obus Samba Member
Joined: March 08, 2001 Posts: 11070 Location: just off Garden State Parkway Exit 81
kingkarmann Samba Member
Posted: Wed Feb 24, 2021 9:21 am Post subject: Re: What did you do to your ghia this week? |
Recently I've reinstalled the engine and revisited the transmission mount install. It's not right
I switched out some worn red urethane mounts with CB Rhino Mounts. I did not remove the transmission. Tough but doable.
If you look closely, I fastened the nosecone mount to the frame using two acorn nuts. I tried re-using the nuts from my old mounts but there is little to no clearance for a wrench or socket using those nuts. The Rhino mount has a thick ridge that is very close to the hole where the frame mounting stud installs.
The acorn nuts were taller (thicker) and I was able get a bit more bite with a wrench. I initially thought the nuts were metric. It turns out they are 7/16" If I were able to get the torque needed I'm sure they would have stripped out. Additionally, the transmission ground strap is not connected to the frame stud. There was no room for that either. It's just a paperweight the way I had it connected.
What to do?
I searched "Rhino Mounts". Several threads were returned with a couple mentioning the clearance issues.
The front studs are 1.5 x 10mm . What I needed was a nut that would stand off enough so I could get a wrench or socket on it.
I found 30mm "coupler" nuts that fit the bill. They also gave me place to fasten the transmission ground strap to the frame.
Problem solved and torqued! _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
pkbghia Samba Member
Joined: February 22, 2017 Posts: 64 Location: Wyomissing Pennsylvania
Posted: Sun Feb 28, 2021 6:15 pm Post subject: Re: What did you do to your ghia this week? |
Thanks to my Samba connection nearby (Charley) I now have a proper fuel tank for my ghia!
While I have the experts checking this out I was wondering what goes trough chassis where I am pointing in the photo?
Fearful for looting I won't provide the GPS coordinates to this basement treasure but I remain in Awe!
_________________ Kurt
1970 Ghia body off restoration in process |
Vladiiiii Samba Member
Joined: February 24, 2019 Posts: 518 Location: Munich, Germany
Posted: Sun Feb 28, 2021 11:40 pm Post subject: Re: What did you do to your ghia this week? |
It's only my humble opinion, but I think that's not an original hole.
I also had a few extra ones, but bought a "rubber plug set" and sealed them up. I also used plugs to cover up the drilled holes needed for spraying cavity wax in some areas.
Best Regards,
Vlad _________________ Vlad's 72 Ghia (Once in a Lifetime Restoration topic)
https://www.thesamba.com/vw/forum/viewtopic.php?p=9237746#9237746 |
Posted: Mon Mar 01, 2021 11:33 am Post subject: Re: What did you do to your ghia this week? |
So..... I drove mine. The first time with numberplates, it's real maiden voyage. I'm really humbled, because 95% works like it should.
It's a high number considering I did everything apart from bodywork .
It didn't really sink in, maybe because it went so well, first try......
I need to sort out the oil cooler thermostat (stuck open), maybe have an allignment done (I used the string method and although it's drivable, I want to be sure that someone in the know checks it), and I have to add an extra ground to the fuel sender (it's ground is hit and miss).
Best Regards, from (finally!) another Ghia driver.
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3818 Location: Georgia
Posted: Mon Mar 01, 2021 4:42 pm Post subject: Re: What did you do to your ghia this week? |
Santa Clause has a Ghia?
Seriously though, I have a 70.
I’m jealous of your gas tank.
I’ll look at mine and see if I have that hole and what if anything is shoved in it. _________________ Volkswagen!
(Compression 8.7:1) |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13957 Location: Southampton U.K.
LVGhia72 Samba Member
Joined: April 22, 2020 Posts: 282 Location: Lost Wages
Posted: Sat Mar 06, 2021 2:17 pm Post subject: Re: What did you do to your ghia this week? |
pkbghia wrote: |
I have a hole in the same location. It looks much bigger than yours. 1972 KG.
Posted: Sun Mar 07, 2021 7:35 pm Post subject: Re: What did you do to your ghia this week? |
Still haven't figured out the hole near fuel filler or the santa siting??!!
This week I did some "stock" work and cleaned up my oil bath air cleaner.
I had some question for the experts regarding how the wire from the thermostat vanes is connected to the oil bath. I have been looking for some pictures but haven't had any luck. Any thoughts?
