rjonas Samba Member
Joined: July 24, 2004 Posts: 644 Location: Chandler, AZ
Posted: Thu Jul 03, 2008 12:20 pm Post subject: |
I have just broken the westy only interior slider handle so far but it's only been on the road since mid May '08. Almost have 1000 miles since resurrection.
That part is not reproed yet as I understand _________________ 1979 Type-2 Westfalia “Sandy”
1973 Type-181 Thing "Velma"
1956 Type-1 Beetle Patina Project “Rosie”
www.azbusclub.org |
Redd73 Samba Member
Posted: Thu Jul 03, 2008 12:26 pm Post subject: |
- The seal on the small vent window in the rear drivers side of mine is broken. I sealed it with some temp stuff until I can redo the whole thing.
- The rear seal on my hatch broke. Its been replaced.
- The sliding door seal is not leaking but im not sure how. It has more cracks than the polar ice sheet. It will be replaced soon.
- The fuel pump was broken when I got her. I replaced it with the wrong kind but will be changing that (which leads us to the next one
- My pass side carb broke and im pretty sure it was due to a surge in pressure from the fuel pump and the seal on the carb also failed.
- The inside sliding door handle broke. _________________ "...theres nowhere to go but everywhere." - Kerouac
73 Westy 2000cc w/dual solex (engine code GE) + aftermarket AC |
Tri-Bus Samba Member
Joined: November 29, 2005 Posts: 732 Location: Butler PA
Posted: Thu Jul 03, 2008 12:59 pm Post subject: |
Any part that says "Empi" on it
Annoying hard to find parts like westy door handles |
calebmelvin Samba Member
Joined: July 19, 2006 Posts: 3140 Location: Seattle, WA
josh Samba Member
Joined: July 13, 2003 Posts: 1773 Location: laid back in the tall grass
Posted: Thu Jul 03, 2008 3:27 pm Post subject: |
I don't think I've ever bought a bus that had the stock windshield washer working. I've fixed them but they initially always seem to be broken. _________________
modok wrote: |
...If If stoner A takes a hit and then stoner B goes right away(not waiting two seconds), he's trying to suck on it while it's still got a vaccum, doesen't get much of a hit at all! Cause it hasn't filled back up all the way yet.
Stoner A is cylinders #2/4 B is #1/3 The plugged bowl is the throttle, the bong is the manifold |
theizzardking Samba Member
Posted: Thu Jul 03, 2008 4:38 pm Post subject: |
josh wrote: |
I don't think I've ever bought a bus that had the stock windshield washer working. I've fixed them but they initially always seem to be broken. |
hahah that seems to be very true, are you sure you haven`t broken more with that pic of your bus looking like a turtle on it`s back..... |
Posted: Thu Jul 03, 2008 5:29 pm Post subject: |
josh wrote: |
Bays have a windshield washer???? I always thought that was something for washing your pants leg or something. |
vdubyah73 Samba Member
Joined: July 05, 2003 Posts: 2541 Location: somewhere in Texas, my house has wheels
Posted: Fri Jul 04, 2008 5:21 am Post subject: |
FUEL LINES. read the sticky. _________________ burning down the house
73 bounty hunter, sold.
'77 transporter, junked had crotch rot.
Dubless, but have a CPR built stroker waiting for a new to me Beetle
'93 Fleetwood Bounder 34' |
1977_L63H_P27 Samba Member
Joined: January 17, 2006 Posts: 2345 Location: Bristol, Tennessee
Posted: Fri Jul 04, 2008 5:59 am Post subject: |
It's the sun visor clips!! Peace! _________________
busdaddy wrote: |
...and try a few chubby ones until you find one you like.
1977 Westfalia P27
you can't spell Volkswagen without SWAG
M-code Plate
Full Moon Bus Club |
tinyacres Samba Member
Posted: Fri Jul 04, 2008 11:41 am Post subject: |
Seat Belt Hangers, often break, made of plastic. _________________ Peter
1978 VW Westfalia P 27
1975 VW 7 Pass Station Wagon, Original Owner
2006 Volvo XC90, Original Owner
2001 Mercedes E 320, Original Owner
1992 Honda Accord, Original Owner
1975 Suzuki T 500, Original Owner |
TRN9 Samba Member
Joined: September 29, 2006 Posts: 309 Location: Where its rainy
Posted: Fri Jul 04, 2008 11:42 am Post subject: |
The engine if it has a GEX Sticker on it! |
GeorgeL Samba Member
Posted: Fri Jul 04, 2008 11:51 am Post subject: |
Door pulls. The plastic ends crack and screws work loose.
Those annoying little springs in the door latch mechanism that allow you to close the locked door by pulling the trigger. Not a problem in themselves, but if you don't replace them you end up breaking the lock cylinder.
Clutch and throttle cables. |
ccpalmer Samba Member
Joined: September 17, 2006 Posts: 3850 Location: Ann Arbor, Michigan
Posted: Sat Jul 05, 2008 2:24 pm Post subject: |
GeorgeL wrote: |
Yea - I just had to replace those the other day!
My replacement window cranks keep breaking - I even tried the Vanagon versions. And my visor clips too.
My only broken items while driving - accel. cable, coil, valve, and of course steering pivot. (luckily I was only going 5mph. Too much fun in the Rocky Mountain back roads!) _________________ '71 Westy |
Karl Samba Member
Joined: January 29, 2001 Posts: 6170 Location: Coos Bay, Oregon
Hippie Samba Tinner
Joined: August 16, 2004 Posts: 1781 Location: Iowa: The Mud State
Posted: Sat Jul 05, 2008 6:53 pm Post subject: |
Valves
Oil leaks
Brakes
Electrical
Rust
Rings and bearings
Transmission |
Posted: Sun Jul 06, 2008 11:50 am Post subject: |
On early bays, steering boxes and transmissions. |
twinfalls Samba Member
Joined: November 21, 2003 Posts: 2133 Location: France
Posted: Sun Jul 06, 2008 12:33 pm Post subject: |
I had:
_Clutch cable.
Broke on a German highway ( repaired on the emergency lane with trucks full speed near my feet ).
_Parking brake cable.
Broke while lauching a boat in Northern Manitoba.
_Heating ducts, bellows flaps and their control cables under the bus, eaten by rust.
_CV joints ( just asking for grease repacking ).
_Breaker points ( just reminding me, it doesn't last forever ).
_Foam seal around the engine ( lack of it, is overheating engine in the summer, mostly when stuck in traffic jams ).
_Front brake calipers. Stuck solid with rust, from bus storage too long under a leaky roof. _________________ Stock 1974 US Westy, AW-A 1800cc dual carbs. Twin Falls is my favorite site on the Churchill river in Manitoba. |
Napoleon Resurrected Samba Member
Posted: Sun Jul 06, 2008 5:33 pm Post subject: |
The brake fluid resevoir. @#%*ing thing crumbled today as I was trying to bleed the brakes. Any idea where I can find ANY resevoir that will work? I will exchange with an original at a later date but for now, I would just like to take the bus and its new engine out for a test drive. ( I know, use the search feature. Been doing that for about an hour now and still reading)
thanks
Tim
1970 westy |
Karl Samba Member
Posted: Sun Jul 06, 2008 5:59 pm Post subject: |
Napoleon Resurrected wrote: |
thanks
Tim
1970 westy |
Find the square one behind the seat of 71-73 buses. MUCH better material.
I found 45 posts on reservoirs in about 5 seconds. Keyword: reservoir
and for Author, put in karl |
