jroymcd Samba Member
Joined: April 18, 2005 Posts: 1053 Location: Bay Area
Posted: Wed Jul 02, 2008 9:34 am Post subject: bowden tube shims? |
Anybody know what size the washers are? need to shim my bowden tube. Im getting a nasty shutter in 1st. The the bowden tube has very little bend in it.
need to know the inner and outter diameter size . how thick should I make them?
got a laser here at work so I want to burn a few today.
its a stock 57 oval if that makes any differance.
thanks _________________ www.cultwagen.com |
clarkbre Samba Member
Joined: June 20, 2004 Posts: 1107 Location: Everett, WA
Posted: Wed Jul 02, 2008 9:37 am Post subject: |
I want to say it's a 1/2 inch hole that is needed. I used stacked washers and they worked great. |
akokarski Samba Member
Posted: Wed Jul 02, 2008 1:00 pm Post subject: |
1/2 inch sounds about right. Just measure diameter of the metal rear end of the bowden tube.
Any hardware store would have em. While you are in there check the nuts and front tranny mount. On mine nuts kept digging into the mount and backing out. A pair of flat and locking washers fixed it.
Anton |
Posted: Wed Jul 02, 2008 1:02 pm Post subject: |
akokarski wrote: |
I would but, im at work and the car is home. wanted to fix it tonite _________________ www.cultwagen.com |
Posted: Wed Jul 02, 2008 1:08 pm Post subject: |
well, get a couple of 1/2 inch and a couple of smaller and bigger. they are only like $0.10 or something.
Anton |
2002sportside Samba Member
Joined: January 27, 2004 Posts: 1489 Location: New England
Posted: Wed Jul 02, 2008 1:31 pm Post subject: |
1/2 inch washers are what you need. IIRC the proper spacer would be 12mm, but that is .47" so... _________________ 1973 Volkswagen Beetle never ending project |
Posted: Wed Jul 02, 2008 3:32 pm Post subject: |
2002sportside wrote: |
1/2 inch washers are what you need. IIRC the proper spacer would be 12mm, but that is .47" so... |
so the hole is .47 correct? or the outside fo the washer? _________________ www.cultwagen.com |
Posted: Wed Jul 02, 2008 4:04 pm Post subject: |
0.47 should be the opening in the washer.
Anton |
rterfert Samba Member
Joined: October 08, 2003 Posts: 1419 Location: Yuma Arizona
Posted: Wed Jul 02, 2008 6:22 pm Post subject: |
1/2 inch ID washer and cut a slot in the side big enough to slide over the clutch cable....Saves you the time to reinstalling the cable and more if it were to come unhooked from pedals up front. |
pdub Samba Member
Posted: Wed Jul 02, 2008 9:42 pm Post subject: |
VW head washers fit nicely. |
