kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2877 Location: Auckland, New Zealand
Posted: Sun Oct 09, 2022 3:53 pm Post subject: Re: What did you do to your ghia this week? |
mouse action wrote: |
Generation Gap
That is a really beautiful Ghia - and the Beetle ain't bad either.
I stole a pic of an aircooled and colour-matched Beetle some time ago.
_________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Mon Oct 31, 2022 4:44 pm Post subject: Re: What did you do to your ghia this week? |
My 30+ year old amplifier malfunctioned. Can’t find anyone to fix it so I got new.
Here’s the old picture.
Had to recover the amp stand etc.
Here’s the new setup.
More Watts really woke it all up. _________________ Volkswagen!
(Compression 8.7:1) |
Posted: Tue Nov 01, 2022 12:21 am Post subject: Re: What did you do to your ghia this week? |
Due to my steering couplers slipping when I turned the wheel under load, I needed to replace the steering couplers. Seen here from above after the gas tank had been removed.
Off with the old:
On with the new:
The rag/rubber damper also had to be replaced: seen here before the nuts and bolts had been tightened:
After checking the everything is A-okay, the gas tank goes back in:
with one new hose:
Two and a half hour labour. _________________ Festina lente - hasten slowly
gorbur Samba Member
Joined: October 10, 2010 Posts: 187 Location: West of Calgary
Posted: Thu Nov 03, 2022 4:51 pm Post subject: Re: What did you do to your ghia this week? |
It's been 8 weeks since the paint went on with the last two weeks spent assembling. Other than the CV's, all fun. It's all new or rebuilt with just a ground cable left to do. Used PU trailing arm and spring arm bushings. Very liberally greased with silicone PTFE grease. Other than that it's all OG spec.
The weird bends on the rear brake line was more to preserve the factory flare rather than cutting it down to size and botching the bubble flare.
I didn't like hanging front suspension with no weight on it. It bound the ball joints. A threaded rod and eyebolt pull's it up until it becomes a rolling chassis. It's reassuring using quality parts ATE, FAG, Meyle, Zimmerman etc. The values in the predictability of assembly. If something isn't pressing on quite right, I know it's my fault not the parts.
Great thread on the Type 3 forum on rebuilding the steering box. Immensely helpful.
This get bundled up and back onto the body work.
_________________ 73 - Ghia Cabriolet, currently under resto
76 - Type1, 1776, full restomod |
todmeg Samba Member
Joined: November 26, 2005 Posts: 252 Location: new jersey
Posted: Mon Nov 07, 2022 6:55 pm Post subject: Re: What did you do to your ghia this week? |
So the 71 is finally in the resto- process! Soooo….. have new rust parts for the lower fenders on order. They are in Frankfurt, awaiting a plane ride to the states. Funny but no matter hard I search, I can’t find a smiley face remotely close to how excited I am for this restoration!!! _________________ 1770 DP Bad ass heads dual weber 40mm 010 headers and glass pack. Rivieras. 1971!!! |
gorbur Samba Member
Posted: Sun Dec 04, 2022 3:24 pm Post subject: Re: What did you do to your ghia this week? |
Drivers side rear quarter area repaired.
Typical to many Ghia's it didn't look too bad from 10 feet away.
Surprisingly the inner bumper bracket was sound but the rest either paper thin or non-existent. The rusty bit on the valence I patched after I had the inner bumper bracket replaced.
Epoxy primed and seam sealed. I'm not certain what the oblong hole is for on the wheel well is for but will fashion a rubber plug for it later.
The panels were from Jopex. The fit was pretty much perfect. The only issue was the indent for the bumper had too large of an arc to match the squarer bumper.
Primed and ready for the finer finishing at a later step. _________________ 73 - Ghia Cabriolet, currently under resto
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Sun Dec 04, 2022 4:11 pm Post subject: Re: What did you do to your ghia this week? |
Quote: |
I'm not certain what the oblong hole is for on the wheel well is for |
Likely a tooling remnant from the earlier bumpers thru '71, to attach the front bolt for holding the front end of the bumper side "spear". Yes, a suitable plug with a thin outline of seam sealer will be sufficient.
