kshbaja Samba Member
Joined: June 15, 2008 Posts: 476 Location: Portland, OR
Posted: Sat Jun 28, 2008 10:07 pm Post subject: starter won't crank, voltage looks good at starter/solenoid |
1986 Westy
I measured about 12.4 volts at the battery and the big lead into the starter. When the ignition switch is turned, I also see about the same voltage at the solenoid input. Is there anything else that could cause this or do these symptoms conclusively indicate the starter/solenoid? I haven't tried to tap the starter with a hammer yet, but before I get working on this tomorrow, I wanted to see if its feasible anything else could be related.
I just bought this van a couple weeks ago and have probably only started it 10 times, but it started just fine all those times. I drove it into my garage and that's where it has been since then. I have been going through everything in the engine so i have had a lot of things disconnected. I expected to have a problem or two after putting it back together, but I can't figure out what would cause this other than a failing starter? It all just seems too coincidental to be a failed starter.
Thanks,
K |
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4532 Location: Cedar Falls, Iowa
Posted: Sat Jun 28, 2008 11:27 pm Post subject: |
You're right, it does seem likely that you caused it. How about the ground straps, especially the big one at the nose of the transmission? These cars are old enough that any of the major or minor wires could corrode completely off by now. I'd do a complete visual exam of the wires and tug on them to make sure they are not falling off or just loose.
Al _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
dragonfire709 Samba Member
Joined: July 13, 2005 Posts: 154 Location: Hampshire, UK
Posted: Sun Jun 29, 2008 3:06 am Post subject: |
I have had this problem on and off for 2 years!! The wife has got fed up of bump starting it so yesterday i recrimped the end of the 'exciter' wire that goes to the starter. I am hoping that will cure it, and it only took 2 minutes. _________________ My name is Roy |
Posted: Sun Jun 29, 2008 7:07 am Post subject: |
I haven't checked the transmission ground strap. I did actually clean the ground connections running from the head over to the left side of the engine bay. I will also completely remove the ground strap from the battery. i used a wire brush on the terminal and the battery post, but maybe it warrants more attention. |
Posted: Sun Jun 29, 2008 9:07 am Post subject: |
further debugging:
1. took battery from westy and put it into another car of mine, started no problem. so the battery should be ok.
2. re-cleaned the battery connections and terminals. nothing.
3. removed ground strap from tranny to chassis, cleaned up both ends, reconnected. nothing.
4. per a samba suggestion, ran jumper cable from negative battery terminal to engine block near starter to rule out issue in ground circuit. nothing.
i just saw a post abut a crumbling ground strap on the starter, i will check this next.
is there ANYTHING else that could disable the starter? in the course of going through the engine i disconnected about every wire and its very possible i forget to reconnect something or put something back in the wrong place. |
Posted: Sun Jun 29, 2008 2:43 pm Post subject: |
ugh...so i pull the starter and go and get it tested. works fine. i think my next test will be to bypass the 12V circuit from that battery and see if the problem is there. i read 12v at the supply and solenoid with ignition on, but perhaps it can't carry the necessary current? |
Posted: Sun Jun 29, 2008 10:18 pm Post subject: |
Have you tried jumping from the big stud to the terminal where the wire pushes on? This is how you'd hook up a remote starter switch.
Vanagons:
Posted: Mon Jun 30, 2008 6:49 am Post subject: |
I finally tested the continuity of the lead from the battery to the starter and found some resistance. Cleaned up the terminal at the starter and the resistance went to 0, although i haven't tested it yet as the starter is out of the rig. The starter is really old, so I am thinking of proactively changing it. |
Posted: Mon Jun 30, 2008 3:02 pm Post subject: |
Solved. Just to close the loop on this one, after thoroughly cleaning up the terminals on the starter connections, it fired right up. What was interesting was that before I started my work on the engine, the starter was working fine. I saw the connectors looked a little dirty so i disassembled and wire brushed the connectors. Put it back together and it didn't work. It required me hitting the connectors with a dremel wire wheel to get them clean enough. Visually, it really wasn't apparent they had a problem. Perhaps some of the corrosion that was on the periphery of the terminal made its way into the contact surface when reconnected. Good lesson learned. |
floggingmolly Samba Member
Joined: April 06, 2007 Posts: 1106 Location: San Diego, CA
Posted: Mon Jun 30, 2008 3:27 pm Post subject: |
Thanks for posting what the problem was and the solution. Often for the time we spent solving the problem, people forget to post the solution, me included. Who knows, any one of us may need this thread in the future. the SOLUTION is the most important part! _________________ '85 Wolfsburg Weekender |
