udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Mon Jul 07, 2008 1:55 am Post subject: . |
Seat belt hangers (plastic) |
twinfalls Samba Member
Joined: November 21, 2003 Posts: 2133 Location: France
Posted: Mon Jul 07, 2008 9:32 am Post subject: Re: . |
udidwht wrote: |
Indeed,
This plastic is so bad; One I had replaced did not last much.
A next project is to improve them with steel backing. _________________ Stock 1974 US Westy, AW-A 1800cc dual carbs. Twin Falls is my favorite site on the Churchill river in Manitoba. |
GeorgeL Samba Member
Posted: Mon Jul 07, 2008 9:37 am Post subject: Re: . |
twinfalls wrote: |
udidwht wrote: |
Indeed,
A next project is to improve them with steel backing. |
The originals are decades old. The repros don't have any UV inhibitors in the plastic so the light kills them quickly.
I had the same problem with my Hagus mirrors. The metal body and mirror glass are fine, but the plastic that connects them together was killed by the sun and the glass fell out. I put it back with double-stick foam tape and filled the gap with hot-melt glue. Not perfect, but at least the glass doesn't fall out. |
lostsailr Samba Member
Joined: August 05, 2004 Posts: 126 Location: Burnt Hills, NY
Posted: Mon Jul 07, 2008 12:18 pm Post subject: |
I agree with the seatbelt holders. I have one replaced with a metal piece which should outlast the bus. Also the plastic cabinet drawer pulls/latches. Someone always pulls harder rather than pushing the button and then rips the things right off the screws holding them on. All else seems to wear out rather than break. _________________ The Bus came by and I got on, that's where it all began! |
kirklarson Samba Member
Posted: Mon Aug 25, 2008 5:38 pm Post subject: |
Clutch cables, Clutch cables, Clutch cables,Clutch cables,Clutch cables, and muffler. I finally figured out that my clutch cable tube was bent and was hanging up the cable and causing the problem. So check your clutch cable tube for kinks and such. And lot of lube on it as well as you clevis pin. |
static Samba Member
Joined: March 22, 2002 Posts: 1831 Location: The High Desert
Posted: Mon Aug 25, 2008 6:00 pm Post subject: |
kirklarson wrote: |
Please don't call me a clevis pin. It hurts my feelings. |
larryulm Samba Member
Posted: Mon Aug 25, 2008 7:14 pm Post subject: |
once I broke the pulley on the generator on a 1600 going uphill in a split bus. The belt was too small, too tight, and the pulley split and looked like pac man....some crazy stuff right there, Happened in Morgantown West Virginia if anyone would care. |
calebmelvin Samba Member
Joined: July 19, 2006 Posts: 3140 Location: Seattle, WA
dweller Samba Member
Joined: May 31, 2007 Posts: 819 Location: Chapel Hill, NC
Posted: Mon Aug 25, 2008 7:34 pm Post subject: |
the #|~% plastic piece on the end of the solenoid you hook the hot wires to will snap off if you're not careful!
eh, remembering when you could just buy another solenoid and replace it.
dp _________________ 77 Westie 2.0L FI ... slowly restoring bit by bit... |
elstrom Samba Member
Joined: February 02, 2006 Posts: 395 Location: Seattle
Posted: Mon Feb 16, 2009 12:47 pm Post subject: |
I can't believe no one has mentioned the fuel gauge. Those things never seem to work. Maybe it's just a late bus thing, though. _________________ '78 Landmark Conversion/Westy "Buster" |
Runamuck Bus Samba Member
Joined: July 01, 2007 Posts: 197 Location: Western PA
Posted: Mon Feb 16, 2009 12:52 pm Post subject: |
bank account _________________ Endeavor to persevere.
