Peter D. Samba Member
Joined: February 25, 2004 Posts: 718 Location: Stamford, CT
Posted: Mon May 07, 2018 1:49 pm Post subject: Re: What did you do to your ghia this week? |
Thanks for the tip. This is great. I was looking at some of my old crusty parts with corrosion and paint over-spray thinking what on earth am I going to do with these?! _________________ 2019 Golf Alltrack, '65 Ghia Coupe Restoration in Progress |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13943 Location: Southampton U.K.
calexican Samba Member
Joined: June 11, 2008 Posts: 727 Location: El Paso, TX
Posted: Sat May 12, 2018 12:34 pm Post subject: Re: What did you do to your ghia this week? |
....I don't think the backdrop for that photo is up to your standards for "Betty" but it looks like a fun show anyway....I don't know for sure what links the three cars, but I would imagine that the house of Karmann has something to do with it.... |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2867 Location: Auckland, New Zealand
Posted: Sat May 12, 2018 1:00 pm Post subject: Re: What did you do to your ghia this week? |
John Moxon wrote: |
calexican wrote: |
:lol: Backdrop is the children's play garden. Could you be more specific about your suggestion John. ;) |
I think John is right about the Karmann connection but I have a question: Is the Porsche a '63 or a '61, '62.
The "Karmann" hardtop 356 was a '61 or '62, I thought. Perhaps carried through on the '63? _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
Posted: Sat May 12, 2018 1:41 pm Post subject: Re: What did you do to your ghia this week? |
kiwighia68 wrote: |
John Moxon wrote: |
calexican wrote: |
Backdrop is the children's play garden. Could you be more specific about your suggestion John. |
The "Karmann" hardtop 356 was a '61 or '62, I thought. Perhaps carried through on the '63? |
Yes it's a '63...the last 356c was 1965 I believe. Yes John is correct...the specifics are all three were built in the same factory, the Karmann factory, Osnabrück. _________________ John.
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Sun May 13, 2018 6:32 am Post subject: Re: What did you do to your ghia this week? |
John Moxon wrote: |
kiwighia68 wrote: |
John Moxon wrote: |
calexican wrote: |
Yes it's a '63...the last 356c was 1965 I believe. Yes John is correct...the specifics are all three were built in the same factory, the Karmann factory, Osnabrück. |
If only you could come and drag the beater/parts status 1996 Audi Cabriolet from my driveway, you could have yet another car built in that very same factory.
(... and I wouldn't have to park my DD a 0.5 mile 12 minute walk away because getting rid of that Audi would free up a spot in my driveway!) |
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Sun May 13, 2018 6:58 am Post subject: Re: What did you do to your ghia this week? |
Why don't you just donate it to one of the veteran organizations or karsforkids.com You get a tax write off and an empty place for your daily.
Just a thought. _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
Jimbuffalo Samba Member
Joined: March 09, 2018 Posts: 8 Location: Buffalo, NY
Posted: Tue May 15, 2018 5:42 am Post subject: Re: What did you do to your ghia this week? |
Drove mine (new to me) for the first time yesterday; Off to get an inspection sticker, mechanical look over today.
Update: Needs a steering coupler to pass...so I clay barred and waxed it instead. |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3804 Location: Georgia
Posted: Thu May 17, 2018 11:43 am Post subject: Re: What did you do to your ghia this week? |
Tore down the old 1915 and here are some interesting problems I found:
The oil pump had worn a groove in the cam gear(or vise versa)
The distributor rotor tang was non existent
The pistons were in the wrong orientation
The distributor shaft showing wear too.
It was also very difficult to turn over by hand. Turned out the main bearings were about to seize. Probably because the oil pump was so screwed up. |
Posted: Thu May 17, 2018 11:50 am Post subject: Re: What did you do to your ghia this week? |
Also repainted the deck.
Posted: Thu May 17, 2018 11:54 am Post subject: Re: What did you do to your ghia this week? |
Also got my Kafer bar installed. What a bitch that was. I had to modify the triangle brackets as the angles were off by about 4 degrees for the pivot arm bars to line up without stress. 6 mounting points in two days? Par for the course I suppose
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1031 Location: Jacksonville, FL
Posted: Thu May 17, 2018 12:29 pm Post subject: Re: What did you do to your ghia this week? |
^^^ Progress is progress, even when it's slow. Good work.
Thanks for reminding me to fit my Kafer brace BEFORE I put the body back on the pan.
Emil _________________ “…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
Posted: Thu May 17, 2018 10:08 pm Post subject: Re: What did you do to your ghia this week? |
Nothing special: Just refitted the original dealer-installed radio. (Yanase was the importer of VW in Yokohama.) I had to do a slight restoration of the plate.
Posted: Sun May 20, 2018 8:21 pm Post subject: Re: What did you do to your ghia this week? |
John Moxon wrote: |
A drive down scary narrow country lanes to take a drink at a Hampshire pub this afternoon.
My wife Jacqui likes the feel of the driver's seat but doesn't drive...
Luv the car, the pose and your photographers eye.
Nice Share. Thanks |
Posted: Mon May 21, 2018 7:39 am Post subject: Re: What did you do to your ghia this week? |
jeffrey8164 wrote: |
John Moxon wrote: |
There's a wife?
Based on the first 500 photos you've posted here, I was under the impression that your beautiful Karmann Ghia was the only love of your life.
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Mon May 21, 2018 11:21 pm Post subject: Re: What did you do to your ghia this week? |
Evil_Fiz wrote: |
Thanks for reminding me to fit my Kafer brace BEFORE I put the body back on the pan. |
Not sure you can do that because the bar goes through the holes in the body _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
Posted: Tue May 22, 2018 9:35 am Post subject: Re: What did you do to your ghia this week? |
kiwighia68 wrote: |
I did the same. Found this radio from a 50’s Porsche in the classifieds, sold as a non working radio, I managed to get the knobs working again, replaced a broken tube, and it turns on now, the light is on and it hums, but no music....yet.... I think it might just need to be grounded properly... I think it looks great in this car. The original radio worked up until a few years ago when the on off switch permanently broke...
Posted: Tue May 22, 2018 11:39 am Post subject: Re: What did you do to your ghia this week? |
calexican wrote: |
kiwighia68 wrote: |
Nothing special: Just refitted the original dealer-installed radio. (Yanase was the importer of VW in Yokohama.) I had to do a slight restoration of the plate...] |
Very nice. I'm waiting for a "quiet exhaust" from Vintage Speed and only after fitting it will I be at the point where I can find a way to play your music in my car. _________________ Festina lente - hasten slowly
