Marcdeb Samba Member
Posted: Tue May 03, 2022 6:35 pm Post subject: Re: What did you do to your ghia this week? |
Figment wrote: |
I tripped over my own feet this week.
In the years that I've been working this car, the decklid has never latched-shut. I fussed with it for a while years ago but realized that the release-cable tube was the failure point and just deprioritized it. The weight of the luggage rack was enough to keep it down anyway.
Some interior work prompted me to finally replace that latch-release cable, and in the adjust-test-adjust-test process of course I got it to latch but not release.
*INSTANTLY* kicking myself for not taking care of this while I had the engine out of the car a couple of months ago....
The 20 minute job became a 3-hour job as I had to remove the muffler and exhaust header so I could drill a hole under the latch and trip it open, get things adjusted and operating properly, and weld the hole closed again. |
Been there, done that. It was not my finest hour! _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
ScottDoonan Samba Member
Joined: August 04, 2005 Posts: 546 Location: Northern California
Posted: Mon May 09, 2022 12:38 am Post subject: Re: What did you do to your ghia this week? |
I finally came across a long looked for piece. I was able to set it in place.
_________________ If you take time to do it, do it right and don't be so damn cheap.....🤙🏻
1959 Karmann Ghia Cabriolet (current restoration)
1965 Porsche 356 SC coupe
1967 Volkswagen Convertible Beetle
1969 Porsche 911E Targa 3.2 twin plug
2006 Porsche 987 Rüf 3400K Prototype #2 of 2 |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13952 Location: Southampton U.K.
kent70ghia Samba Member
Joined: June 15, 2020 Posts: 176 Location: Tacoma, WA
Posted: Sat Jun 25, 2022 6:25 pm Post subject: Re: What did you do to your ghia this week? |
Put in an EV4U, delrin shift rod bushing. Makes a huge difference, although it took way longer than planned |
hondatriker Samba Member
Posted: Sat Jul 09, 2022 9:04 pm Post subject: Re: What did you do to your ghia this week? |
1974 GHIA Finished the quarter window rubber install.. Put the lower trim pieces on. Ordered new latches. Headliner yesterday. Put the badge on the right fender.
Quarter window rubber is not fun. 2 of us and almost 3 hours for the first one.
The seal is way too big from the factory. Section that goes n the "B" piller get bigger around when forcing it in and stops the window from going in, Had to cut the flange of the "B" piller part.. It is in the way for the screws to the hinge. It is not needed anyway. Cut it all the way down so the bottom so outside trim will go in. Put the outside trim on before the window so you can get to the screws holes. Glass gets in the way. |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2874 Location: Auckland, New Zealand
Posted: Fri Jul 15, 2022 11:56 pm Post subject: Re: What did you do to your ghia this week? |
I've been without my Ghia since February 1 and only got her back last week. That's a story for my main thread - Saving Emiko. In the meantime, I've done a lot of work in the last week and will start with this as the first instalment:
I had to do a lot of cleaning where greasy hands worked in the engine bay, under the front trunk, on the back of the seats, and on the carpet next to the accelerator.
I started tidying up the wiring. The first thing I did was to relay all the earth wiring on top of the instruments and switches. Then I encased bundles of wires where I could. Here's before and after: (There's more to do.)
And I had to tie down the battery under the back seat.
_________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
nikita Samba Member
Joined: September 16, 2007 Posts: 531 Location: California
Posted: Wed Jul 20, 2022 6:59 am Post subject: Re: What did you do to your ghia this week? |
Pulled it out of storage spot in the hangar and in the open to work on it after a few years. Split engine case, cleaning and measuring everything. Engine ran fine but leaked oil and clutch was slipping a bit, that is why the disassembly. |
PeteSC Samba Member
Posted: Thu Jul 21, 2022 11:37 am Post subject: Re: What did you do to your ghia this week? |
I took it on a 167-mile round trip to VW Drag Nite, and averaged 30.4 mpg with oil temps never topping 190* F in the July heat.
Posted: Thu Jul 21, 2022 12:40 pm Post subject: Re: What did you do to your ghia this week? |
PeteSC wrote: |
Very nice everything.
Great colour, and colour scheme.
Nice roof rack to complement the Ghia lines.
Nice wheels and stance.
All on a lowlight.
What's not to like? _________________ Festina lente - hasten slowly
PeteSC Samba Member
Posted: Fri Jul 22, 2022 4:51 am Post subject: Re: What did you do to your ghia this week? |
kiwighia68 wrote: |
PeteSC wrote: |
All on a lowlight.
What's not to like? |
Thank you, I appreciate the kind words. Though I wish it were its original bamboo/dark green, the green/white has grown on me. |
PeteSC Samba Member
Posted: Fri Jul 22, 2022 11:18 am Post subject: Re: What did you do to your ghia this week? |
Marcdeb wrote: |
Went for a ride to check out the Vermont countryside. These beautiful old barns are slowly disappearing as family farms struggle to compete.
Lovely Ghia and scenery! |
Steelz21 Samba Member
Joined: January 09, 2017 Posts: 130 Location: Ontario canada
Posted: Mon Jul 25, 2022 5:06 pm Post subject: Re: What did you do to your ghia this week? |
Installed bulllet mirrors without drilling any holes. After much searching I found these Astrali brand mirrors which have a 36 mm mounting hole spacing. I took a chance on shipping them from the UK but they made it in one piece as they were well bubble wrapped. Easy install and IMHO they look so much better and match the cars shape.
I think they are meant for a classic mini but don’t quote me on that one.
E-bay UK, less than $100 CDN including shipping, so I had to take a chance. |
kingkarmann Samba Member
Posted: Thu Jul 28, 2022 7:31 am Post subject: Re: What did you do to your ghia this week? |
The 67 Coupe has been feeling a bit neglected lately so I bought her a small gift to spruce up the engine room.
Ross Wulf Locking Dipstick to match the graphite grey scheme.
Totally unnecessary but I like it anyhow
_________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
crocteau Samba Member
Joined: March 31, 2005 Posts: 1204 Location: Philaburbia
Posted: Thu Jul 28, 2022 9:34 am Post subject: Re: What did you do to your ghia this week? |
kingkarmann wrote: |
The 67 Coupe has been feeling a bit neglected lately... |
👍 Very nice. Just curious: are you pulling the vacuum advance from both carbs? |
Posted: Thu Jul 28, 2022 1:27 pm Post subject: Re: What did you do to your ghia this week? |
Nice bit of engine jewelry. |
Posted: Thu Jul 28, 2022 1:40 pm Post subject: Re: What did you do to your ghia this week? |
crocteau wrote: |
Thanks!
No, just the left side. _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
Posted: Thu Jul 28, 2022 2:05 pm Post subject: Re: What did you do to your ghia this week? |
A little engine bay jewelry of my own. JDM fender bolts from E-Bay
New, better looking tool bag. Looks way more appropriate. From Amazon
Spun up some vent knobs in my battery drill lathe. From Scrap bin. |
Posted: Sun Aug 14, 2022 12:20 pm Post subject: Re: What did you do to your ghia this week? |
What is that machined silver thing front and centre of both wiring pictures?
Speedo cable compensater ?
Andy
kiwighia68 wrote: |