'72 Westy "Weekender" |
bigzack Samba Member
Joined: January 20, 2008 Posts: 26 Location: Ephrata, WA
Posted: Mon Feb 16, 2009 1:34 pm Post subject: |
Windshield. Who would guess that birds can't get out of the way of a brick travelling at the speed of smell. _________________ 1972 ASI Riviera (Big Blue)
1967 Beetle |
Blaubus Samba Member
Posted: Mon Feb 16, 2009 2:04 pm Post subject: |
if you are looking at an old bus, suspect the following:
ball joints
transmission
booster
steering box
signals
rotor and drum thicknesses
hydraulics
the entire engine
battery
as far as common on-the-road failures i have suffered in order of frequency:
more than once:
lighting
cables
fuel pump
generator
flat tire
fan belt
frozen gas line
starter
only once:
broken gen. pulley
points
cutoff jet wiring
plug blew out of head
release bearing blew up, ate the cross shaft and plate
fuel filter obstruction
needle valve obstruction |
theizzardking Samba Member
Posted: Mon Feb 16, 2009 3:25 pm Post subject: |
dansvans wrote: |
ball joints
transmission
booster
steering box
signals
hydraulics
the entire engine
battery
more than once:
lighting
cables
fuel pump
generator
flat tire
fan belt
frozen gas line
starter
only once:
broken gen. pulley
points
cutoff jet wiring
dude sweet post this is the sort of info i was looking for when i originally posted this thread, i was trying to priortize the items i checked and come up with a decent parts list, thanks again,
so far i've only had, accel cable x2,e brake cable x1 ,door handles all of them, interior door handles,lighting,drivers side window reg., and that's it so far. thanks again guys! _________________ "Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin
'71 westie "the wanderer" |
towd Samba Member
Posted: Mon Feb 16, 2009 5:26 pm Post subject: |
I was trying to narrow this down, with what doesn't break ?
The two rivets holding the ID tag to the dash, They have to be drilled out |
keumnam Samba Member
Joined: June 11, 2006 Posts: 53 Location: boise, Idaho
Posted: Mon Feb 16, 2009 6:12 pm Post subject: busted stuff |
clutch cable, throttle cable, pilot bearing. All that has gone wrong in the 4 years I've owned my 71 westy except for the brake servo. _________________ 1971 Westy stock, 2006 Corolla stock, 1969 transporter waiting for engine install
I read somewhere that 77 per cent of all the mentally ill live in poverty. Actually, I'm more intrigued by the 23 per cent who are apparently doing quite well for themselves. ~ Jerry Garcia |
Posted: Mon Feb 16, 2009 8:10 pm Post subject: |
dansvans wrote: |
more than once:
lighting
cables
fuel pump
generator
flat tire
fan belt
frozen gas line
starter
only once:
broken gen. pulley
points
cutoff jet wiring
this is the one that i had to pay big for. i was in Atlanta when it blew, and i had to drive all the way back to NY without a clutch. (Atlanta seems to have no foreign part stores) figured it might not go too bad till i got to the traffic jam- on the interstate! WTF? i just went around everyone, leaving the road surface, pissin everyone off for cheatin.
now, i wont drive more than 100 miles out of town with out the plate, shaft and bearing. release bearings are not reliable- no warning!
i would also recommend you carry an OG ignition switch, coil, cutoff jet, headlight switch, and flasher relay. |
enjoispammy8 Samba Member
Joined: December 26, 2007 Posts: 1984 Location: Long Beach, CA
Posted: Mon Feb 16, 2009 8:47 pm Post subject: |
battery cables on the freeway _________________ 1969 Westy, 1690cc. montana red and cloud white.
1969 Standard Beetle [sold]
Watch My Movies: https://www.youtube.com/user/taylorlikesacdc
Desertbusman wrote: |
Is there a message here? Enjoy Spammy Ate |
EZ Gruv wrote: |
Way to fuck up some little kids riding in the car next to you. |
hazetguy wrote: |
you need to be doing better drugs. |
Vamstad Samba Member
Joined: September 19, 2007 Posts: 223 Location: So Cal
Posted: Tue Feb 17, 2009 12:40 pm Post subject: |
Seat belt hanger clips - always carry an extra for passenger side - my friends have no idea how this system works and just pull the belt.
Clutch cable
Vacuum lines - carry a bit of all sizes (look at ratwell's website for sizes) they crack easily and make the bus run like shite
Horn - wiring sucks and is prone to break
Fuel lines - don't last long - get the good ones _________________ Fear is the mind killer.
1979 Federal Westfalia
2.0 FI |
i_am_cool_fred Samba Member
Joined: June 26, 2004 Posts: 1743 Location: Benton, AR
Posted: Tue Feb 17, 2009 2:06 pm Post subject: |
in my 4 years the throttle cable has broke, the fitting on the carb broke off causing a small fire, ummmmmmmmmmmmmmmm, that's really it.
oh, my transmission lost 4th gear coming back home on a 250 mile trip i was about 150 from the house and just held it in gear...scared the crap out of me everytime i forgot and took my hand off the stick
that's all i've had problems with and i'm rough on my bus too _________________ proud owner of a defunct 1979 sunroof kombi
Brian Denning, as seen on Gearz TV |
