morgan8899 Samba Member
Joined: January 17, 2018 Posts: 32 Location: las vegas
Posted: Mon May 04, 2020 2:44 pm Post subject: Re: What did you do to your ghia this week? |
Installed a roll bar, seats, and move the rear seat area back 4".
kurt912 Samba Member
Joined: October 20, 2014 Posts: 158 Location: The Woodlands Tx
Posted: Sat May 09, 2020 12:46 pm Post subject: Re: What did you do to your ghia this week? |
Moved driving lights back behind the over-rider bars and refinished the rims.
_________________ 1964 MG Midget MK1 Monte Carlo Replica
1969 Karmann Ghia Coupe
1972 Mercedes 250 Coupe |
Rome Samba Member
Joined: June 02, 2004 Posts: 9638 Location: Pearl River, NY
Posted: Sat May 09, 2020 3:46 pm Post subject: Re: What did you do to your ghia this week? |
Lovely Ghia, kurt. Perfect front bumper alignment. Overall stance is appealing- slightly lowered but level. How did you achieve that? Adjustable front beam and slight rear torsion bar realignment? Or was the rear already perfectly set due to "age sag"? I looked at a few other photos of it in your gallery. Have you fitted the F&R HD sway bars? I don't immediately recognize the front lic. plate... could it be M for Madrid, Spain? |
Posted: Mon May 11, 2020 12:19 pm Post subject: Re: What did you do to your ghia this week? |
Rome wrote: |
Hi, I think I'm just picking the right photos- the car is actually about an inch higher in the rear. Stock beam and I have not re-indexed the torsion bars on this car. I did in fact install 3/4 inch sway bars front and back. And the plate is Spanish (lived there for a few months back in the Eighties) but I purchased them off E-bay. _________________ 1964 MG Midget MK1 Monte Carlo Replica
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Mon May 11, 2020 3:37 pm Post subject: Re: What did you do to your ghia this week? |
Tried closing the door gap at the front of my doors, no go. Screamed and swore a bit. Did a dry check of my wiring, some lights came on, flashers flashed (Hazards), one headlight worked, wipers rotated, horn went off and almost blew my eardrum because I just happen to have my head stuffed down into the spare tire area checking the horns. Horn still honks when I connect the ground wire.
Checked that whole set up again and read the entire Sticky on horns, yet they still go off when I flip the key......will attempt going through everything 4-5 more times....
On the positive, some lights worked and nothing melted down, so there's a chance!
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
Vladiiiii Samba Member
Joined: February 24, 2019 Posts: 518 Location: Munich, Germany
Posted: Tue May 12, 2020 6:30 am Post subject: Re: What did you do to your ghia this week? |
Hehe, we're doing stuff at the same time. Just a small tip, for troubleshooting the horn wiring.....Just connect a voltage meter (that beeps), or a test light, instead of the horns.....
I did this on my Bug so that I could really troubleshoot in peace _________________ Vlad's 72 Ghia (Once in a Lifetime Restoration topic)
https://www.thesamba.com/vw/forum/viewtopic.php?p=9237746#9237746 |
Posted: Tue May 12, 2020 8:31 am Post subject: Re: What did you do to your ghia this week? |
Thanks for the tip Vlad, will try that....but still need to track down why the horns are going off at the connection point and not at the steering wheel....something is grounded or not grounded correctly if I can decipher the troubleshooting instructions.
2012 Passat-Sold
FRNKNSTNGHIA Samba Member
Joined: March 05, 2010 Posts: 411 Location: Kissimmee, FL
Posted: Tue May 12, 2020 3:33 pm Post subject: Re: What did you do to your ghia this week? |
Finally got my headliner installed. TMI Vinyl Perforated Headliner. Was a tedious task, but I am more than pleased with the result. It does have clips o n front/rear, but it is all glues in. Should be installing glass this weekend.
Posted: Thu May 14, 2020 10:07 am Post subject: Re: What did you do to your ghia this week? |
Your headliner looks great, I have to do mine eventually... _________________ 1964 MG Midget MK1 Monte Carlo Replica
drlocke Samba Member
Posted: Wed May 20, 2020 6:23 pm Post subject: Re: What did you do to your ghia this week? |
My wife's 1970 Ghia came with a non-functional AM radio. She wanted to listen to her high-school mix tapes while driving. Took many hours to digitize the tapes but then added this $19 bluetooth amp with a cherry friction-fit plate and an on/off switch. Works like a charm and man was it cheap
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3815 Location: Georgia
Posted: Thu May 21, 2020 1:06 pm Post subject: Re: What did you do to your ghia this week? |
Awesome ingenuity!
Luv it! _________________ Volkswagen!
(Compression 8.7:1) |
Posted: Thu May 21, 2020 3:13 pm Post subject: Re: What did you do to your ghia this week? |
Very cool idea! What's the plug in port for, connecting the phone/IPOD, headphones?? Would be much easier to plug in some ear buds when driving a convertible without having to blast the speakers!
2012 Passat-Sold
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Fri May 22, 2020 6:43 pm Post subject: Re: What did you do to your ghia this week? |
rbsurfguy wrote: |
Jeff |
- unless you live in a State that prohibits said action while driving.
bryan _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
Posted: Sat May 23, 2020 4:24 pm Post subject: Re: What did you do to your ghia this week? |
Installed F/R Windshields. Cal-Look seals from West Coast Metric. Purchased seals easily 8 years ago. Been in a bag ever since and no complaints. Rear window took 3 different tries to get it acceptable to my father and mine standards. I guess from learning what not to do during rear install, the front windshield took one try. We used string wrapped around entire seal on the outer grove and one on the inner groove. |
kingkarmann Samba Member
Posted: Tue May 26, 2020 7:51 am Post subject: Re: What did you do to your ghia this week? |
The weather finally dried out enough for a nice Memorial weekend cruise. The local Cars n Coffee felt good enough!
I got to test the tach I got from ISP West. I like it! The clock it replaced is sitting on my bench waiting for a rainy day repair. I might find a way to display it on my desk.
_________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
Posted: Tue May 26, 2020 9:25 pm Post subject: Re: What did you do to your ghia this week? |
Fabricated one block off plate for the intake manifold EGR port, and fab'd another plate for the coolant line elbow from back of cylinder head to heater...
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
lasslo Samba Member
Joined: September 01, 2004 Posts: 206 Location: sweden
Posted: Wed Jun 03, 2020 2:10 am Post subject: Re: What did you do to your ghia this week? |
Got Fuchs _________________ 65 DD klenbus
57 Karmann Ghia |
Posted: Wed Jun 03, 2020 4:06 am Post subject: Re: What did you do to your ghia this week? |
That looks sooooo sweet!
2012 Passat-Sold
Posted: Thu Jun 18, 2020 7:33 pm Post subject: Re: What did you do to your ghia this week? |
Just did a new Generator and voltage regulator (boring I know) but also added a type 3 full circle horn ring which I've wanted for a while.
Probably influenced by the other daily driver...
LVGhia72 Samba Member
Joined: April 22, 2020 Posts: 282 Location: Lost Wages
Posted: Mon Jun 22, 2020 9:59 am Post subject: Re: What did you do to your ghia this week? |
Replaced 48 year old brake hoses.
New hoses from Denmark/Germany?
New/Old
One of the hard line tubing nuts did not want to come off. Broke my wrench on it.
Hard line that would not come off. Used a torch to heat it up, it came off.
Cracked all over.
Since the old hard line tubing nut is all FU. I decieded to order new hard lines.
New hose |
