mysticalclimber Samba Member
Posted: Sat Jun 28, 2008 9:03 am Post subject: Restoration Shop paint from Tcpglobal.com |
Has anyone used the Restoration Shop from tcpglobal? It's there in house paint and appears to have good reviews on their webpage (of course!) but I can't find anything about it anywhere else. I'm wondering how the color match is? and how long I can expect it to last (for the single stage urethane)?
I'm thinking about using the PPG epoxy primer (DP) because it's supposed to be really good for protecting the metal from elements and then using something cheaper like matrix or restoration shop. This paint job is basically to protect it from rusting - in other words not a show car.
Also, will a gallon be enough for a vanagon?
Thanks! |
RWalker Samba Member
Joined: June 25, 2008 Posts: 11 Location: Flowery Branch, Georgia
Posted: Sat Jun 28, 2008 12:01 pm Post subject: |
PPG has a line of commercial paint that is high quality but inexpensive because it is only available in about 30 colors or so. That's a good option. Omni is the lower grade PPG paint and is pretty decent and much less expensive. If you are going with a good primer, go with a good paint that will be a solid base for a higher quality paint later. _________________ Late Nite Customs
Flowery Branch, Georgia |
DaKine Samba Member
Posted: Sun Jun 29, 2008 5:48 pm Post subject: |
I've used TCPGlobal a couple times. I just used their urethane primer this week and it worked fine. I painted a car with their Restoration Shop 'Dove Gray' base coat clear coat kit and have to admit the color layed really nice but I had trouble with the clear coat. I'm going to try a single stage paint from them next. You definately can't beat those prices. |
Posted: Thu Jul 03, 2008 3:05 pm Post subject: |
Van is in the paint booth- buying the paint next week. Decided after talking to a few people here, and a few different paint stores to go with nason single stage urethane. I'll post pics after I spray it:
Here's an picture taken the day I bought it.
marklaken Samba Member
Joined: March 19, 2004 Posts: 2416 Location: fort collins, CO
Posted: Mon Jul 07, 2008 10:31 am Post subject: |
I was very unsatisfied with TCP's pearl white (single stage acrylic eurathane) - it was WAY too yellow - being that they are an online vendor, i didn;'t even try to get them to adjust the tint, nor did I try to go to a paint shop with it and have them tweek it -
i thought it layed down better than the dupont centari pearl white that I used instead (and centari is a much closer but not perfect match)...TCP's paint seemed like high quality paint (my first time sopraying automotive paint)...I think it is a good deal for someone not looking to duplicate a factory color (the creamy yellow "pearl white" was actually a really nice color)... _________________ Wish List:
1967 Wesfalia SO-42 Parts Needed: Kitchenette, Cot Poles
'65 rear left beetle fender
15" Bus Wheels in fair condition
Mark Laken
Fort Collins, CO |
Posted: Mon Jul 07, 2008 7:01 pm Post subject: |
Thanks for the response. I believe that is the same color I'm getting. I don't need a perfect match because I'm painting the entire van but don't know if I would be happy with a yellow tint?? I'm buying my paint this week- still thinking of getting nason.
