suebug Samba Member
Joined: April 13, 2006 Posts: 1152 Location: The OC, SoCal, with my olympic cats
Posted: Wed Jun 04, 2008 5:34 pm Post subject: Brake lights make 9 pin box click? |
I hear a click that I think is coming from the 9 pin box every time I step on my brakes. Only one click. Is it supposed to do this? (Yes, I already did a search.) I just recently had a NOS turn signal switch installed. _________________ '67 Beetle
'67 Squareback
'66 Sundial
'60 Single cab
'70 Bitchen 3-speed Schwinn |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
suebug Samba Member
Posted: Thu Jun 05, 2008 5:35 am Post subject: |
Duh, I figured that part out myself. Care to elaborate on what could be wrong? _________________ '67 Beetle
'67 Squareback
'66 Sundial
'60 Single cab
Posted: Thu Jun 05, 2008 5:57 am Post subject: Re: Brake lights make 9 pin box click? |
suebug wrote: |
I hear a click that I think is coming from the 9 pin box every time I step on my brakes. Only one click. Is it supposed to do this? |
is it a NOS SWF or wolfsburg west or other reproduction t-switch? is this the early 67 standard bus or the 66 sundial? both use 9 pin box. will it be at octo? _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
suebug Samba Member
Posted: Thu Jun 05, 2008 9:05 am Post subject: |
NOS, not a reproduction. The '66 Sundial. It will be at OCTO. Why? _________________ '67 Beetle
'67 Squareback
'66 Sundial
'60 Single cab
Andrew Samba Member
Joined: October 27, 2000 Posts: 5865 Location: Who in the what now?
Posted: Thu Jun 05, 2008 9:27 am Post subject: |
Do the brake lights/turn signals/hazards/everything work? If so, then does it really matter that the relay clicks when you step on the brakes? _________________ -Andrew |
suebug Samba Member
Posted: Thu Jun 05, 2008 10:19 am Post subject: |
Andrew wrote: |
Do the brake lights/turn signals/hazards/everything work? If so, then does it really matter that the relay clicks when you step on the brakes? |
All signals/lights/hazards/everythings work but the left brake light is dimmer than the right. Could that be a clue to anything? _________________ '67 Beetle
'67 Squareback
'66 Sundial
'60 Single cab
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Thu Jun 05, 2008 10:21 am Post subject: |
suebug wrote: |
NOS, not a reproduction. The '66 Sundial. It will hic.nabe at OCTO. Why? |
Try to find Bill May if your going. He was a factory trained VW mechanic, and a good man to boot. |
Braukuche Samba Member
Posted: Thu Jun 05, 2008 11:08 am Post subject: |
TimGud wrote: |
suebug wrote: |
Is he that old fart with the fuzzy caterpillar on his upper lip who's always at VW shows in that rusty $25 Bus??
--Dan |
TimGud Samba Member
Posted: Thu Jun 05, 2008 12:05 pm Post subject: |
He does own a $25 bus, no comment on your description of him. |
suebug Samba Member
Posted: Thu Jun 05, 2008 12:10 pm Post subject: |
Braukuche wrote: |
TimGud wrote: |
suebug wrote: |
--Dan |
Yeah, Dan, I think I know that guy! Do you think he would help me? _________________ '67 Beetle
'67 Squareback
'66 Sundial
'60 Single cab
dstefun Samba Member
Joined: February 20, 2002 Posts: 3338 Location: Sacratomato
Posted: Thu Jun 05, 2008 12:12 pm Post subject: |
suebug wrote: |
Andrew wrote: |
All signals/lights/hazards/everythings work but the left brake light is dimmer than the right. Could that be a clue to anything? |
A dimmer light could mean a bad ground on that light assembly, wrong bulb, poor connections. Bill can help. |
Andrew Samba Member
Posted: Thu Jun 05, 2008 12:44 pm Post subject: |
dstefun wrote: |
suebug wrote: |
Andrew wrote: |
Probably half or more of the buses I see have one brake light dimmer than the other. My bet is one taillight getting a better ground than the other. _________________ -Andrew |
Okie Adam Samba Member
Joined: November 07, 2003 Posts: 1347 Location: OOOOOOOOOOOOOOOOOklahoma
Posted: Thu Jun 05, 2008 2:13 pm Post subject: |
I have had at least 3 different 9 pin relays in my '66 since I have had it(7+years as a daily driver). Everyone of them has made a clicking noise when I apply the brake. All are/where original VW parts, 6V system, lights work. It is the same click you hear when you put on your turn signal but it is just one click and not a repeated click. About every bus I know has a dimmer left light. Further for the current to travel through old green wires is often a problem if the wiring is original. I have two grounds on both my tail lights and still the left is dimmer. Is your wiring original and are your tail light housings original? _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
60 Walkthrough Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
wanta23 Samba Member
Joined: March 31, 2007 Posts: 534 Location: At The Beach
Posted: Thu Jun 05, 2008 3:10 pm Post subject: |
My 9 pin has been replaced as well as the turn indicator. Both with WW. My 9 pin clicks continuously unless I turn on the headlights or plug something in to the accessory plug. I've added an additional ground wire but I can't figure it out. I drive with my lights on anyway so it doesn't really bother me too much. _________________ '66 13 window camper
www.makaibuildinginspection.com |
suebug Samba Member
Posted: Thu Jun 05, 2008 6:32 pm Post subject: |
one percenter wrote: |
I have had at least 3 different 9 pin relays in my '66 since I have had it(7+years as a daily driver). Everyone of them has made a clicking noise when I apply the brake. All are/where original VW parts, 6V system, lights work. It is the same click you hear when you put on your turn signal but it is just one click and not a repeated click. About every bus I know has a dimmer left light. Further for the current to travel through old green wires is often a problem if the wiring is original. I have two grounds on both my tail lights and still the left is dimmer. Is your wiring original and are your tail light housings original? |
The wiring is original. The tail light housings are original with a separate ground. I'm thinking something is wrong with the turn signal wiring at the 9 pin box because I looked at the diagram and the brake wires disappear into the 9 pin box and go to the turn signal switch. Hmmmmm. _________________ '67 Beetle
'67 Squareback
'66 Sundial
'60 Single cab
Posted: Thu Jun 05, 2008 6:45 pm Post subject: |
suebug wrote: |
The wiring is original. The tail light housings are original with a separate ground. I'm thinking something is wrong with the turn signal wiring at the 9 pin box because I looked at the diagram and the brake wires disappear into the 9 pin box and go to the turn signal switch. Hmmmmm. |
my concern with the original parts is more in the direction of the dim light problem. Make sure your bulb is fitting snug in the housing. You can pinch the bulb hole with pliers or wrap the bulb in foil. It grounds through the bulb base and a loose bulb wont ground no matter how many ground wires you have.
9 pins are a pain and i have often considered converting to the earlier style. If you have the correct bus wiring diagram for a '66-'67 then use it like a map and as long as what you have looks like what it shows you've got it made. The only thing I have to offer that it wont is that IMO your 9 pin relay will make noise when you push your brake pedal and that's okay. _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Andrew Samba Member
Posted: Thu Jun 05, 2008 9:14 pm Post subject: |
suebug wrote: |
The brake light wiring is supposed to go through the 9 pin relay... _________________ -Andrew |
66sunbug Samba Member
Posted: Thu Jun 05, 2008 9:59 pm Post subject: |
mine did that in my bug for ever until the 6v 9pin box pooped out it ran on 12v for 9 months. I think it is just a sudden use of power out of the same power supply as the pin box that it makes it slick my turn sigs never blinked when it clicked and every thing all ways functioned as it should |
