Wasn't a Squareback fan until I saw this one!!
Critter1
Critter1 is offline
PostPosted: Sun Jun 29, 2008 10:01 am    Post subject: Wasn't a Squareback fan until I saw this one!! Reply with quote
I'm a huge fan of 70's Cal-Look. When I saw this one in July 08 Volks World, I instantly became a fan of the square. A 3.0 in a Type 3, THAT ROCKS!! The panel squares are so cool too! If your an old school Cal-Look fan, chime in on this perfect Type 3....
http://www.volksworld.com/news/cars/256628/russell-ritchie-s-show-winning-type-3-squareback.html
Justin
blankmange
Type 3 Darksider
blankmange is offline
PostPosted: Sun Jun 29, 2008 10:16 am    Post subject: Reply with quote
it does, but then you get all sorts of questions when you get to the engine bay:
póg mo thóin
Certified DHS Technician
Samba Member # 24517
btectonic
btectonic is offline
PostPosted: Sun Jun 29, 2008 10:51 am    Post subject: Reply with quote
Maybe he refrigerates it or something.
I think somebody should stretch a square one whole window and make a hearse. You could make swanky drapes out of og plaid bus curtain material. That would totally kick ass. It'd be like if Bobby Brady had a funeral home.
______________________
Brad in SF
People ask me, "Does your car have a name?" I ask them, "Does your dog have hubcaps?"
Tram
Samba Socialist
Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Tram is offline
PostPosted: Sun Jun 29, 2008 11:25 am    Post subject: Reply with quote
That's a Rednek Approved enhanced cooling system. Heat dissipates faster that way. All that pesky tin just holds the heat in. Thought you knew!
Bryan67 wrote:
To best contact me, please use the EMAIL function in my profile
abgwin
abgwin is offline
PostPosted: Sun Jun 29, 2008 1:14 pm    Post subject: Re: Wasn't a Squareback fan until I saw this one!! Reply with quote
perfect Type 3? why, that's far from perfect. This is the perfect type 3:
Critter1
Critter1 is offline
PostPosted: Sun Jun 29, 2008 1:30 pm    Post subject: Reply with quote
That is a nice T34 for sure! As far as the old school cal look goes, the square is perfect in my eyes. Although i'd have some cooling tin so I could drive more than a few miles...
Justin
vwfye
vwfye is offline
PostPosted: Sun Jun 29, 2008 1:47 pm    Post subject: Reply with quote
the 3 liter squareback is set up for racing. the guy that built has several over the top cars.
64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3"
RennyRB
Samba Textbook Gangsta
RennyRB is offline
PostPosted: Sun Jun 29, 2008 2:45 pm    Post subject: Reply with quote
He also owns a few over the top cars built by others...
1967 Squareback
btectonic
PostPosted: Sun Jun 29, 2008 3:22 pm    Post subject: Reply with quote
Oh of course! The motor never gets hot when you're racing.
Brad in SF
vwfye
vwfye is offline
PostPosted: Sun Jun 29, 2008 4:14 pm    Post subject: Reply with quote
have you ever seen a drag engine? most of the dedicated cars don't run any tin at all. they make passes, go back to the pits and use box fan to blow air over th engine to cool it off, then go race again. with the high amp ignition systems, most are finally coming around to running a nippondenso alternator and no fan to keep the system firing the entire time it is lit off.
KTPhil Premium Member
KTPhil is offline
PostPosted: Sun Jun 29, 2008 4:32 pm    Post subject: Reply with quote
Do drag cars usually sport stock external rear view mirrors? Kinda a "drag" aren't they?
vwfye
vwfye is offline
PostPosted: Sun Jun 29, 2008 4:47 pm    Post subject: Reply with quote
some do to keep the appearance of a street car.
RareAir
RareAir is offline
PostPosted: Sun Jun 29, 2008 8:11 pm    Post subject: Reply with quote
Take a close look at cylinders on that car, there's only a pair (one on each side of the engine case)
With that engine configuration (Type 1) the floor was raised more than a few inches too
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sun Jun 29, 2008 9:42 pm    Post subject: Reply with quote
A gal named Mica used to have a black square that was done up like a hearse.
Gary: OK. Ima poop.
notchboy
notchboy is offline
PostPosted: Sun Jun 29, 2008 9:47 pm    Post subject: Reply with quote
You have to read the article on that motor. I think it was designed by a guy that worked for Deno Dinosaur racing. The case has a raised deck to accommodate a bigger stroke. 70s racing stuff. If I had the mag in front of me I could tell. Anyway its a cool resto rad rod panel deal. Cool
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
EvKev
Samba Tea Specialist
EvKev is offline
PostPosted: Sun Jun 29, 2008 10:52 pm    Post subject: Re: Wasn't a Squareback fan until I saw this one!! Reply with quote
Bleck. I feel like my eyeballs have been raped.
Power steering is for wankers.
Critter1
Critter1 is offline
PostPosted: Mon Jun 30, 2008 5:03 am    Post subject: Reply with quote
I believe those are called "siamese" barrels. The pistons are so big that there wouldn't be enough space left between them to make them individual barrels. Cool stuff!
Justin
Buttafuoco
Buttafuoco is offline
PostPosted: Mon Jun 30, 2008 6:12 am    Post subject: Reply with quote
Has anyone seen a newer 911 turbo motor in a Ghia yet?
notchback
Insensitive Jerk
notchback is offline
PostPosted: Mon Jun 30, 2008 6:29 am    Post subject: Re: Wasn't a Squareback fan until I saw this one!! Reply with quote
How sad. An original panel. At least is looks like it can be undone.
zeen wrote:
Arguing with johnnypan is like mud-wrestling a pig. After a while you realize he just enjoys playing in the mud, winning the contest is not the point.
FU#3
Critter1
Critter1 is offline
PostPosted: Mon Jun 30, 2008 8:19 am    Post subject: Reply with quote
What?!?!
Justin
