What did you do to your ghia this week?
Page: Previous  1, 2, 3 ... 120, 121, 122 ... 164, 165, 166  Next
Bloku
Expert Noob
Bloku is offline
PostPosted: Fri Nov 03, 2017 3:02 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
Got my seats back! They are far better than I ever imagined! These seats feel better than the seats that are in my modern mazda. The seats are a completely custom job, no pre-made panels or anything. Before they were reuphulstered, I could look through the driver's seat at the floor...
1971 Karmann Ghia
1975 Porsche 914
1975 BMW 2002
1976 BMW 2002 (Bored and Stroked w/ 5-Speed)
1981 BMW E21
1986 Toyota 4Runner (Dead engine and trans)
1989 Toyota 4x4 PU
1994 BMW E36 (Daily)
rbsurfguy
Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
rbsurfguy is offline
PostPosted: Fri Nov 03, 2017 3:09 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
Those look great Bloku! Post another pic when you get them installed. Are they leather or some type of Naugahyde?
1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
Bloku
Expert Noob
Bloku is offline
PostPosted: Fri Nov 03, 2017 3:20 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
Thank you rbsurfguy! They are actually made of a marine grade vinyl. It is visually very close to the original materials. In the pictures, the door cards and the back seat are the og fabrics for reference.
Many thanks to Katie at Long Lane Upholstery out of Carthage, Missouri for doing these seats (excelent pricing as well). If anyone needs there seats done right and lives around there, this is the place to go!
Here are the seats installed. Please forgive the lighting in the pics it is a particularly overcast day here in OK...
1971 Karmann Ghia
1975 Porsche 914
1975 BMW 2002
1981 BMW E21
1989 Toyota 4x4 PU
rbsurfguy
PostPosted: Fri Nov 03, 2017 3:35 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
They look really great Bro. I like the look with you Ghia color!
2012 Passat-Sold
kiwighia68
kiwighia68 is offline
PostPosted: Fri Nov 03, 2017 4:13 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
Very nice indeed. Good work.
Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015
Volfandt
Volfandt is offline
PostPosted: Mon Nov 20, 2017 10:35 am    Post subject: Re: What did you do to your ghia this week? Reply with quote
Had been living with a intermittent no start problem all summer and it finally went to full time no start so I had to address it.
Problem was turning the key to start would not spin the starter, just get a click. Several off/on's would get it to spin, that is until it wouldn't LOL.
Crawled under and hooked up a remote starter switch and the starter spun every time, starter good.
Traced wiring to a splice connector behind the dash (solid red to red/black) and another connector under the rear seat (red to red).
Opened connector at dash and at 1st I read 12v from ign switch when turned.
Hooked up a jumper and applied 12v directly to the red/black wire running back to the starter. Starter spun every time.
Must have been a lose splice connector I thought.
Cleaned up and reconnected red to red/black spade lugs in the splice connector and the starter wouldn't spin. Hummm I thought, this ain't making no sense.
I then checked and rechecked that splice connector again and again.
So, long story short, I got the red wire from the ign switch to fail several times at that splice and decided to swap the ign switch.
That fixed the problem.
Swapping the ign switch isn't too bad but sliding the combination turn signal/wiper switch in and out of the steering column is tight. I ended up spraying alittle silicon in the column to help slide the switches back in.
Surprisingly I got the plastic ign switch from a local flaps for $9.
Also found a loose ground that caused intermittent right front turn signal, parking light failures.
1972 Karmann Ghia, the Dragon slayer....
alansvwTwinCab
alansvwTwinCab is offline
PostPosted: Mon Nov 20, 2017 5:34 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
Someone asked to se some more photos of the 61, All rubbers now installed now doing all the little details that take forever and are very frustrating.. thank god for red wine!
rbsurfguy
PostPosted: Wed Nov 22, 2017 7:05 am    Post subject: Re: What did you do to your ghia this week? Reply with quote
This looks SWEET Bro. I can't wait to get mine to at least this stage! Couple of questions: where did you get the breather box and the battery hold down? They are what I am looking for as well. Good on ya mate!
