BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Tue Jun 24, 2008 7:17 pm Post subject: new Brosol fuel pump, pump rod, and high pressure |
I decided to put on a new fuel pump so I went and bought the latest Brosol that is being offered along with the corresponding rod with a length of 107.5 mm or 4.31 inches. The top outlet is dumb because it's aimed right at the throttle, but whatever.
I test ran it for leaks and it started right up. When I got back from a cruise I checked for leaks again and found fuel dripping big time out of the throttle. I pulled the gas cap off and no whooshing and it's a real VW one also. Leaving the cap off I pulled the hose off at the carb and fuel shot out like a hydrant spraying everywhere. There's a lot more to say but the upshot was I bought another one thinking I'd gotten a lemon plus I didn't like the "up" outlet. The new one said to use the 107.5 mm rod so I did and it has the pipes in a more copacetic arrangement.
Same problem: sky high pressure. I changed 3 different new needle/seats, 2 different floats, extra gasket on the needle but to no avail. It still runs down the carb while running and after shutoff. I've measured all the ways the Bentley says to but the short or long rods are all different than the OG VW rod. I've written down all the measurements. I went and bought a new fuel pressure gauge and the pumps are putting out 14 psi while cranking the engine.
I really need some help.
my65vert Samba Member
Joined: November 09, 2003 Posts: 6186 Location: Middleburg, Florida
Posted: Tue Jun 24, 2008 7:24 pm Post subject: |
Going through the exact same thing right now. Same pump as your first pic and one of the old style rebuildable pumps.
I think a holley fuel pressure regulator will be the trick. _________________ OGJHC
Kombisutra;
I'm starting to get little wafts of bus stink coming from the north. Something about the unique scent of drivers seat padding when it's glued together with mouse piss and shit that really gets me going... and I'm smelling it! Oh yeah! Time to start loading up the equipment. |
sloans265 Samba Member
Posted: Tue Jun 24, 2008 7:27 pm Post subject: |
I have found that not only are the aftermarket rods sometimes longer than og VW rods. But also the aftermarket fuelpump stands can be "shorter" than the og one which makes the rod push up even farther. I remedied the problem by installing an od rod and stand to get my pressure back down to a "manageable" range before shimming it with gaskets. _________________ 1970 Lotus White Panel
In search of any Pensacola Fla dealership items |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76904 Location: Sneaking up behind you
Posted: Tue Jun 24, 2008 7:29 pm Post subject: |
Try adding a few gaskets under the pump base to lower the fuel pressure. You could also grind down the pushrod a little.
Personally, I hate those pumps. They look like crap. _________________ Glenn
Member #1009
#BlueSquare |
BarryL Samba Member
Posted: Tue Jun 24, 2008 7:41 pm Post subject: |
The lever is .3200 up inside the case. The rod sticks up at it's lowest .4218 which means the pump is already engaged upon boltdown. If I put in my middle length one that starts to protrude at .2500 and rises to .3906 the pump only lifts .7000 but has a gap of .7000 before the rod hits. This configuration yields 4 psi; still too high. What is going on? I've researched the rod length vs pump for 4 days and they all say to use the 107.5 mm length. |
Glenn Mr. 010
Posted: Tue Jun 24, 2008 7:46 pm Post subject: |
The rod should be 108mm according to the VW micro fiche. does the pushrod looks like it was made with a pencil sharpener?
The new aftermarket rods look like crap. _________________ Glenn
Member #1009
#BlueSquare |
Culito 11010101
Joined: December 07, 2006 Posts: 5865 Location: Columbia Missourah
Posted: Tue Jun 24, 2008 9:33 pm Post subject: |
I put one of those pumps on my engine...I think they have way more pressure than the stock pump out of the box.
I had to put a thick-ass gasket underneath mine, otherwise it would shoot fuel out of the top of the carb and flood the engine immediately.
That and the outlet points directly into the carb base flange of the manifold, and the fuel line rubs there.
Yeah, they blow (too much). _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
mynameismud Samba Member
Joined: October 23, 2002 Posts: 5923 Location: Middle of a corn field
Posted: Wed Jun 25, 2008 7:12 am Post subject: |
BarryL wrote: |
I had this issue also- on one of my new brosol pumps- broke the lever instantly. I picked up an OG rod and installed another brosol- no problems so far (at least with the pump) _________________ Even YOU can prevent FIRES!
Click to view image |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12408 Location: Over 2002 posts deleted!
Posted: Wed Jun 25, 2008 7:16 am Post subject: |
bill may wrote: |
need an original german fuel pump that you can get a wolfsburg west rebuild kit for Barry? i have some (pierberg from 67 beetles) |
You coulda fixed him up in our forums at first try! _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Wed Jun 25, 2008 8:00 am Post subject: |
pyrOman wrote: |
bill may wrote: |
You coulda fixed him up in our forums at first try! |
Barry don't seem to ask on www.sv2s.com - so i come here trying to help him. Dan E. has some parts also,but Barry is determined to do it the samba way. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
BarryL Samba Member
Posted: Thu Jun 26, 2008 8:40 am Post subject: |
Glenn wrote: |
The new aftermarket rods look like crap. |
I have a 108mm and a 107.5mm. Yes the 108 is the pencil one. In either case those long rods do not coincide with the Bentley block-gasket-stand-gasket measurements. The Bentley says .31" up to .51" inch for the og rod. What is the 108mm rod supposed to be as far as rise? |
BarryL Samba Member
Posted: Thu Jun 26, 2008 7:23 pm Post subject: |
Ok my local auto parts house had this. It is all new and not rebuilt and looks very husky in the casting, pin, and other materials.
It did not come with a rod however. This pump is recessed .3000" and my German original was .3100" but it could have been worn down. The 108 mm rod rises from .4375" up to .5781" : obviously way too high. Does anyone have the specs for how high the 108mm is supposed to be or is mine normal? How long is the rod that rises from .3100" up to .5100" supposed to be? |
hsosa1 Samba Member
Joined: January 17, 2005 Posts: 1897 Location: Fontana
Posted: Thu Jun 26, 2008 7:43 pm Post subject: |
that fuel pump looks like the old bocar brasilia pumps. the new bocars are crap. I ended up going with a german fuel pump rebuilt it . _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
Culito 11010101
Posted: Thu Jun 26, 2008 7:50 pm Post subject: |
BarryL wrote: |
That looks alot better than option #1. _________________ Copyright CJ Industries, Inc.
'62 bug
johnnypan wrote: |
Glenn Mr. 010
Posted: Thu Jun 26, 2008 7:53 pm Post subject: |
Here's another twist... the aftermarket Bakelite base are lower than the original ones. This will also raise your fuel pressure. _________________ Glenn
Member #1009
#BlueSquare
type241 Samba Member
Joined: June 02, 2006 Posts: 971 Location: MOSES LAKE, WA
Posted: Fri Jun 27, 2008 5:57 am Post subject: |
Fuel pump creates oil pressure? |
pyrOman Fire Master
Posted: Fri Jun 27, 2008 6:07 am Post subject: |
Glenn wrote: |
Here's another twist... the aftermarket Bakelite base are lower than the original ones. This will also raise your oil pressure. |
How so? _________________ Some people are so busy being clever they don't have time enough to be wise. |
Glenn Mr. 010
Posted: Fri Jun 27, 2008 6:11 am Post subject: |
type241 wrote: |
Fixed. _________________ Glenn
Member #1009
#BlueSquare |
pyrOman Fire Master
Posted: Fri Jun 27, 2008 6:15 am Post subject: |
'So'right! _________________ Some people are so busy being clever they don't have time enough to be wise. |
