri May 23, 2008 11:50 am Post subject: |
i leave the keys in my project vans/cars. it's ough e'nuff to keep track of the keys in all my plated cars.
of course the projects don't run w/o battery, and i've no kids around the yard curious to keys.. _________________
Abscate wrote: |
Posted: Fri May 23, 2008 11:58 am Post subject: |
danfromsyr wrote: |
of course the projects don't run w/o battery |
This project doesnt run w/o an engine!
Thanks Wildthings and Wellington
I'll give that a whirl and try to get another key made. _________________ 89 Bostig powered syncro westy |
devesvws Samba Member
Joined: January 05, 2004 Posts: 1540 Location: madison va
Posted: Fri May 23, 2008 3:52 pm Post subject: |
its the pass side that has the number on it. take it to a modern locksmith. should be no more than $75 to look up the code and cut a key if they have the blank. |
