casey79westfalia Samba Member
Posted: Mon Jun 16, 2008 9:56 am Post subject: |
Great work Jake! Two camping trips this summer so far (1000 miles) and not a single problem on our camper special. Have about 10k on my camper special to date and it has been absolutely worry free. I will buy another if i blow this one up someday due to me driving it like a sports car. The proof is in the pudding guys!
Jake I have a leaky flywheel seal too! Wanna come fly down to baltimore?
Actually I put my camper special version together myself and first go had a very leaky flywheel seal and after doing it a second time it still leakes a tiny bit. Usually a dime size oil drop per week! Dry as a bone everywhere else.
The rear flywheel seals I have always had trouble with and it really happens on the first startup on a rebuild. The seal is to dry and gets snagged or shifted in its bore or the bore si not clean and smooth! Seems some design work needs to be done there to eliminate the failure of these seals. In my case it was surely user error! Maybe when I remove the camper special for a clutch replacment in 5 years or so I will do it then! _________________ 66 Westfalia
87 Westfalia Syncro "Phoenix"
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
Currently looking for 62 Double Cab, 66 Westfalia Parts!
(Rear seat and pedestal, bumpers, mirrors)
http://www.baycountrymotors.com
My 87 Syncro Westfalia 1.8t Restoration
http://www.thesamba.com/vw/forum/viewtopic.php?t=418933
"Do it the right way, or you'll pay for it" |
thewalrus Big Jack
Joined: March 27, 2006 Posts: 3014 Location: Belchertown, MA
Posted: Mon Jun 16, 2008 10:15 am Post subject: |
Hey Jake....off topic but out of curiosity...what kind of CHT do your engines usually have? I understand weight, speed, and terrain factor in but, on average what would you guess?? _________________ '73 Transporter 1.7L Dual Carb
notchboy wrote: |
You ran over some #Vanlife'ers hopes and dreams? |
60vwnewengland wrote: |
Looking forward to next weekend, weed, krunk juice, hookers, blow, hanging with bums, philly, ...the awards! |
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 7433 Location: Aircooled Heaven USA
Posted: Mon Jun 16, 2008 10:16 am Post subject: |
The main issue that causes main seal leaks is inadequate lubrication of the seal/ flywheel surface during assembly.
Once the seal is "sealed" oil cannot get to it to lubricate the surface, so the seal becomes "smoked" quickly at start up...
Those who use any form of grease on these surfaces also instigate issues since the grease has to get very hot before it is burned away, at that point the grease has blocked the seal from getting the oil needed to keep it alive and well.
Then you have a leak. The flywheel seal wasn't the source of Jim's leak. _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
Posted: Mon Jun 16, 2008 10:22 am Post subject: |
thewalrus wrote: |
Hey Jake....off topic but out of curiosity...what kind of CHT do your engines usually have? I understand weight, speed, and terrain factor in but, on average what would you guess?? |
My Bus runs 350-360 in 90* weather on flat ground, it will hit 375 on a medium grade and will bump 400 up hills. It will not o past 400F, even when towing my Beetle. _________________ Jake Raby
TRN9 Samba Member
Joined: September 29, 2006 Posts: 309 Location: Where its rainy
Posted: Mon Jun 16, 2008 1:14 pm Post subject: |
Kudos Jake! I love these stories! Everything is going great with my Camper Special I love it!!!!!!!!!! Thank you again! |
Posted: Mon Jun 16, 2008 1:27 pm Post subject: |
Cool!!!
I miss my opposition, where did they all go ??? _________________ Jake Raby
jgordon Samba Member
Joined: March 21, 2008 Posts: 162 Location: Cocoa Beach Florida
Posted: Mon Jun 16, 2008 2:09 pm Post subject: |
Jake Raby wrote: |
Cool!!!
I miss my opposition, where did they all go ??? |
finally seen the light and the error of their ways??
or maybe they just finally realize that you are right
either way, great info as always, and i look forward to speaking with you in the fall about my very own Jake masterpiece
James |
Pierre G Samba Member
Joined: April 28, 2007 Posts: 1771 Location: New Caledonia
Posted: Tue Jun 17, 2008 12:22 am Post subject: |
Jake Raby wrote: |
Then you have a leak. The flywheel seal wasn't the source of Jim's leak. |
Hi Jake,
So you recommend what ? Oiling the seal and flywheel surface with engine oil prior to install it ? Is that as simple ?
Pierre _________________ 1976 181/Thing, 1967 fastback, 1973 squareback, 1964 microbus, 1967 Double Cab, 1969 westfalia (currently under resto), 1972 LM1C dune buggy, 1974 jean's bug, 1974 1303 (super beetle, currently under reassembly after new paint). |
Posted: Tue Jun 17, 2008 4:30 am Post subject: |
Yes. Who installs a seal without lubrication?
