alansvwTwinCab Samba Member
Joined: December 28, 2005 Posts: 164 Location: Sydney, Australia
Posted: Wed Apr 26, 2017 10:25 pm Post subject: Re: Tire wheel and suspension thread |
ET 55 will set the Wheel back so more clearance at the front (guard edge)
Use this link to work it out.
https://www.rimsntires.com/specspro.jsp |
xzener Samba Member
Posted: Wed Apr 26, 2017 10:30 pm Post subject: Re: Tire wheel and suspension thread |
Thanks for the help rickpereira. So I'd be better off with a 2" narrowed with ET55 than?? If YOU went with a 4"... That would give you an inch more clearance, but even less turning radius??
Ugh! About to purchase a beam... But every time I read up on it, I get even more nervous about limiting my options. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
rickpereira Samba Member
Joined: May 25, 2010 Posts: 330 Location: Sydney, AUstralia
Posted: Wed Apr 26, 2017 10:50 pm Post subject: Re: Tire wheel and suspension thread |
yes less turning radius because the 7in wide wheels would foul on the inside. its a big balancing act..
start off with standard beam, narrow 2in, add drop spindles.. end up almost back where, you started.. see where im going? its sometimes is trial and error and then trying to work around what you want |
xzener Samba Member
Posted: Wed Apr 26, 2017 10:56 pm Post subject: Re: Tire wheel and suspension thread |
Thanks rickpereira... Have Empi drop spindles already. Those push out 1/4" from stock I believe. After looking at your rim, I again question my choice in rims. LOL! So indecisive.
Your brakes are stock with X-drilled 5X130 disks?? Looks great by the way.
All in all, are you pleased with the results of your front end? Would you have gone narrower on the beam if you could go back and do it all over again? _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Wed Apr 26, 2017 11:04 pm Post subject: Re: Tire wheel and suspension thread |
thanks man, yes the brakes are stock replacements. i wouldn't change a thing about it, it turns well, doesn't rub and handles great. i wouldn't have gone narrower either, i like that the wheel doesn't tuck in too much. just enough to give it the clearance it needs. |
xzener Samba Member
Posted: Wed Apr 26, 2017 11:12 pm Post subject: Re: Tire wheel and suspension thread |
Thanks again. Glad to hear it. Will start off with rotor and rim, make measurements and go from there. Hopefully, the short axle swap I just did in the rear will house whichever rim I choose without issue... But we all know that isn't certain either. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Wed Apr 26, 2017 11:13 pm Post subject: Re: Tire wheel and suspension thread |
Thanks alansvwTwinCab. That link will come in handy for sure. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
onezero Samba Member
Joined: September 14, 2005 Posts: 42 Location: Marquette, Michigan
Posted: Fri May 05, 2017 9:51 pm Post subject: Re: Tire wheel and suspension thread |
Hi
My buddy just bought a '73 Sports Ghia and wants to swap out the 4.5 x15 sport rims with the Sports bug 5.5 x 15 (26 mm ET rims.
Will that work on a stock '73 Ghia depending on the tires you put on them?
Not sure how that works with the disc brake set up.
Any advice is appreciated.
Shawn |
pablovent Samba Member
Posted: Thu May 18, 2017 1:57 pm Post subject: Re: Tire wheel and suspension thread |
Hi Guys;
Any experience installing Empi GT-5 (15x5.5 inch, 4" backspace +20 offset) in a stock Ghia 1958?
Best. |
rachawitw Samba Member
Posted: Wed May 31, 2017 7:58 am Post subject: Re: Tire wheel and suspension thread |
Gents,
Would a 15" x 5", 2.5" BS wheels fit under the rear for a 1967? Thanks. |
Sofia74 Samba Member
Posted: Wed May 31, 2017 4:43 pm Post subject: |
Shorrock wrote: |
All Stock:
Amen brother. Looks awesome. |
hylomatt Samba Member
Posted: Wed Jun 21, 2017 3:20 pm Post subject: Re: Tire wheel and suspension thread |
Could I get some opinions on the ride height / stance of my Ghia? It's a 66 and the PO put a 1600 dual-port in it. In my opinion, it rides low in the rear but I'm wondering if it also rides too high in the front. The goal here is stock.
i know the ghia is supposed to have a 6" ride height. where is this measured from? the frame, pans, nose and tail, etc. |
c21darrel Samba Member
Posted: Wed Jun 21, 2017 7:12 pm Post subject: Re: Tire wheel and suspension thread |
yes ok good. so how can i get a correct measurement by which to adjust the front and rear height? preferably, something that isn't dependent on if fenders have been changed or bumper is shifted up/down, etc. maybe the 4 corners of the floorpans? or front beam and bottom of engine?
also, the cal rubber is the PO's fault. it'll be changed soon.
and the wheels are black because the ghia paint codes archive material said so.
Wheel disc, rim L 41 black
did i misunderstand the archive data? |
xzener Samba Member
Posted: Wed Jun 21, 2017 7:15 pm Post subject: Re: Tire wheel and suspension thread |
The rear spring plates can be adjusted to get it back to stock height. Does the front have an adjustable beam? _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Wed Jun 21, 2017 7:16 pm Post subject: Re: Tire wheel and suspension thread |
i was thinking about whether it was adjustable. i realized i don't know how to tell the difference. it looks stock to me. |
Posted: Wed Jun 21, 2017 7:24 pm Post subject: Re: Tire wheel and suspension thread |
ok i just went outside and checked. what i saw vs what all the adjustable beams look like online, i would say definitely not. no adjustability in my beam.
PO put gas shocks all around and disc brakes on the front but they are stock spindles. |
Posted: Thu Jun 22, 2017 12:11 pm Post subject: Re: Tire wheel and suspension thread |
@c21darrel - Ha! I was going to say that last night. I'm missing something subtle I guess. Can you explain please? I see the beauty rings. But what else are you talking about?
As for the shocks it's gas adjust for all four. I'll pull the shocks off of the front and see if it sits any lower. That'll let me know if the shocks are causing it. I mean to get oil shocks all around soon. As for the rears, I'll most likely need to do the torsion bar adjustment. |
Posted: Thu Jun 22, 2017 1:45 pm Post subject: Re: Tire wheel and suspension thread |
I also have a feeling when the PO put the 1600 engine in there he didn't adjust for the difference in weight between that and the 1300. |
