69 GVert Samba Member
Joined: October 20, 2014 Posts: 61 Location: San Jose, CA
Posted: Thu Nov 12, 2020 10:08 am Post subject: Re: What did you do to your ghia this week? |
kingkarmann wrote: |
My "Winter Pandemic project".
Wow, solid!
I had solids in one of my 914's once. It has Koni Reds in it and every bump kicks my ass... The noise got to be too much for street diving and I went with Sport mounts which are stiffer than stock, but quieter than solids, so a good compromise IMO.
I fought getting the engine out of my Ghia after the red urethane mounts all disintegrated. It was very difficult to get the engine to separate with nothing holding the transaxel in place. I ended up taking the rear cradle off, then replacing the front mount before I was able to finally get the thing out. _________________ Aircooled? Drive one a day, that's all I ask! |
Steelz21 Samba Member
Joined: January 09, 2017 Posts: 130 Location: Ontario canada
Posted: Sat Nov 14, 2020 4:28 pm Post subject: Re: What did you do to your ghia this week? |
Installed fibreglass kick panels from Glass Action for speakers, I went with Rockford Fosgate tri-axial speakers. Not wanting anything too loud, just some background tunes for cruising along.
Installed front sway bar.
Installed hot air hose so my wife can have some heat on her side.
Painted floor pans.
Put the seats, carpet and insulation back after the fuel leak.
Its been a busy weekend. |
Posted: Sun Nov 15, 2020 5:32 pm Post subject: Re: What did you do to your ghia this week? |
Well, I'm back to where I thought I was a couple of months ago!
Back when I thought I could drive it if I got registration/plates etc.
Since then I replaced the transaxel mounts with stock after the red urethane exploded when I drove 10 feet to the driveway and back. Finished the seam sealer and undercoating, repainted some engine tins (as long as it was out...), adjusted the valves points and timing, drained the old oil and added some motor flush and drained again, put in a facet pump under the tank (for priming the mechanical pump since I don't normally leave any gas in it) with a switch hidden under the dash. Oh and I replaced the clutch and seals while the engine was out.
Edit> Forgot to mention relocating the battery under the rear seat.
Today I put in an DVDA with electronic points module, keeping the original for spare. _________________ Aircooled? Drive one a day, that's all I ask! |
obus Samba Member
Joined: March 08, 2001 Posts: 11070 Location: just off Garden State Parkway Exit 81
hanzl Samba Member
Posted: Thu Dec 10, 2020 1:26 pm Post subject: Re: What did you do to your ghia this week? |
I cleaned my clock.
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Thu Dec 10, 2020 6:47 pm Post subject: Re: What did you do to your ghia this week? |
Hanzl, the clock mechanism looks very good. What did you use to clean it? Brake cleaner spray and compressed air? Q-Tips? And what did you use for lubrication- a very thin oil such as "3 in 1"? |
hanzl Samba Member
Posted: Fri Dec 11, 2020 11:58 am Post subject: Re: What did you do to your ghia this week? |
Rome wrote: |
IPA alcohol for cleaning and a small soft brush.
Dried it with low pressure compressed air..
I use a few drops of sewing machine oil and let it run for a night on a 9v battery |
keary_lewis0303 Samba Member
Joined: March 18, 2003 Posts: 98 Location: St Petersburg FL
Posted: Wed Dec 16, 2020 5:15 pm Post subject: Re: What did you do to your ghia this week? |
Just about done with all the major body and rust repairs.
Started disassembly to sand jambs etc. Follow me on Instagram c10etc
kingkarmann Samba Member
Posted: Thu Dec 24, 2020 9:17 am Post subject: Re: What did you do to your ghia this week? |
While I had the engine out I dropped off the tins to Awesome Powdercoat. Clarks shop is about 90 minutes from me. I decided to upgrade from Rustoleum "Hammered" rattle can finish to Eastwood "Poppin Silver Vein" powder coat.
I'm very pleased.
Here's a teaser
_________________ "Depression is a malfunction of the instrument we use to determine reality.
Mike Gerson
What is your "Bespoke Reality"? |
Posted: Mon Dec 28, 2020 3:32 pm Post subject: Re: What did you do to your ghia this week? |
Took some time to strip the powder coating of the ribs of the cast aluminum generator backing plate and coil mounts.
Lots of elbow grease, sanding and polishing but I think the results are worth the effort
Mike Gerson
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13957 Location: Southampton U.K.
