c21darrel Samba Member
asbug Samba Member
Joined: January 01, 2008 Posts: 287 Location: N.W. Ga.
Posted: Fri Jun 05, 2015 12:39 pm Post subject: |
San Dimas?
Bill and Ted's excellent adventure...
_________________ 1969 Ghia Vert - Jenny.
2004 B5.5 Passat Wagon - no name yet.
2012 Routan - Urban Assault Vehicle. |
akear Samba Member
Joined: August 18, 2013 Posts: 359 Location: Los Angeles
Posted: Fri Jun 05, 2015 3:44 pm Post subject: |
Northof49 wrote: |
I tried the double sided tape that came with a led strip in my engine compartment. It got too hot, the tap fell off, and the led strip got slightly abraded by my fan. |
The tape that came with the strip failed on me too. I reattached with 3m double sided tape for auto trim (bought at Autozone). That stuff is strong! |
DanUK Samba Member
Posted: Tue Jun 09, 2015 4:51 am Post subject: |
asbug wrote: |
How are all you early Ghia owners getting these into the solid steel rain trays?
I cannot figure out how to get them into my '69 Vert.
I have a couple openings (small) on the inside of the lid. Mine is a 1959, but I think the deck lid is slightly later. It was pretty awkward. I used sand paper and a vaccuum to make sure the surface was ready/clean.. placed the strip & used clothes pins to position it in a few small vent holes inside (being careful to make sure I had the wires routed properly to the brake lamps to get the signal!).. then removed the first inch or so of the tape backing and carefully peeled & stuck it down as I moved along the strip. I gave it a good rub into position to make sure it was properly stuck down, covering my hands and fingers in little cuts and indentations in the process
Back to the original question- I propped the deck lid open just enough to get a hand under so I could watch from the top, and had to work through a few vent slots on the inside right where the deck lid shuts near the convertible top |
Angus Dowrie Samba Member
Joined: March 07, 2005 Posts: 341 Location: Kangaroo Point, Australia
Posted: Thu Mar 09, 2017 3:21 am Post subject: Re: Third brake light |
Old post, but I have just mounted this at the bottom of my rear window. Wiring through the rear demister vent and double sided tape of the light to the glass means no extra holes.
It is slightly longer than the rear vent by about 20mm. The LED bulb can be rotated to suit the angle of the screen. I've got it mounted but forgot to take a photo of it. Will take one next time I'm there with it wired up. The 'box' minimises any reflection off the glass. _________________ 1963 Australian Delivery RHD Coupe
Build thread;
http://www.thesamba.com/vw/forum/viewtopic.php?t=610414 |
h~moto Samba Member
Joined: November 19, 2008 Posts: 317 Location: Northern Virginia
Posted: Fri Mar 10, 2017 4:04 pm Post subject: Re: Third brake light |
I put a third brake light at the bottom of the back window inside my `66 Beetle. I used a Hella bumper mounted reverse light. I replaced the clear lens with a reproduction 1957 and older type II brake light lens. I think this setup would work well for a Karmann Ghia.
slalombuggy Samba Member
Posted: Sun Mar 12, 2017 4:55 pm Post subject: Re: Third brake light |
h~moto wrote: |
Does the lens require modification or did it drop right in?
brad |
h~moto Samba Member
Posted: Sun Mar 12, 2017 8:26 pm Post subject: Re: Third brake light |
Quote: |
Does the lens require modification or did it drop right in? |
Fits right in. |
carguy4 Samba Member
Posted: Mon May 08, 2017 11:35 am Post subject: |
Do you have to remove the rain tray for this type of install?
Thanks in advance.
Doing the spring clean-up, thought illustrating the method would be useful to others - this basically makes the 3rd brake light a "separable" task without too many contingencies on clean surfaces, etc. We attached the lights to some vinyl weatherstripping, and then attached that to the upper screw positions in the rain tray. Basic idea:
Looks like this from back (lights off):
(Please excuse poor phone pic colors)
And then, what it looks like in real life:
(Again, excuse phone pic... We also later found out that tail-lights & brake-lights were reversed in harness wires, but you get the idea...)[/quote]
Looks good! That stretch of roadway looks like Baron Cameron Parkway near Lake Anne Center in Reston, VA.[/quote] |
e&m_ghia Samba Member
Posted: Mon May 08, 2017 5:52 pm Post subject: Re: Third brake light |
Thanks in advance.
We didn't remove the rain tray, we used the existing screws to find the screw-holes in the shadows. We did it as a 2 person job - one with clever, nimble fingers (E).
The rain trays in the late Ghia's are only held in by a few screws, so it's not a big deal to remove. (Our Ghia didn't come with it, but it was an easy purchase & install.) |
Figment Samba Member
Joined: October 27, 2016 Posts: 218 Location: Connecticut, USA
Posted: Sun Oct 15, 2017 4:57 pm Post subject: Re: Third brake light |
I plan to spend a fair amount of time with a loaded decklid rack, so I put mine up high.
L-61 unit from Watson's. I discarded their pedestal mount and made that little bracket to get it up tighter to the top of the window. Yeah, I know that bracket is going to put a little mooseknuckle in the headliner, but I can live with that.
Turn signals too!
_________________ '71 Ghia coupe |
c.j. Samba Member
Posted: Thu Nov 02, 2017 3:48 pm Post subject: Re: Third brake light |
Instead of splicing into the the wires I hooked up my brake light by using a double spade on the brake light bulb and ran the ground wire to the negative side of the coil. It works. |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Thu Nov 02, 2017 7:20 pm Post subject: Re: Third brake light |
c.j. wrote: |
But wouldn't that only work when the points were closed,,, er open,,, uh, how would that work? _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3914 Location: In Molinya Orbit
Posted: Fri Nov 03, 2017 3:07 pm Post subject: Re: Third brake light |
SBD wrote: |
c.j. wrote: |
But wouldn't that only work when the points were closed,,, er open,,, uh, how would that work? |
I too was wondering about that. The brakes are usually operating with a running engine and wired as described he has a switched earth via the points. The earth is subject to engine speed and dwell angle. Hardly ideal.
There are plenty of earth points nearby, for example on the generator where you can find a nice 4mm threaded hole just askiing for a spade lug.
LEDs are more responsive than filament lights so that might be why SBD has enough light to make him happy with his work methods.
Nicholas _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
c.j. Samba Member
Posted: Fri Nov 03, 2017 4:59 pm Post subject: Re: Third brake light |
Ran the ground to the body. |
Steelz21 Samba Member
Joined: January 09, 2017 Posts: 130 Location: Ontario canada
Posted: Mon Oct 19, 2020 4:20 pm Post subject: Re: Third brake light |
Great idea, safety first. |
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Mon Oct 19, 2020 4:27 pm Post subject: Re: Third brake light |
Looks Great, what brand and size did you use?
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
udo dreisoerner Samba Member
Joined: February 13, 2005 Posts: 1153 Location: Germany
Posted: Tue Oct 20, 2020 12:24 am Post subject: Re: Third brake light |
here my tird brake light. it is an aftermarket brake light from the 80's
_________________ Searching for a 1956 lowlight karmann ghia with a VIN number between1273054 and 1273440, and the matching engine with an Engine Number between
1525510 and 1525519 PLEASE OFFER ME ONLY THE CARS THAT I'M LOOKING FOR, THANKS!! |