2012 Passat-Sold
xzener
xzener is offline
PostPosted: Thu Nov 23, 2017 9:49 am    Post subject: Re: What did you do to your ghia this week? Reply with quote
Your attention to detail is top notch Alan, looks great. Where did you purchase your swan neck mirrors?
My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>!
sputnick60
sputnick60 is offline
PostPosted: Thu Nov 23, 2017 6:39 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
Xener, you can search the classifieds for mirrors.
You'd be looking for swan neck or albert mirrors.
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
c21darrel
c21darrel is offline
PostPosted: Mon Nov 27, 2017 1:03 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
The mirror I am running looks similar. I pieced mine together using an original neck and Albert parts I found at a swap meet. Pics...
GhiaBuild
1967 DC build
kiwighia68
PostPosted: Mon Nov 27, 2017 1:47 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
A local Ghia owner needed just one piece of the fender to fender trim on the sides of his Ghia so I took my old, refurbished set off and replaced it with a new stainless steel set. The old ones came off the clips with a little coaxing. I used a plastic knife from a fast-food place.
The new ones went on just as easliy. Nice, tight fit on the KGP&R clips.
Just saying.
jimwar
jimwar is offline
PostPosted: Tue Nov 28, 2017 2:34 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
I have a 69 and replaced the dash pad and fake wood dash which is more work than it appears. I also too the wheels to Les Schwab who will powder coat each wheel for $30 which is unreal. I found the original seat material and am having the seats recovered locally. Also the company that has interior materials is doing the door panels to match the originals. Then it's going to House of Ghia to dial in electrical.
alansvwTwinCab
PostPosted: Mon Dec 04, 2017 7:39 am    Post subject: Re: What did you do to your ghia this week? Reply with quote
Jeff,
I got the breather box from a guy here in Australia but I have sen them advertised here new on SAMBA. heres his link
http://rodpenroseracing.com.au/breather-boxes/506-breather-box-50mm-deep-aluminium-an-8-fitting.html
The Swan mirrors again from SAMBA classified adverts.
Alan
alansvwTwinCab
PostPosted: Mon Dec 04, 2017 7:44 am    Post subject: Re: What did you do to your ghia this week? Reply with quote
Went to fit the washer switch but its been stored for 7 years and the rubber has rotted.
Does anyone know if you can get a replacement as I wanted to keep the Ivory knob style switch?
Also as Ive fitted a new 12V armature motor so will this work anyway or do I need a new unit?
rbsurfguy
PostPosted: Mon Dec 04, 2017 8:20 am    Post subject: Re: What did you do to your ghia this week? Reply with quote
alansvwTwinCab wrote:
Jeff,
Thanks Alan, I also found what appears to be the same basic model on CIP1 website, very similar if not the same. Deciding which to go with.
2012 Passat-Sold
kiwighia68
PostPosted: Fri Dec 15, 2017 8:00 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
I fitted a tach to my '68 and intslled it in the hole where the clock used to be. The tach works and with a stock transmission and 1641 motor gives a reading of 2000 rpm at 40 MPH. I haven't taken it to the motorway yet to test its accuracy at 60 MPH.
Out of the box:
Installed:
I've owned VW's before (4, to be exact) but never one with a tach.
xzener
xzener is offline
PostPosted: Fri Dec 15, 2017 8:02 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
Looks great! I plan on doing the same in my 68... What's the switch underneath for?
kiwighia68
PostPosted: Fri Dec 15, 2017 8:07 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
There was a hole where that switch is now in the dash when I bought the car. The rear window demister switch on these cars was a bit of an afterthought - going under the dash somewhere, I think - so I filled the hole with a provisional switch for the day I have to install the demister components. (If I ever get there.)
xzener
xzener is offline
PostPosted: Fri Dec 15, 2017 8:09 pm    Post subject: Re: What did you do to your ghia this week? Reply with quote
Is that where the brake test light/switch goes? I think mine was there before I gutted the car.
Page 121 of 166
