xzener Samba Member
Posted: Fri May 12, 2017 6:02 pm Post subject: Re: What did you do to your ghia this week? |
After completing the short axle conversion, I decided it was time to fill the transmission with fluid. I crafted up a fill funnel using a long narrow funnel and a long piece of tubing from leftover trickle irrigation. Worked out great. Just shoved the tube into the fill hole, zip tied the funnel to the deck lid spring and filled it up. So far, no leaks! Who needs a pump? _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
kingkarmann Samba Member
Posted: Sat May 13, 2017 8:45 am Post subject: Re: What did you do to your ghia this week? |
xzener wrote: |
After completing the short axle conversion, I decided it was time to fill the transmission with fluid. I crafted up a fill funnel using a long narrow funnel and a long piece of tubing from leftover trickle irrigation. Worked out great. Just shoved the tube into the fill hole, zip tied the funnel to the deck lid spring and filled it up. So far, no leaks! Who needs a pump? |
Great Idea!
Thanks for sharing _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Sat May 13, 2017 9:42 am Post subject: Re: What did you do to your ghia this week? |
kingkarmann wrote: |
They are never done!!
The laundry list was a bit long but after finishing my Ghia way back in 2006 and racking up around 11,000 miles it was time for a bit of a freshening.
Pulled and rebuilt the pedal cluster (I had a nagging squeak every time ime depressed the clutch pedal) I upgraded the accelerator pedal with an X-Celerator Speed Wheel from Classic Bug Parts. I now have I a nice, smooth and most importantly, QUIET pedal cluster.
I'm happy for you that replacing all of those pedal cluster pieces did in fact take away that nagging squeak every time you depressed the clutch pedal.
The next logical step would have been a hip replacement, and that would be a lot more expensive! ... and doing that job yourself to reduce costs isn't even an option.
As usual, all of your latest efforts add up to another job well done kingkarmann.
Your Ghia is beautiful, and it's great to hear that you are enjoying using it regularly. |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2874 Location: Auckland, New Zealand
Posted: Sun May 14, 2017 6:14 pm Post subject: Re: What did you do to your ghia this week? |
I'm beginning to enjoy my Ghia more every day. Sorted one of the last few niggles today: I have 165/80/R15 at the back and 165/65/R15 on the front, with 2" dropped spindles and adjustable beam - no rubbing on the fenders but only after a lot of trial and error, I might add.
This setup gets the stance right and keeps the engine revs right for the wheels at the back, but it does mean an under-reading on the speedo. So I bought a speedometer gear from an advertiser here on the Samba and installed it today. Accuracy is within about 1-2%. Not good enough for the space program, but good enough for me and the ever so keen cops we have around here.
_________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
c21darrel Samba Member
Posted: Mon May 15, 2017 11:39 am Post subject: Re: What did you do to your ghia this week? |
c21darrel wrote: |
Nice, Do you have a link to that Kiwi? :idea: |
I think this might get you there, Darrel. If it doesn't, I'll PM you Daryl Sandberg's email address. He was very helpful. I'll test the gear some more and post an update on its performance at the end of the week. (Their advert appears every third week or so in the Featured ads.)
http://www.thesamba.com/vw/classifieds/detail.php?id=1999299 _________________ Festina lente - hasten slowly
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13952 Location: Southampton U.K.
Don Radomski Samba Member
Joined: May 12, 2015 Posts: 55 Location: Edmonton, Canada
Posted: Sun May 21, 2017 8:05 am Post subject: Re: What did you do to your ghia this week? |
Bought OE roof rack and drove my Ghia 673 Miles round trip to the Alberta Rockies
Posted: Sun May 21, 2017 10:49 am Post subject: Re: What did you do to your ghia this week? |
Don Radomski wrote: |
Wow! Just wow! That's what our Ghias are for. Great countryside, great photos, and, of course, a great car in a beautiful colour. _________________ Festina lente - hasten slowly
Posted: Sun May 21, 2017 7:56 pm Post subject: Re: What did you do to your ghia this week? |
kiwighia68 wrote: |
Wow! Just wow! That's what our Ghias are for. Great countryside, great photos, and, of course, a great car in a beautiful colour. |
You forgot to mention what a great rack Don has! |
Jtjimmie Samba Member
Posted: Tue May 23, 2017 5:07 pm Post subject: Re: What did you do to your ghia this week? |
1965 KG newbie here! Have been working on my Ghia for a few months now, and just recently discovered this forum! I purchased a coupe and a convertible June 2016, and started working on the coupe first ... it runs, the vert needs an engine.
Have started putting everything back together and have experienced no particular difficulties!
Here are some pics.
Day 1 - Just backed into the garage. Has a little nose damage and minor dents and scratches.
Dash is mostly original ... aftermarket fuel gauge and radio.
Body and paint complete. Went with nerf bars until I can afford to fix the bumpers.
