goffoz Samba Member
Posted: Wed May 28, 2008 10:11 pm Post subject: Rearmounted swing out tire carrier...reinforcement? |
I've stepped up to 16"s and need a place for the spare.
So have any of the guys, who have built a rear mount tire carrier for their syncro....taken any pics of the body reinforcements, you added ?
I am probably going to use a Bronco hinges...modified (I have one in my boneyard)..but I want to swing it from the drivers side...so I may, or may not use the carrier itself....might be easier to just fab that part
I was hoping to put all the reinforcement inside the pillar, just to keep it neat.
but I'm not sure just where and how to tack it all together.
Sort of like Eric's "Bundewehr" GL syncro project
Any good thoughts welcome
Thanks
Tristar Eric Samba Member
Joined: July 25, 2004 Posts: 1242 Location: Portland, Or
Posted: Wed May 28, 2008 10:36 pm Post subject: |
I added backing plates when I mounted my Bronco II tire rack. They're about the same size as the hinge blocks. No issues so far, it's been over 2 years with some pretty heavy abuse, lots of bumps, rocky roads... and to add, I run Michelin XCL military tires with Eurovan 16" steelies which weigh quite a bit. _________________ Vanagon/Transporter flares here: www.terrawagen.com
[email protected] |
goffoz Samba Member
Posted: Wed May 28, 2008 10:56 pm Post subject: |
Hi Eric.
Simple backing plate..easy..about 1/8" plate steel or heavier?
Did you use the bronco latch, on the rear hatch?..
I don't see the green machine listed anymore....does it have a new home |
johnny5 Samba Member
Joined: December 01, 2006 Posts: 9 Location: Ft Worth Texas
Posted: Thu May 29, 2008 6:33 pm Post subject: |
i made mine from an 86 blazer rack. i made hinges out of 1.25 inch angle iron i also put the same angle piece behind the sheet metal for bracing. mine swings out on pass side. i will try and get some pics
jonathan |
tii Samba Member
Posted: Fri May 30, 2008 5:46 pm Post subject: |
Just as FYI, I was able to put 16inch wheel under the nose. have 215/65r16 tires that are 27inch in diameter - they just fit. I could not use the stock spare tire tray tho, so I made a sling from steel cable, seems to work. |
goffoz Samba Member
Posted: Sun Nov 24, 2013 11:24 pm Post subject: |
Finally got some bandwidth time to share |
goffoz Samba Member
Posted: Sun Nov 24, 2013 11:28 pm Post subject: |
The latch..rock solid rattle proof..easy to use
and yes that is cutting board in the bump/stops..equal triangles, I can rotate them as they wear |
canasync Samba Member
Posted: Mon Nov 25, 2013 10:41 am Post subject: |
What kind of rack is that? How does the latch mechanism work? _________________ 1987 Syncro
3 knobs
PumpeDüse TDI (17mm Garret Turbo, bigger injectors, stage 4 malone tune, intercooled)
Cruise Control
Remote Start/locks
Custom Lift
Custom Bumpers with receivers
Coast Mountain Hightop - Comming Soon
1985 2wd Vanagon Pre-runner in the making
soon to be powered by 2.5L Subaru
Custom Lift |
goffoz Samba Member
Posted: Mon Nov 25, 2013 11:07 am Post subject: |
canasync wrote: |
What kind of rack is that? How does the latch mechanism work? |
Home built,
I don't have a heavy tube bender so most of it is a70's GMC bullbar I cut up and repurposed.
The latch works by pulling the 2 knobs together, to release it. works like a really strong doubled door latch,
To close it just swing it closed Thunk,click,click, your done
I've used this design before, and it never lets go
All the tire load is carried on the uhmw pads..there is a substantial support plate inside that all bolts too |
goffoz Samba Member
Posted: Mon Jun 02, 2014 7:18 pm Post subject: |
Added a stop and lock to the carier, borrowed these parts from the "trooper"
rack. new paint(herculiner rattle pack..very happy with this project
[img][/img] |
buspor63 Samba Member
Joined: February 17, 2005 Posts: 1179 Location: Knoxville,TN Where America stops for gas
Posted: Tue Jun 03, 2014 7:32 am Post subject: |
That is alot of good looking DIY stuff there. _________________ Imagine that, theres not an "h" in either Westfalia or Syncro? |