marklaken wrote: |
i thought it layed down better than the dupont centari pearl white that I used instead (and centari is a much closer but not perfect match)...TCP's paint seemed like high quality paint (my first time sopraying automotive paint)...I think it is a good deal for someone not looking to duplicate a factory color (the creamy yellow "pearl white" was actually a really nice color)... |
Superblue67 Samba Member
Joined: September 02, 2020 Posts: 1 Location: Indiana
Posted: Wed Sep 02, 2020 1:15 am Post subject: Re: Restoration Shop paint from Tcpglobal.com |
I am a DIY guy i have about 4 paint jobs under my belt that came out pretty good. But i just painted my 54 chevy w 1 stage eurathane paint restorations midnight blue pearl. Well beware!!! they sent me the paint no paperwork or warnings. Gallon had shaker clips so i assumed it had been shakin. So i thought a good stirr w a stick & i would be good 2 go. Well i had a little mishap on front fender so i stripped & repainted. Well now i am down to 1/3 of a gallon. & now i have a car that is two totally different colors. So not real happy!!! I am not a pro but i believe tcp global advertises serving the DIY painter it would be nice to see some warnings on paper come with the paint. |
ibjack Samba Member
Joined: February 06, 2002 Posts: 2105 Location: Imperial Beach CA
Posted: Thu Sep 10, 2020 7:38 pm Post subject: Re: Restoration Shop paint from Tcpglobal.com |
I’ve used both the acrylic enamel and acrylic urethane with good results. Their color matching is spot on. _________________ '68 Lotus White T34 automatic sunroof
'64 Manila Yellow T34
'65 Sea Blue Square Panel
the1500club.com
Shop Lacky at the T3/34 Factory, https://www.facebook.com/profile.php?id=100094313902074 |
2type2 Samba Member
Joined: June 02, 2002 Posts: 975 Location: SW Colorado
Posted: Sat Sep 12, 2020 4:05 am Post subject: Re: Restoration Shop paint from Tcpglobal.com |
My experience with TCP is with their HotRodFlatz line.Even if you have never painted, I would assure you that you could get a nice cheap flat job with it even if your pet monkey held the sprayer. If you're liking the look of flats, that is! _________________ "A life of peace and happiness depends on your own gratefulness" |
Braukuche Samba Member
Posted: Wed Sep 16, 2020 7:05 am Post subject: Re: Restoration Shop paint from Tcpglobal.com |
I use TCP single stage urethane. Stuff lays down nice and has excellent coverage. I use a little bit of their flow enhancer.
I had a customer who provided me with Omni single stage and it was like shooting water, thin, required multiple coats, total garbage.
TCP also has excellent color matching from my experience. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
67ctbug Samba Member
Posted: Fri Sep 18, 2020 3:11 pm Post subject: Re: Restoration Shop paint from Tcpglobal.com |
I’ve shot Omni, don’t add reducer. I reduced a gold metallic and it covered a spray out card in 4 coats. It is thin though. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Sat Sep 26, 2020 9:54 am Post subject: Re: Restoration Shop paint from Tcpglobal.com |
The TCP restoration shop line is great for the price. I really like the single stage urethane
I use SPI brand primers. Lots of people like them _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
71StandardReduction Samba Member
Joined: December 04, 2012 Posts: 715 Location: Louisiana
bomberbob Samba Member
Posted: Tue May 16, 2023 9:28 am Post subject: Re: Restoration Shop paint from Tcpglobal.com |
I have not used their single stage paint, so I cannot comment on that. I am in the process of spraying my 1990 VW Jetta with their two stage. I will include photos below. Notes on this job: TCP Global Bright Jalapeno Red, with their clear. I used a R500 gun off Amazon, with a small (8 gallon) compressor. Sprayed with garage door open, did not wet the floor, had a fan running, did nothing to try and reduce airborne dust/dirt or bugs. I sprayed 3 coats, 4th coat I added about 1/3 retarder to slow it down and let it flow. Sprayed all panels laying flat. I had considered using my Wagner Motocoat for this but decided to try out the R500 gun. I will have to do some wet sanding and buffing, oh well. I do not have access to a paint booth.
I had no problems with their paint, but I am not a pro.
Oh, these photos are of the inside of a rear door, which will be covered with a door card but I sprayed it anyway. I will flip it over and paint the outside next. Sprayed this door, two fenders, and two sunroofs.
_________________ 1968 Beetle (storage)
1990 Jetta GLI megasquirted, burning E85 (currently in heavy maintenance)
2004 Jetta turbo GLI
Marion, Iowa |
Posted: Tue May 16, 2023 8:10 pm Post subject: Re: Restoration Shop paint from Tcpglobal.com |
The gun I used is a LVLP (low volume low pressure). If you use another gun you will have to look at the CFM requirements for the gun.
- I laid my pieces out so I could move from piece to piece, stopping at several points along the way to move around and look at the reflection to make sure I did not miss any spots. This gave the small compressor I was using time to catch up. If I had the car assembled with fenders, doors, hood etc all on the car and I tried to paint the whole car in one shot, the compressor probably would not have been able to keep up. I was able to paint these piecemeal and make it work.
I thought instead of just telling you I didn't have problems with their paint, I would show you some results. Any issues with this paint job are my fault due to inadequate prep, filthy garage, etc. I have no complaints about the material. Compressor I used was a California Air Tools Ultra Quiet machine. _________________ 1968 Beetle (storage)
Marion, Iowa |
