Bay Window Steve Samba Member
Joined: July 13, 2006 Posts: 280 Location: Van Alstyne, Texas
Posted: Sun Jun 22, 2008 8:39 pm Post subject: Working on the Barn Find today, wiring questions w/pics. |
Well, me and Kirk were going to work on the '79 today, but apparently no local parts places had anything I need. My question is about some wiring things. I have several manuals and I'm looking where all these rat chewed wires need to be. Any help you can give is help full.
First off is all the wires from the coil.
Second is this one that has a fuse at the end. Second pic is where it comes from.
Last is this wire next to the distributor.
Last is some random big wire coming from the middle.
Coming from....
So basically I got lucky. Aside from the side marker light wires, these are the only four (not counting the plug wires) wires chewed through. So tell me this is easy, and where they go. _________________ '73 Transporter - Driver
'69 Deluxe
Member: WTKHABG
Original Air Cooler Member |
TheTominator Samba Member
Joined: February 20, 2007 Posts: 898 Location: HICKORY, NC. USA
Posted: Sun Jun 22, 2008 8:59 pm Post subject: |
If you need a correct answer now BWS, a search will yield the answer. I'm sort of in my cups, but I will toss out this potentially incorrect answer, Four wires equal two disconnected wires? It seems to my memory that the wire from the dizzy goes to the negative side of the coil? The other two wires hook up to each other. _________________ "A foolish faith in authority is the worst enemy of truth" Albert Einstein - 1901
If I can't curse, I can't fix it.
71 Bus
78 HD FXS Lowrider 1200cc
An Oldsmobile for crying out loud. |
dweller Samba Member
Joined: May 31, 2007 Posts: 819 Location: Chapel Hill, NC
Posted: Sun Jun 22, 2008 9:08 pm Post subject: |
I just took a look at my '77. The second pic's fused wire leads to the coil, 15 terminal. I think it has to do w/ backup lights. Do your's work?
Mine has 3 wires leading up the fuse, 2 exiting rear, one goes back to the loom, the other to the coil.
the other fused in mine runs the auxiliary fan, in your last pics. Not sure if that's the same in yours.
regardless, you need an engine seal. Don't leave home w/out it.
dp _________________ 77 Westie 2.0L FI ... slowly restoring bit by bit... |
Posted: Sun Jun 22, 2008 10:05 pm Post subject: |
1. You need power from the ignition switch to the positive side of the coil. I think the original wire is black.
2. You need a wire running from the negative side of the coil to the distributor. This wire comes with the condenser when you buy it. This wire is usually green.
3. You need a wire telling the FI telling it how often to fire the injectors. This wire also hooks to the negative side of the coil. This wire is usually white.
4. The backup light circuit feeds of the positive side of the coil and through a black inline fuse. This wire is black.
The wire disappearing through the tin in front of the dizzy is for the oil pressure warning light. Don't remember its color right off. |
Karl Samba Member
Joined: January 29, 2001 Posts: 6170 Location: Coos Bay, Oregon
Posted: Sun Jun 22, 2008 10:41 pm Post subject: |
In this picture, the white wire goes from the neg side over to the pass side of the bus. There should be a single wire cut off in the FI harness just about 8" from the ECU plug.
From the harness up by the heater fan, you should have 2 cut-off wires. One should be black. It is ignition on B+. It goes to the pos side of the coil. The other black wire on the pos side goes to the in-line fuse that is laying where a battery would go on the drivers side. That black wire feeds the fuse AND goes to the double relay to power it. The other end of the fuse goes to the reverse switch on the trans.
The other cut-off wire goes to the oil sender. In this pic:
I need more info on that last picture..... |
Bleyseng Samba Member
Posted: Mon Jun 23, 2008 5:03 am Post subject: |
That is correct! plus looks like you need a plug wire set. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
Posted: Mon Jun 23, 2008 7:11 am Post subject: |
Karl wrote: |
What do you need to know?
Thanks for the info guys. _________________ '73 Transporter - Driver
'69 Deluxe
Member: WTKHABG
Posted: Fri Jun 27, 2008 8:31 am Post subject: |
Well worked on the wiring some yesterday, thanks for all the info. I found where the white wire went, and that bigger black wire from the fan. What I haven't figured out yet is that wire in the last picture Karl was asking about. Upon cleaning, it looks like it goes to a sensor of some sort. Oil temp perhaps? Still havent hooked it up yet. The fuse link on the drivers side has one wire coming into it, but another short wire coming right back out on the same side it goes into. Like there should have been two wires going in. I took some other pics, just need to upload them.
Replaced plugs, wires, reconnected vaccum lines, replaced all the fuel lines I found. Today (I work 8-6, so little time to tinker in the evening after dinner, playing with the kids and dogs) I'll hook up the other wires, and the new battery, and see what happens when I try to turn it over. _________________ '73 Transporter - Driver
'69 Deluxe
Member: WTKHABG
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Fri Jun 27, 2008 9:19 am Post subject: |
Red flag!
There's no engine compartment seal. This indicates certain PO neglect and potential abuse. Proceed with caution. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
peaceful warrior Samba Member
Joined: January 22, 2005 Posts: 5274 Location: Taoswest, USA
Posted: Fri Jun 27, 2008 8:02 pm Post subject: |
Check this link and if you click on it to enlarge it, you can print it out on 2 pages. It will help you ID the wiring. They are PITA to follow, much easier if you had the Bentley book as it is in color I believe.
http://www.thesamba.com/vw/archives/info/wiring/baybus_79.jpg |
Posted: Sat Jun 28, 2008 10:05 am Post subject: |
Okay, found where all the wires go (I'm pretty sure) and when I hook the battery up, the battery light on the dash stays on, regardless of if the key is on or not. Turns over, wont start. Ideas? _________________ '73 Transporter - Driver
'69 Deluxe
Member: WTKHABG
Karl Samba Member
Posted: Sat Jun 28, 2008 10:08 am Post subject: |
I wanted more info on this pic:
Posted: Sat Jun 28, 2008 11:55 am Post subject: |
Karl wrote: |
It was the main one from the blower fan, which I hooked to the pos side of the coil. _________________ '73 Transporter - Driver
'69 Deluxe
Member: WTKHABG
Posted: Thu Jul 03, 2008 6:30 am Post subject: |
I Here is a pic where that wire goes.
'69 Deluxe
Member: WTKHABG
2VWs1BMW Samba Member
Posted: Thu Jul 03, 2008 6:42 am Post subject: |
oil press sender? _________________ - Brian -
'17 Alltrack
'99 ///M Coupe w/48k mi - Bimmerforums
'77 Westy w/156k mi |
Posted: Thu Jul 03, 2008 8:33 am Post subject: |
That is exactly what I was thinking. _________________ '73 Transporter - Driver
'69 Deluxe
Member: WTKHABG
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51155 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Jul 03, 2008 10:26 am Post subject: |
Yes, oil pressure switch.
You need to get serious with the shop vac in there before you fire that bad boy up, I can imagine the crap flying everywhere. Looked through the spark plug access holes at the tops of the heads, cylinders and oil cooler for where those rodents were living yet? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Jul 03, 2008 12:17 pm Post subject: |
I have, with no luck. I did however have a buddy point my Echo 24cc leaf blower in there while wearing a mask, and made a BIG OLE mess. He did manage to blow some crap out, but there is still more there. _________________ '73 Transporter - Driver
'69 Deluxe
Member: WTKHABG
