kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2876 Location: Auckland, New Zealand
Posted: Fri Dec 15, 2017 10:18 pm Post subject: Re: What did you do to your ghia this week? |
xzener wrote: |
Is that where the brake test light/switch goes? I think mine was there before I gutted the car. |
Tha brake test light switch is on the other side of the steering column on my RHD Ghia. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
xzener Samba Member
Posted: Sat Dec 16, 2017 12:41 pm Post subject: Re: What did you do to your ghia this week? |
Right. Looked through your build thread and noticed it was RHD. 😉 _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
VWRESTOMODMAN Samba Member
Joined: January 17, 2014 Posts: 75 Location: California
Posted: Fri Jan 05, 2018 8:46 pm Post subject: Re: What did you do to your ghia this week? |
Was surfing the net today and ran across this very useful and informative "How To" video for engine removal on a 1967 Ghia, NOT!
It was painful and funny to watch, but in the end just kind of left me thinking, was this video really necessary to share with the world. You can be the judge, please just don't shoot the messenger
https://youtu.be/KoI2v3kp_20 |
xzener Samba Member
Posted: Fri Jan 05, 2018 8:54 pm Post subject: Re: What did you do to your ghia this week? |
Wow. I took apart the top end, makes it easier to get out IMO. Can easily tip the motor back and slide under the rear apron. The first time is always a learning experience... My first time was with my previous 70 beetle. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Sun Jan 07, 2018 1:19 pm Post subject: Re: What did you do to your ghia this week? |
What I did "to my Ghia this week" was to break the speedo glass.
Mmm!
Does anyone know the precise diameter of a '68 Ghia's speedo glass? I measured after putting the shards togetehr again but I get different sizes: - 11.4 cm and 11.3 cm - or 4.5 inches and 4 and 5 sixteenth of an inch.
Yeah, I know. I can take the speedo out and measure, but I don't want to take it out until I have the glass. _________________ Festina lente - hasten slowly
xzener Samba Member
Posted: Sun Jan 07, 2018 2:13 pm Post subject: Re: What did you do to your ghia this week? |
Do you have the ring off? Maybe you can get an idea of the size by comparing the ring and the face of the speedo. My 68 speedometer is out... But don't want to break mine too. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Sun Jan 07, 2018 2:42 pm Post subject: Re: What did you do to your ghia this week? |
xzener wrote: |
Do you have the ring off? Maybe you can get an idea of the size by comparing the ring and the face of the speedo. My 68 speedometer is out... But don't want to break mine too. |
I'm going to have to prize the ring off without damaging the chrome face, but I don't want to start until I have the new glass. I measure the inside diameter of the ring to be 9.7cm and the outside diameter 10.8cm.
My glass measurements (11.3 and 11.4cm respectively) are greater than the outside diameter of the ring, which, I think, means I can go to 11.3cm when I order the glass without fear of it being too large. _________________ Festina lente - hasten slowly
Fiatdude Samba Member
Joined: April 20, 2009 Posts: 1218 Location: now in MO.
Posted: Sun Jan 07, 2018 4:19 pm Post subject: Re: What did you do to your ghia this week? |
VWRESTOMODMAN wrote: |
xzener wrote: |
Wow. I took apart the top end, makes it easier to get out IMO. Can easily tip the motor back and slide under the rear apron. The first time is always a learning experience... My first time was with my previous 70 beetle. |
I cheat ----- However, I'm a HUGE fan of the 2 floor jack system
_________________ Remember, as you travel the highway of life,
For every mile of road, there is 2 miles of ditch |
swavananda Samba Member
Joined: February 14, 2009 Posts: 889 Location: Can o' Scruz
Posted: Sun Jan 07, 2018 8:33 pm Post subject: Re: What did you do to your ghia this week? |
kiwighia68 wrote: |
How in the heck did you manage that ? If it's something you would rather not talk about i understand |
Posted: Sun Jan 07, 2018 8:53 pm Post subject: Re: What did you do to your ghia this week? |
swavananda wrote: |
kiwighia68 wrote: |
How in the heck did you manage that ? If it's something you would rather not talk about i understand :wink: |
I find a new way of making a fool of myself every day.
I was trying to reconnect the speedo cable and must have pushed too hard. The problem is that the cable had snapped leaving too short a piece protruding to fit into its slot in the speedo. So I pushed and pushed until the glass shattered.
