Car32 Samba Member
Posted: Sun Jan 16, 2022 3:20 pm Post subject: Re: What did you do to your ghia this week? |
Fuel-door delete, weld-in panel, Bondo (R) work, sanding, primer, Rust-oleum Satin Moss Green paint.
_________________ First Car = 1970 Westfallen Typ II
Second Car = 1966 Baja
Nth Car = 2006 Cayman S
1971 Karmann Ghia Coupe |
Car32 Samba Member
Posted: Sun Jan 16, 2022 3:25 pm Post subject: Re: What did you do to your ghia this week? |
This was a while ago, but I deleted the turn-signals and installed amber LEDs inside the fresh-air grilles.
Porsche crest is apropos?
MJMarkham Samba Member
Posted: Thu Jan 20, 2022 7:40 pm Post subject: Re: What did you do to your ghia this week? |
test fitting new floor pans
_________________ M J Markham
57 Ragtop Oval, 58 Lowlight Coupe
WANTED: Original 58 Ghia Dash Knob |
Redlabel6 Samba Member
Joined: October 17, 2016 Posts: 381 Location: Minnesota
gorbur Samba Member
Joined: October 10, 2010 Posts: 187 Location: West of Calgary
Posted: Thu Feb 24, 2022 8:22 am Post subject: Right hand Rockers / HC Replaced |
Finally done the replacement of rockers and heater channels. Well over a month but no insurmountable issues. Molding holes and clean up the lower pinch welds to be done. Door gaps finished off at 4mm. Sill plate (trim) clearance slightly more. Top of windshield frame sitting about 4mm from original measure. Hoping the convertible top adjustment / reconstruction will take that out.
The torsion tube hole is smaller than factory but tested removing and it all worked out.
_________________ 73 - Ghia Cabriolet, currently under resto
76 - Type1, 1776, full restomod |
Doug914 Samba Member
Joined: January 18, 2009 Posts: 96 Location: Northern New Jersey
Posted: Thu Feb 24, 2022 9:33 am Post subject: Re: What did you do to your ghia this week? |
Looks like some really nice work. This stuff ain't easy to do correctly as you probably know, but the rewards are well worth it. _________________ 1959 Karmann Ghia
1960 Single Cab
1956 Beetle Oval Window |
Vladiiiii Samba Member
Joined: February 24, 2019 Posts: 518 Location: Munich, Germany
Posted: Thu Feb 24, 2022 10:01 am Post subject: Re: What did you do to your ghia this week? |
Tried to get the thing to idle
When parking it 2-3 times in november before winter sleep, I noticed it's running poorly (maybe on 2-3 cylinders), and decided to tackle it in sping (now).
I checked and replaced dizzy, points, condenser, cap, rotor, plug wires, plugs, cleaned carb, adjusted valves (were spot on), made all no difference....
Now I'm waiting for a compression tester.... _________________ Vlad's 72 Ghia (Once in a Lifetime Restoration topic)
https://www.thesamba.com/vw/forum/viewtopic.php?p=9237746#9237746 |
obus Samba Member
Joined: March 08, 2001 Posts: 11065 Location: just off Garden State Parkway Exit 81
Figment Samba Member
Joined: October 27, 2016 Posts: 218 Location: Connecticut, USA
Posted: Mon Feb 28, 2022 8:57 am Post subject: Re: What did you do to your ghia this week? |
The 1915 I built pre-pandemic is finally in the car.
(yes the carbs conflict with the decklid springs)
_________________ '71 Ghia coupe |
obus Samba Member
Posted: Tue Mar 01, 2022 7:32 am Post subject: Re: What did you do to your ghia this week? |
I'm fairly sure that the air cleaners will prevent those props from falling out of the way as intended, but I've ordered a set anyway. For $40 it's worth a shot even if I do eventually go with a gas strut. _________________ '71 Ghia coupe |
kent70ghia Samba Member
Joined: June 15, 2020 Posts: 176 Location: Tacoma, WA
Posted: Tue Mar 01, 2022 9:14 pm Post subject: Re: What did you do to your ghia this week? |
Worked on clearing the SP intake manifold pre heat tube. Used 1/4 inch wire and a drill, and lots of PB Blaster and carb cleaner. After cleared, painted, now have to put it together.
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Thu Mar 03, 2022 9:08 am Post subject: Re: What did you do to your ghia this week? |
Winter is finally starting to fade a bit, in fact here in St. Louis, MO we broke the high temperature record yesterday for March 2nd with a temp of 82 degrees! Gotta love global warming!
So I dove in and cleaned and then waxed the entire '70 Coupe from front to tail and her chrome bumpers too! A lot of elbow grease expended! She's ready for Spring drives. Now if it would just rain like hell for a few days to wash away all the salt on the roads from the past three snow storms in the last month...
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2874 Location: Auckland, New Zealand
Posted: Sat Mar 05, 2022 4:39 pm Post subject: Re: What did you do to your ghia this week? |
My Ghia, also known as Emiko, is in the workshop for replacement of the gearbox - with a freeway flyer - and replacement of the front beam and drop spindles - with an adjustable beam and original spindles.
The new gearbox was put in this week, and some oil leaks and other minor issues resolved. The car runs sweetly, according to the technician. The work on the beam starts this week.
In the meantime, I'm driving around in a Mercedes A170 and a Honda CRV. Automatic, short of a pedal, easy to get in and out with my sore knee, quiet, safe, power steering, but... boring boring boring. I miss even the discomfort of my 54 year old Ghia.
I think it was Darrel who said the work on these cars never stops. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13952 Location: Southampton U.K.
PeteSC Samba Member
Posted: Sun Mar 06, 2022 10:13 am Post subject: Re: What did you do to your ghia this week? |
Made some windlace for a more finished look.
lasslo Samba Member
Joined: September 01, 2004 Posts: 206 Location: sweden
Posted: Mon Mar 14, 2022 12:11 am Post subject: Re: What did you do to your ghia this week? |
Overload
fitted a AMR500 blower on my 1835cc engine
_________________ 65 DD klenbus
57 Karmann Ghia |
wanted driver Samba Member
Joined: February 07, 2013 Posts: 8 Location: Invermere, BC
Posted: Mon Mar 14, 2022 10:27 am Post subject: Re: What did you do to your ghia this week? |
Did you fabricate the intake(s) to make it lie down? Looks great, would like to do it on my motor. What's the carb you're running? _________________ '70 ghia coupe
closet type 34 fan |
lasslo Samba Member
Posted: Tue Mar 15, 2022 2:44 am Post subject: Re: What did you do to your ghia this week? |
Y
Yes, homemade manifolds. Made by a firend.
Needed the blower to lay down to make room to allmost close the enginelid
It’s not much space to wrench the bolts when mountning
I’m using a weber dcoe 40 carburettor. _________________ 65 DD klenbus
57 Karmann Ghia |
Posted: Tue Mar 15, 2022 5:40 am Post subject: Re: What did you do to your ghia this week? |
That's some nice work. _________________ '71 Ghia coupe |
