Franklinstower Samba Member
Posted: Thu Mar 05, 2009 10:38 am Post subject: |
hiram6 wrote: |
tschroeder0 wrote: |
Perfect, thank you!
If making up some backet sets please PM me with cost, I'll send it right out. Todd. |
Yep, same here. Very interested in brackets ans maybe also in the modded 5x112 rotors, although I know shipping weight would be heavy. |
Maybe you could order new Rotors through Schucks/O'reilly for pick up at the store near Jeff - He could modify them and ship them to you along with the brackets. Then you would only have to have the hubs modified.
The rotors are cheap: $24 for bendix - $25 for Raybestos each.
http://shop.oreillyauto.com/ProductList.aspx?PartType=2352&PTSet=A
Shipping can't be that much - $20-$30?
Of course I am speaking on a 'What if' basis for Jeff with out his knowledge - I am sure he will chime in with what he can offer.
I think this is such a great set up I want to see it installed on more Vanagons!
Paul _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug |
Posted: Thu Mar 05, 2009 10:43 am Post subject: |
One more thing - Anyone interested in a rear disc set up should check their local pull-a-part yards for Vanagon rear hubs - I bought mine for $14 for the pair. that way you can have them modified while you keep your rig on the road. _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
jeremysmithatshawdotca Samba Member
Joined: February 11, 2002 Posts: 2530 Location: Edmonton, AB
Posted: Thu Mar 05, 2009 11:33 am Post subject: |
Out of curiousity, which Passat rims have you got Franklin? And what did you have to do to get them to fit properly? |
Petervw Samba Member
Joined: July 04, 2005 Posts: 1020 Location: Sarnia Ont. Canada
Posted: Fri Mar 06, 2009 10:46 am Post subject: |
Is there a way to check the rear calipers to see if they are NOT siezed when useing the scrap/recycling yards...A lot of Ford and Gm calipers will seize prematurely when the brake fluid has not been changed on a regular basis |
danfromsyr Samba Member
Posted: Fri Mar 06, 2009 1:24 pm Post subject: |
the easiest and maybe more or less reliable is to pull the parking brake up hard then release..
if you can not turn the wheel easily by hand then it's likely sticking.
Dan
Petervw wrote: |
Abscate wrote: |
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Fri Mar 06, 2009 2:22 pm Post subject: |
This is to much of an ad, they go in the classifieds.
If anybodys intrested PM a914622 directly. |