Posted: Tue Dec 29, 2020 6:48 am Post subject: Re: What did you do to your ghia this week? |
John Moxon wrote: |
You'll have to fit a set of Gasburners to finish the look. |
Interesting you mentioned Gasburners as they are a favorite wheel of mine
I bought a damaged one several years ago. I thing I paid $25 at a swap. I was trying to get and idea of what they would look like. Ultimately I decided to keep her as classic looking as possible. Another issue was fitment. I have the 67 wide swing axle's along with rebuilt "Z-Bars". I think the offset would work but i wasn't ready to commit pulling the rear suspension and switch axles if it didn't.
My new plan for that lone wheel is to mount some legs and a piece of glass for a man cave style end table _________________ "Depression is a malfunction of the instrument we use to determine reality.
Mike Gerson
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Tue Dec 29, 2020 4:17 pm Post subject: Re: What did you do to your ghia this week? |
This will show you the GasBurners on my 70 _________________ Volkswagen!
Let he that is without oil throw the first rod
(Compression 8.7:1) |
Posted: Wed Dec 30, 2020 8:43 am Post subject: Re: What did you do to your ghia this week? |
jeffrey8164 wrote: |
This will show you the GasBurners on my 70 |
Very nice but I'm now a bit dizzy _________________ "Depression is a malfunction of the instrument we use to determine reality.
Mike Gerson
c21darrel Samba Member
J_Dubz 69 Ghia(s) Samba Member
Joined: December 23, 2020 Posts: 9 Location: Southern California
Posted: Fri Jan 01, 2021 8:33 am Post subject: Re: What did you do to your ghia this week? |
Nice choice on the powdercoat! Looks sweet. _________________ * 1969 Karmann Ghia Coupe aka "Lil Red Devil" - Resto Mod Project start date Jan. 2021
** 1969 Karmann Ghia Coupe aka "Baby Blue" - 4th Owner (3rd Family)
***2012 Passat aka 'Ol Squeaky |
obus Samba Member
kent70ghia Samba Member
Joined: June 15, 2020 Posts: 176 Location: Tacoma, WA
Posted: Sun Jan 10, 2021 6:44 pm Post subject: Re: What did you do to your ghia this week? |
cleaned my speedo, gas gauge, and clock. Clock is running about 20 minutes slow, trying to wake up after not running for 15 years!
fontduroy Samba Member
Posted: Wed Jan 13, 2021 12:57 pm Post subject: Re: What did you do to your ghia this week? |
Rebuilt my first carburetor!
What a great age we live in where there are so many free, excellent resources online. I was able to rebuild the carburetor right the first time with help from schematics I found online.
34Pict-3
I changed out the main jet from 127.5 to 122.5. The engine was running pretty rich (as evidenced from the very black and sooty spark plugs). This was originally a Texas Ghia, and I live in the Denver area. After tuning the rebuilt carb, the car is running smooooothly.
Lessons learned:
1. Rebuilding a carburetor is a) fun and b) not too difficult as long as you keep track of parts and have some resources to reference.
2. Brakleen is some really potent and dangerous stuff. I was wearing nitrile gloves and after about 30 minutes my hands were burning. Badly. I assume that the vapors leaked through the gloves. This was my first time using Brakleen, and I plan on working through the rest of the bottle (maybe) but from now on using something more earth- and human-friendly. _________________ 1974 Karmann Ghia |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2876 Location: Auckland, New Zealand
Posted: Wed Jan 13, 2021 8:50 pm Post subject: Re: What did you do to your ghia this week? |
I've been lazy and to be honest, lethargic. It has been hot this summer, %$#* hot, as Robin Williams announced in Good Morning Vietnam. Ironically, it was the heat that forced me to get off my butt and do some work on my Ghia. It happened like this: I went to play tennis: 4 sets later we gave up due to the heat. On the way home I found that the tar had melted on a newly resurfaced road. The result was tar and small pieces of gravel stuck to my car's inner fender wells. The good news is that I had installed Lokari inner fender liners in front some time ago and that there was protection for the headlight buckets. Still, it took hours to clean off all the tar and gunk. I took the opportunity to re-install my wheels, this time with the centre caps Charley had sourced for me. I had to do a bit of machining to get the caps to fit over the dust caps on the front axle.
I have 3 jobs left: Re-install KPH speedo (reconditioned); replace horn boot; replace glove book lock. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
