carcrazed Samba Member
Posted: Mon May 26, 2008 10:05 am Post subject: 1.5 quart or 3 quart oil sump....which one for the price |
Since my hellish parade today...I realize that I need a sump to help cool the oil. I don't have anything on now but the stock case, but am going to buy one. I would like to get the 1.5 quart due to the price difference from the 3 quart. I am running a 1776cc, dual Kadrons, 110 cam. With this engine set-up... do you guys think a 1.5 quart will do me ok? Thanks _________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
pastevensonjr Samba Member
Joined: February 07, 2008 Posts: 22 Location: Omaha, Ne
Posted: Mon May 26, 2008 10:26 am Post subject: |
the 1 1/2 qt will do just fine but if you are hitting higher RPMs and maybe doing some highway time now that gas is almost $4 around the country, the 3 qt will hold a little extra insurance. A little more pricey now but even with the 1776 your still going to get better gas mileage than that dodge durango in the neighbors front drive, so put a little more love into the car. _________________ Phillip Stevenson
Bellevue (Offutt AFB), Ne
1970 Beetle Autostick
<embed></embed> |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Mon May 26, 2008 11:32 am Post subject: |
That engine combination should not overheat. Find the overheating problem. Then worry about the sump. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Ann Mezger Samba Member
Joined: October 13, 2003 Posts: 933 Location: Delaware
Posted: Mon May 26, 2008 12:02 pm Post subject: |
Adding the deep sump will give you more capacity for oil which will deter oil starvation, however if you're having issues with over heating, it will not cure the problem. You need to figure out why it's running hot & resolve that problem. As far as capacity, having the 3 qt. sump will not hurt, but the 1.5 would be fine. _________________ www.vintageperformance.net |
Posted: Mon May 26, 2008 1:13 pm Post subject: |
I guess i missed the overheating. You wouldnt happen to have a misplaced oil cooler on the engine do you. I saw a post earlier today with a cooler just in front of the dog house and the guy couldnt figure out why it was overheating.
Also, what is your indication of overheating? _________________ Phillip Stevenson
<embed></embed> |
Mongo63 Samba Member
Joined: February 15, 2007 Posts: 1358 Location: prison city, IL
Posted: Mon May 26, 2008 1:19 pm Post subject: |
Either sump is good, but realize some 3 qt sumps sacrifice ground clearance to some degree or another. Fine for a stock height car if you're careful but can be catastrophic on a lowered ride with a schmaltz at the wheel... or so I've heard. _________________ Southside Buggistas VW & kit car club
www.southsidebuggistas.com
Mongo only pawn in game of life...
mharney wrote: |
Behold the true power of the extractor! Mongo has it right! |
Posted: Mon May 26, 2008 3:02 pm Post subject: |
thanks....yes....I am going to have to replace the oil cooler, but I am now going to go with the 1.5 qt. thanks everyone. _________________ 1965 Herbie Replica. 1776cc dual Kads.
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