Nice work on this repair. |
gorbur Samba Member
Posted: Sun Dec 04, 2022 5:35 pm Post subject: Re: What did you do to your ghia this week? |
Thanks Rome. Good to know what its purpose was. Even better to know I can safely plug up a source of trapping water. _________________ 73 - Ghia Cabriolet, currently under resto
Figment Samba Member
Joined: October 27, 2016 Posts: 218 Location: Connecticut, USA
Posted: Wed Jan 11, 2023 7:01 am Post subject: Re: What did you do to your ghia this week? |
I've had the engine out for a bit now. (the 1915 pulled studs so I made a 1641 from parts-on-hand)
In a strikingly uncharacteristic move, before installing the 1641 I took a breath and remembered to correct the alignment of the decklid latch while it was accessible from inside the compartment. Huge personal-growth moment.
The decklid actually latches-shut now for the first time since the paintjob over a decade ago. _________________ '71 Ghia coupe |
Exnermobiles Samba Member
Joined: September 14, 2010 Posts: 64 Location: Finland
Posted: Sun Jan 29, 2023 1:28 pm Post subject: Re: What did you do to your ghia this week? |
Just got my seats from the upholsterer.
These are for a 1962 Pacific Blue coupe with ice blue vinyl and turquoise cloth inserts. The vinyl and cloth come from SMS. At the time when I ordered that cloth SMS did not have correct turquoise available. So, I decided to dye them by myself.
I gave some written instructions for the upholsterer on how to imitate the details of the original seat covers as close as possible. I think he did quite good job:
_________________ 1962 Karmann Ghia Coupe
1958 Plymouth Belvedere Sport Coupe
1959 Dodge Sierra STW |
Posted: Sun Jan 29, 2023 8:08 pm Post subject: Re: What did you do to your ghia this week? |
Those look great!
Looks like you have a good upholsterer.
The good one I used to know, sadly is gone to the gods. _________________ Volkswagen!
kingkarmann Samba Member
Posted: Mon Jan 30, 2023 12:54 pm Post subject: Re: What did you do to your ghia this week? |
What a beautiful result!
Definitely inspiring. _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13958 Location: Southampton U.K.
Marcdeb Samba Member
Posted: Sun May 07, 2023 5:05 pm Post subject: Re: What did you do to your ghia this week? |
First ride of the season. Went for an eight mile drive. She's far from finished, but she's drivable. I was excited that the engine started easily and ran flawlessly. Made for a great day.
_________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
blue72beetle Samba Member
Joined: April 23, 2008 Posts: 846 Location: Fort Wayne, IN
Posted: Sun May 14, 2023 6:27 pm Post subject: Re: What did you do to your ghia this week? |
Chasing an exhaust leak I decided it's time for an exhaust refresh. Only broke one bolt.
_________________ -Andy-
-1970 Ghia-
-1971 Bus 1776 Microsquirt EFI- |
Posted: Tue May 16, 2023 7:08 pm Post subject: Re: What did you do to your ghia this week? |
Replaced the points, condensor, rotor, and cap today. Then it just WOULD NOT START. Checked the points gap a hundred times. Checked coil voltage. Couldn't figure it out. So I started replacing parts with the old parts. Finally got to the points, and it fired up on the old original points. The new ones were NOS "Ikar" brand. What crap parts. _________________ -Andy-
-1970 Ghia-
n1 Samba Member
IN2VWS Samba Member
Joined: January 29, 2006 Posts: 2521 Location: Australia
Posted: Sun Jun 18, 2023 6:12 pm Post subject: Re: What did you do to your ghia this week? |
Finally fitted LED's to the taillights so people can see them.
_________________ ( ⫏ ⫐ )
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³ |
