daSCHISSnit Samba Member
Joined: January 22, 2003 Posts: 334 Location: San Diego, CA
Posted: Sun Apr 27, 2003 7:51 pm Post subject: Exhaust Question |
Will a late model fuel injected exhaust fit on a normally aspirated motor? |
mbugz60 Samba Member
Joined: November 26, 2000 Posts: 1366 Location: St. Martinville, Louisiana
Posted: Mon Apr 28, 2003 10:11 am Post subject: Exhaust Question |
A chrome one will bolt up nicely, but the painted ones don't line up correctly.
You will have to shove a potato in the exhaust tip so it can build up horsepower. When you hear the potato shoot out like a cannonball that means the exhaust is correctly fitted to the engine. |
bljones Resident Wit
Joined: February 08, 2002 Posts: 2377 Location: ontario canada
Posted: Mon Apr 28, 2003 11:01 am Post subject: Exhaust Question |
Assuming you are talking about a beetle, the simple answer is "it depends." Smog laws may not allow it where you live. carbureted exhaust systems are designed to bolt up to manifold heat risers, which a fuel injected car does not have, so a later exhaust may not work on an earlier car. |
aircooled_mechanic Samba Member
Posted: Mon Apr 28, 2003 5:10 pm Post subject: Exhaust Question |
Thank you mbugz60, for that shining example of why it is important for kids to breath clean air when they are young. |
Posted: Mon Apr 28, 2003 5:30 pm Post subject: Exhaust Question |
Where in the hell do you find clean air? |
Posted: Mon Apr 28, 2003 5:34 pm Post subject: Exhaust Question |
If you are an aircooled mechanic you should have answered the question, or maybe exhaust systems aren't your specialty. |
Richard Nigerian Scammer Trainee
Joined: January 23, 2003 Posts: 263 Location: Totally Lost
Posted: Mon Apr 28, 2003 5:42 pm Post subject: Exhaust Question |
should I use the small red "boiling" potatoes, or will the large "Baking" style work better ? |
Posted: Mon Apr 28, 2003 5:44 pm Post subject: Exhaust Question |
For the best results use the big baking potato. |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Mon Apr 28, 2003 5:57 pm Post subject: Exhaust Question |
******crackling voice over the intercom****
"Everett, clean up on isle nine,!!!" |
Posted: Tue Apr 29, 2003 8:51 am Post subject: Exhaust Question |
mbugz, if you will reference the "superbeetle" forum, you will find that I did answer his question. |
Posted: Tue Apr 29, 2003 9:16 am Post subject: Exhaust Question |
I stand corrected. You did answer his question. I seldom go to the sb forum.
You never did say where you can find clean air. Down here in Louisiana you can see the cancer floating in the air. |
Posted: Tue Apr 29, 2003 12:50 pm Post subject: Exhaust Question |
I think you can still find clean out in the wilderness of Alaska, or maybe when you are 100 miles out to sea??? |