Shaved the dealer installed antenna and mirror holes, and mounted aftermarket swan mirror.
Reworked dash ... added a rubber washer around the ignition switch to prevent scratches ...
cannot find if there was an original escutcheon (??)
Repaired the nose ... about 4 hours of hammering and "skim coat" of bondo. The entire car is "mostly" bondo free,
only needing small areas of "smoothing"!
Refurbished deck insignia ... still working the "VOLKSWAGEN" script
Completed rear deck and new rubber connector.
Original front towel bar bumper ... needs work ... saving my $$$$
Original rear towel bar bumper ... needs work ... saving my $$$$
Engine compartment (as purchased ... no work done here!)
Rear view with nerf bars and cheese grater.
xzener Samba Member
Posted: Sun May 28, 2017 12:27 pm Post subject: Re: What did you do to your ghia this week? |
Installed an X-drilled Porsche/Chevy rotor. Painting the caliper, it's in the oven curing. Decided to throw on the 17X7 rim to see what the initial fit/clearance would look like on a stock beam with lowered spindles... It actually looks like it will clear the fender if I remove the jacks. I am certain a 2" narrowed beam will be the way to go.
xzener Samba Member
Posted: Sun May 28, 2017 2:26 pm Post subject: Re: What did you do to your ghia this week? |
Here is the finished product. Looks great.
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Tue May 30, 2017 1:57 am Post subject: Re: What did you do to your ghia this week? |
Damn that looks really good. I even like the red calipers. _________________ ----------------------
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything |
Posted: Tue May 30, 2017 6:39 pm Post subject: Re: What did you do to your ghia this week? |
Installed the front and back glass today ... took my time, and spent about 1 hour each. The toughest part was keeping the rubber on the glass while trying to install it! I tried masking tape, no go. Then I "bungee'd" the rubber on overnight, and when the rubber had a little "memory", it stayed in place during the installation. I used plenty of soapy water, working inside-outside-inside-outside, a little at a time until done.
Then, every time I worked on the outside, I used an "orange stick" to coax the rubber molding edges into position. An "orange stick" is typically used by beauticians to push the cuticle back when doing ladies nails. It works great, and doesn't scratch the paint! Any small hardwood dowel will work ... sand the edge to a rounded chisel point (not a pencil point ... see pic)
Front Glass - Original glass, new rubber.
Rear Glass - Original glass, new rubber
Orange Stick - Used to push the edges of rubber molding into position, and not scratch the paint. Any hardwood dowel should work: 3/16" diameter x 6" or 7" long.
Posted: Thu Jun 01, 2017 5:32 pm Post subject: Re: What did you do to your ghia this week? |
1965 Karmann Ghia - Door Panel Rebuild
Yesterday, I prepared my new door panels for installation.
I included the edge piping (name ??) from the original, and the aluminum strips.
To make the holes, I used a small drill bit, drilling from the "finished" side.
I learned (testing on the old/original vinyl) that if you try to drill through vinyl on the "backside', the drill bit catches the fabric and "wound" it up around the bit.
I first placed masking tape where I wanted the trim to be, then measured and marked each hole.
1965 Karmann Ghia - Hood and Deck Lid Seal Installation
Today, I installed the hood and deck lid rubber seals. I used 3M 8008 - Black. The trick is to let it dry (15-20 minutes) before you bond the pieces.
First I roughened up the paint, spread the sealant on both the car edge and the rubber seal.
After waiting about 15 minutes for the glue to dry, I carefully put the seal in place.
Then, using clothes pins to hold the seal, let it dry for about an hour.
Now, I need to install the hood, and realigned the lock pins.
Posted: Sun Jun 11, 2017 9:25 am Post subject: Re: What did you do to your ghia this week? |
I get the occasional itch to do something to the Ghia before the next show season.
To me, the "trunk" area didn't pop. I'm sure that somewhere I stole this idea but for the life of me I cannot remember where I saw it. I tried recreating what I thought I saw by installing polished aluminum strips to the recesses of my fuel tank.
I ordered 1/8" x 3/4" flat stock. I the cut and formed the stock to match the contours of the tank. I fastened the strips using 3M double sided automotive trim tape. The tape is fairly thick,about1/16". It made the strips sit too high. I redid with trim & emblem adhesive. I'm much more satisfied.
Before
During
After
Mike Gerson
swavananda Samba Member
Joined: February 14, 2009 Posts: 889 Location: Can o' Scruz
Posted: Mon Jun 12, 2017 10:17 am Post subject: Re: What did you do to your ghia this week? |
What , you didn't polish the fuel sender too ? looks great. |
Posted: Mon Jun 12, 2017 10:43 am Post subject: Re: What did you do to your ghia this week? |
swavananda wrote: |
Actually I found a chrome sender cover but it didn't fit.
Not sure if one is made to fit mine. I guess I will have to get to polishing _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