ANY component that is assembled that contacts any other component, in any way MUST be lubricated during engine assembly!! _________________ Jake Raby
Bloog Samba Member
Joined: April 11, 2007 Posts: 484 Location: Over yonder
Posted: Tue Jun 17, 2008 5:10 am Post subject: |
Jake Raby wrote: |
thewalrus wrote: |
My Bus runs 350-360 in 90* weather on flat ground, it will hit 375 on a medium grade and will bump 400 up hills. It will not o past 400F, even when towing my Beetle. |
I have a '72 fully loaded Campmobile running the "original" Camper Special. It has around 50k miles on it now and the heads have never seen 400 degrees, even in Florida in late July, even in the mountains in August...
Our other '72 bus is a Transporter converted to a Weekender with full cabinetry and fold down bed. It has never seen head temps past 360... _________________
Bob Hoover wrote: |
Listen to what the ENGINE has to say. It won't take your money and it's incapable of lying. All you have to do is learn to speak its language.
-Bob Hoover |
chabanais wrote: |
Ah... you buy from Sum Ting Wong Distribution Company. |
Posted: Tue Jun 17, 2008 6:55 am Post subject: |
Quote: |
I have a '72 fully loaded Campmobile running the "original" Camper Special. |
Meaning ORIGINAL.. As in, First one ever built! _________________ Jake Raby
Brown_Bus Samba Member
Joined: December 14, 2007 Posts: 319 Location: Roanoke, VA
Posted: Tue Jun 24, 2008 7:30 am Post subject: |
The thread doesnt suprise me. The few times that I spoke with Jake he was informative, helpful, friendly and seemed dedicated to making sure that the customer would be happy.
Still a few dimes away from my CS. But It wil come soon! _________________ '76 L20A marino yellow Westy |
Bleyseng Samba Member
Posted: Tue Jun 24, 2008 7:59 am Post subject: |
good to see some well deserved kudo's for Jake and his service.
Its way easier to assemble one of Jake's kits instead of buying a pile of parts off the net for a motor. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
Posted: Tue Jun 24, 2008 8:15 am Post subject: |
I have absolutley no engine removal or rebuild experience. I want to at the very least get the CS kit.
How hard is it to build. Can a extreme novice with determination handle it? _________________ '76 L20A marino yellow Westy |
Posted: Tue Jun 24, 2008 8:19 am Post subject: |
How hard is it to build. Can a extreme novice with determination handle it? |
We don't sell kits to shops. We also won't sell a kit to someone who will take it to a shop for assembly. The shops bad habits and "thoughts" impact the results of the kit in 95% of cases.
The entire program has been based from an entry level perspective and today we even sell tool kits with all the tools needed to assemble the entire kit included in them.
Our best kit customers are those with no experience- they are meticulous and procedural following our instructions verbatim because they have no badhabits and prior experience to cloud their judgement. _________________ Jake Raby
barrysmith Samba Member
Joined: July 14, 2006 Posts: 258 Location: wilburton oklahoma
Posted: Tue Jun 24, 2008 8:26 am Post subject: |
rab-E or RAY-B ? Just curious as to pronounciation.
thanks! |
Posted: Tue Jun 24, 2008 8:44 am Post subject: |
Its easy.
Baby with the first B replaced with an R. _________________ Jake Raby
IFBwax Samba Member
Joined: April 05, 2005 Posts: 1325 Location: Beaverton, Oregon
Posted: Tue Jun 24, 2008 10:04 am Post subject: |
Just got back from trip #2 of the year so far in my CS... try as I might on the mountains, or hills of Central Oregon, couldn't get my CS to go above 386 on a pretty hot day for here. That's uphill folks!
Loving it Jake!!!! _________________ Owner of: "The Party Pickle" (a 1979 2 Liter FI "Raby Camper Special" Sage Green Westy Campmobile) & "Charlie Brown" (a 1979 2 Liter FI "Rob Grant Rebuild" Agate Brown/Dakota Beige Station Wagon)
www.partypickle.blogspot.com |
Rubber Duck Samba Member
Joined: January 18, 2006 Posts: 806 Location: Pitt Meadows BC
Posted: Tue Jun 24, 2008 10:26 am Post subject: |
Jake Raby wrote: |
Our best kit customers are those with no experience- they are meticulous and procedural following our instructions verbatim because they have no badhabits and prior experience to cloud their judgement. |
This sounds really good to someone like me Nothing like a fresh slate to work on eh _________________ ---------
Rubber Duck
1974 Westfalia |
Posted: Tue Jun 24, 2008 10:36 am Post subject: |
IFBwax wrote: |
Loving it Jake!!!! |
Great! thats what we like to hear!!!
Quote: |
This sounds really good to someone like me Nothing like a fresh slate to work on eh |
Yep, its always best to start from scratch. _________________ Jake Raby