I plan to reconstruct the whole EVAP system as well.
Marcdeb Samba Member
kent70ghia Samba Member
Joined: June 15, 2020 Posts: 176 Location: Tacoma, WA
Posted: Sun Mar 07, 2021 10:18 pm Post subject: Re: What did you do to your ghia this week? |
PKB, in your 5th picture, there is a bracket by the hose clamp. The cable goes through it, the outer casing is clamped there and the end of the cable loops over the small bar on the filter.
Pic to follow. |
Posted: Sun Mar 07, 2021 10:32 pm Post subject: Re: What did you do to your ghia this week? |
PKB here are pics of the oil bath, and fuel filler hose. There is not a hole like in your pics.. These are from my 70 Ghia, it came stock as an autistic, and I had it converted to a manual. I am the second owner so in those pics, that is how it came from the factory. Kent
Posted: Mon Mar 08, 2021 4:10 am Post subject: Re: What did you do to your ghia this week? |
Thanks for pics and response!
Kent, where is the cable connected after it leave the thermostat vanes on the fan housing? There is a cable connector that looks like it receives a sheet metal screw but I can't figure out where to put it. The outer housing on the cable is in pretty rough shape but I am figuring I can replace it with some cable covering from an old 10 speed bike in my shed!
Kurt _________________ Kurt
Posted: Mon Mar 08, 2021 4:14 am Post subject: Re: What did you do to your ghia this week? |
Marc,
I checked that BAT link and I think I got it. My cable outer housing is a little brittle to make that bend. Will look into the 10 speed. My son does not need all 10 gears!
kurt _________________ Kurt
Posted: Mon Mar 08, 2021 5:14 am Post subject: Re: What did you do to your ghia this week? |
pkbghia wrote: |
Marc,
kurt |
After all, priorities matter! _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
Posted: Mon Mar 08, 2021 9:44 am Post subject: Re: What did you do to your ghia this week? |
Kurt
Here are a couple pics of the entire cable. With that big loop it works, mine is stiff too. And looking at my pis, looks like I need to clean my engine compartment more!
Kent
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Sat Mar 27, 2021 7:15 pm Post subject: Re: What did you do to your ghia this week? |
Did a bunch of little things this last week since the weather was good and not too many online meetings, forgot to take pics of most.
Installed the door window felts, what a hassle, new repops are good, but new repop felt clips suck, some locked in the holes, others didn't and broke. Had a few leftover originals, so used those where the bad ones didn't lock.
Finally got around to adding the front blinker wire covers that route from the blinker rubber to the headlight bucket. Thanks to some Samba members for helping out on those, you know who you are!
The worse thing I worked on was mounting those Bakelite heater extensions that connect from the heat tube under the back seat and then route to the motor. Tried everything to get them over the torsion tubes, definitely something that should be done if you have the body off before remounting. Ended up having to grind down most of the mount area except for where the bolts connect and was then able to slip them into an impossible area. Shoved on them hard, got them to hit the heater pipes, but they weren't going to go flush against the body. May try wiggling them out again and fabricating some kind of spacer with that closed cell foam and try again.
You really can see how many little things there are on these cars when you rebuild from the ground up!! But still fun to learn.....I keep telling myself!!!
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
Posted: Sat Mar 27, 2021 8:07 pm Post subject: Re: What did you do to your ghia this week? |
Jeff,
I learned that lesson myself. I am 3+ years into my 70 body off restoration and I actually posed the question "what things should I make sure I do before dropping the body on?" Unfortunately nobody commented on those bakelite tubes. I also modified with a little creative grinding and made it work.
Learning lots, having fun, soon on the road!
Posted: Sat Mar 27, 2021 8:10 pm Post subject: Re: What did you do to your ghia this week? |
My next project is dropping the engine since my clutch is not clutching and it appears the push out bearing is the culprit. Those little doodangers that hold it in place are likely the problem. I was not too happy with how that installation went.....
Posted: Sat Mar 27, 2021 8:12 pm Post subject: Re: What did you do to your ghia this week? |
Hi Kurt, yep those are the ones. I think I asked previously how to get those things on and believe you posted your pics. I did the same thing based on your pics, thanks for that. I can't find any bolts that match those to mount to the body. Do you happen to have a pic of the bolts or know the size? I'll have to find some maybe a little extra length to reach since I couldn't get the mount base flush against the body wall.
2012 Passat-Sold