The lady at the glass shop greeted me and said, "You've been here before, have you?"
Indeed I had been. _________________ Festina lente - hasten slowly
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Mon Jan 08, 2018 6:35 am Post subject: Re: What did you do to your ghia this week? |
kiwighia68 wrote: |
swavananda wrote: |
kiwighia68 wrote: |
Indeed I had been. |
There's no fooling her - the lady behind the counter at the glass shop could apparently see right through you.
kiwighia wrote: |
My glass measurements (11.3 and 11.4cm respectively) are greater than the outside diameter of the ring, ... |
You shoudn't feel too bad about breaking that glass then - it was obviously too large to begin with and must have been under tremendous pressure all squeezed in under that chrome ring.
Posted: Wed Jan 10, 2018 3:02 pm Post subject: Re: What did you do to your ghia this week? |
Hey Flatdude, I'm a cheater too, I use an engine stand and a lift, saves the knees and back, which is good at my age. I also employ the disapearing rear apron method as well on some of my vehicles. Sure like your motor |
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Thu Jan 18, 2018 7:46 pm Post subject: Re: What did you do to your ghia this week? |
So after almost 11 years since i began the tear down for a full restoration of my Ghia, I finally got it over to a painter that accepted the job. Since the body work was mostly done, except for the blocking and final undercoats, I am hoping to have it back in about five weeks....Then the real fun begins!
That said, I need to figure out the best order for reassembly, I assume wiring first. Since many of you have done this, would you care to share your tips on best assembly order? Please respond to this specific request on my resto link below so we don't change this topic. Thanks. _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
PeteSC Samba Member
Posted: Mon Jan 29, 2018 8:03 am Post subject: Re: What did you do to your ghia this week? |
I moved my Optima 6v battery from the engine compartment to underneath the rear seat. Side mount battery tray is from Kartek and fits nicely. The tray is mounted with the terminal side on the raised part of the pan and the battery bottom in the recessed part, so it's at an angle, giving the terminals plenty of clearance from any possible interference. I have terminal covers on order from Amazon as additional insurance.
The Optima is a great performing battery, but doesn't have a vintage look and appears out of place to me in the engine compartment. I think this is cleaner looking.
Laguna1116 Samba Member
Joined: October 04, 2016 Posts: 36 Location: Southern California
Posted: Thu Feb 15, 2018 12:24 am Post subject: Re: What did you do to your ghia this week? |
Bought my first Ghia today. 1973 convertible project. Just planning to reassemble and get her back on the road for now. Can't wait to drive her. _________________ 1961 Sedan Two Fold Ragtop - Recent restoration completed
1968 99.9% Original Sedan - Driver Sold
1971 Super Beetle Convertible - Wife's Driver
1973 Karmann Ghia Convertible - Work in Progress |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13957 Location: Southampton U.K.
Ryma10 Samba Member
Posted: Fri Feb 23, 2018 11:54 am Post subject: Re: What did you do to your ghia this week? |
Purchased my first Ghia this week!!
Posted: Fri Feb 23, 2018 12:15 pm Post subject: Re: What did you do to your ghia this week? |
Awesome! Congrats and welcome!! Looks really good. I have a question, is this a right hand drive or left? I ask because unless I am seeing things, the Karmann badge in the pic is on the left side, I thought they were always on the right side? _________________ 1971 Ghia convertible (Body off rebuild)
2012 Passat-Sold
Altema Samba Member
Joined: June 20, 2010 Posts: 2904 Location: Lower Michigan
Posted: Sat Mar 03, 2018 3:56 pm Post subject: Re: What did you do to your ghia this week? |
I reactivate the insurance and pulled it out of it's slumber. Drove it for a few days while the wife used my daily driver, and it seemed happy to be out on the road again, especially the freeway. |
xzener Samba Member
Posted: Sat Mar 03, 2018 4:38 pm Post subject: Re: What did you do to your ghia this week? |
Mocked up the stock motor today. Still waiting on the Hoover Bit to complete the dog house conversion. The fan is rubbing the shroud, so another shim or two is in order. Went together rather easy. Luckily, I won't need the ugly angled fuel pump or the intake extender. Turned out nice. I do like the flat gloss black look.
