Making a 6" fuchs into a 4.5"
Page: 1, 2, 3, 4  Next
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
flyinglow94
flyinglow94 is offline
PostPosted: Thu Jun 12, 2008 11:38 am    Post subject: Making a 6" fuchs into a 4.5" Reply with quote
The topic says it all. I was asked if this was possible? And if I could do this? Well I like a challenge once in a while so I agreed to the job. And Here is the Job in progress to the finished product. I do not polish so I gave them back ruff machined. I had given them back to there owner at the Classic.
I Did not show the register that I had cut to locate the ring I just did not take a picture the bead seat for the tire is 3/4 of an inch and the ring is Tig welded both front and back.
I have a couple more pictures in my gallery of these and other projects I have worked on for my cars.
"What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
"Socialism is a philosophy of failure,the creed of ignorance, and the gospel of envy,its inherent virtue is the equal sharing of misery.."
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
David
David is offline
PostPosted: Thu Jun 12, 2008 11:07 pm    Post subject: Reply with quote
Shocked That's pretty cool.
I'd like to see them again after having the weld smoothed out and the face polished or chromed.
Cheers,
Dave
*October '54 Ragtop
mr. warehouse
mr. warehouse is offline
PostPosted: Fri Jun 13, 2008 2:00 am    Post subject: Reply with quote
The "King Crabs"
Detailing is inn the works, they should be delivered to Al Reed today (Friday) for full chrome.
I'll post after pics once I get them back.
envycustoms
envycustoms is offline
PostPosted: Fri Jun 13, 2008 12:52 pm    Post subject: Reply with quote
how much, and how long to produce me a set?
56 SunRoof (o\U!U/o) "Hood Fellas"
Damn.. not another car on earlies!
www.EnvyCustoms.Tumblr.com
flyinglow94
PostPosted: Fri Jun 13, 2008 2:30 pm    Post subject: Reply with quote
It takes about two weeks turn around to machine and weld. That is between my day job , family and small must do projects. And I charge $400 to do a set of two.
NOTAHONDA
Vegas Don
NOTAHONDA is offline
PostPosted: Fri Jun 13, 2008 4:24 pm    Post subject: Reply with quote
Nice work Chris! With the going rate of real 4.5's this is sweet.
mr. warehouse
PostPosted: Fri Jun 13, 2008 7:30 pm    Post subject: Reply with quote
Not the same as a 4.5.
These spokes stick out WAY farther than a "regular" 4.5"
Still waiting to hear if polish / chrome will be possible with the welding.
These may just be nice wall hangers....
NOTAHONDA
Vegas Don
PostPosted: Fri Jun 13, 2008 8:03 pm    Post subject: Reply with quote
Just noticed that, look bad ass! Confused
sas-lo
sas-lo is offline
PostPosted: Sun Jun 15, 2008 4:56 pm    Post subject: Reply with quote
so how do you keep them from warping during the welding process?
-DHP
flyinglow94
PostPosted: Sun Jun 15, 2008 5:03 pm    Post subject: Reply with quote
sas-lo wrote:
so how much do you keep them from warping during the welding process?
I preheat then I start tacking across and around until it's totally welded because I use a tig welder, not a mig for better control and penetration. I also machine a register in the rim to accept the ring for a tight fit.
theastronaut
theastronaut is offline
PostPosted: Sun Jun 22, 2008 6:56 pm    Post subject: Reply with quote
I guess you could narrow them just enough to get the same look as a 4.5" from the front, with the spokes sticking out the same amount as an OG 4.5"?
Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
-Sir Henry Royce, co-founder of Rolls-Royce
'64 Beetle Sunroof OG Bahama Blue
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10
mr. warehouse
PostPosted: Sun Jun 22, 2008 8:25 pm    Post subject: Reply with quote
You'd need 2 cuts for that.
1 on the face, and 1 on the rear.
by the time you pay for a deep 6, pay $400 per wheel (2 cuts) you could buy a sets of real 4.5's
flyinglow94
PostPosted: Sun Jun 22, 2008 9:56 pm    Post subject: Reply with quote
Mr.Warehouse is right, many things can be done but is it worth the cost... if the 4.5 can still be found?
theastronaut
PostPosted: Mon Jun 23, 2008 9:10 am    Post subject: Reply with quote
I was thinking about just having the front narrowed, to get the same look from the outside; i know the overall width would be more than a 4.5" but it still would be around 5 inches, just guessing as i don't have a 4.5 to compare with my deep 6s.
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10
flyinglow94
PostPosted: Mon Jun 23, 2008 9:34 pm    Post subject: Reply with quote
It can be done, I would just need to know the measurement of the OG 4.5" lip to the bottom of the spoke, to make it look like a correct 4.5". And yes, it would be 5".
Bruce
Bruce is offline
PostPosted: Mon Jun 23, 2008 10:06 pm    Post subject: Reply with quote
It is not so easy. If you look at the drop center of a deep 6, there isn't anywhere you can cut out an inch and be able to mate the pieces back together. The drop center has a taper. You can do this to a late flat 6. A buddy did just that.
flyinglow94
PostPosted: Mon Jun 23, 2008 10:14 pm    Post subject: Reply with quote
It would need to be cut lower at the spokes to make it look right. I cut a register in the base and then weld the pieces together then machine a radius between the base and the ring to make it look correct.
theastronaut
PostPosted: Tue Jun 24, 2008 8:33 am    Post subject: Reply with quote
I had noticed the taper and saw from your pics that it had to be cut at the bottom of the lip. I will have to find out how deep the lip is on a 4.5" to be able to replicate it.
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10
El Cookie Monster
El Cookie Monster is offline
PostPosted: Fri Jun 27, 2008 12:29 pm    Post subject: Reply with quote
what if u do this to a set of 16's. i think that would be sick 16x4.5
flyinglow94
PostPosted: Fri Jun 27, 2008 1:54 pm    Post subject: Reply with quote
One of my next projects will be to do some 16's for my car as soon as I can afford a set. I think I will only make it a 5 wide though. I have the tools and the time I just don't have the money.
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 1 of 4
