WendyArmbuster Samba Member
Joined: March 03, 2006 Posts: 330 Location: Springfield, MO
Posted: Fri Jul 11, 2008 10:00 am Post subject: |
Karl,
I don't know what's wrong with mine. It holds the rubber stopper up, but the rubber stopper becomes a fulcrum on which the seat pivots. There doesn't seem to be any ratcheting action. Some guy in a 4WD Dodge pickup slid through an icy intersection a few years back and hit me in the side, right behind the sliding door and crushed the wood with the hatch and electrical box in it, so I rebuilt that section. Maybe I left out the part that ratchets?
Brian Z |
JLT Samba Member
Joined: September 23, 2008 Posts: 162 Location: Sacramento CA
Posted: Sat Nov 08, 2008 10:37 pm Post subject: Comment on the lantern hanger, and a tip |
Wildthings wrote: |
Not wanting to burst anyone bubble, but that bracket for the lantern looks way to flimsy to me, especially if someone where to smack it as they passed. The plastic extending over the lantern isn't so cool either, as gas lanterns get damn hot. Buy a battery operated light if you want to use it or stick with just using it for the flag, we don't want to see a thread about your bus burning. |
Believe it or not, it's plenty strong. As for heat, it may have problems with a propane lantern turned up to "way high" but for normal illumination and for kerosene (paraffin to Brits) lamps, it's fine. In fact, any lamp you can comfortably hold by the handle shouldn't heat up the plastic unduly.
Here's my own contribution to this thread. I've been using kerosene lanterns for a long time, and have been filling them with this little filler from the Coleman company:
It's screwed onto the spout of a Coleman fuel can and is used to fill gasoline stoves. Its advantage over a plain old funnel is that it automatically cuts off when the tank is full. I discovered that it also fits onto the top of many oil-lamp bottles:
While I buy kerosene by the gallon, I find it easier to pack a quart at a time, so I re-fill the lamp-oil bottle as needed. I also modified a filler so it works better with kerosene lanterns. This involves shortening the filler pipe and attaching a washer to the neck if necessary (for instance, if the filling orifice on the lamp is unusually wide):
It makes filling the lamps a lot easier, especially in the dark. _________________ -- JLT
Present bus: '71 Dormobile Westie
with an Allstate single-wheel trailer
Past buses: '61 17-window
'70 Frankenwestie
'71 Frankenwestie |
1303 sb Samba Member
Joined: November 11, 2004 Posts: 145 Location: Nevada
Posted: Sun Nov 09, 2008 1:10 am Post subject: |
The lantern idea is sweet...I guess you could say it was a bright idea _________________ 1961 Beetle.
1972 Westfalia.
1973 Superbeetle. |
static Samba Member
Joined: March 22, 2002 Posts: 1831 Location: The High Desert
Posted: Sun Nov 09, 2008 1:18 pm Post subject: Re: Bus Gadgets, here's two |
I made a couple of the PVC lantern hangers and have been using them.
They are so simple, so ingenious, so useful. Thanks for posting that!
Opossum wrote: |
I like all the gadgets and accessories for the bus. Here are a couple, I made this week, to make camping a little easier:
This hanger is also good to dry out towels and is easy to make.
Two sprinkler parts:
Just cut a couple notches and screw together.
"Stay Air-Cooled my friends" |
panicalum Samba Member
Joined: May 06, 2008 Posts: 244 Location: Roseville, CA
Posted: Sun Nov 09, 2008 4:17 pm Post subject: |
If static approves, then it is good. As strange and interesting as it sounds, he collects lanterns from all over the world. I would have to say that he is the lantern authority on the samba. Which automatically makes him the lantern holder authority. _________________ '63 Bug
gone:
69 Riviera - non walk thru-Turd
1971 Type 3 squareback
1974 Orange Westy -William
1970 Deluxe Sunroof - Tinkerbell
1973 Westy - Didn't stick around long
1976 Sage Green Westy
1959 Single Cab
1982 Vanagon Westy
1974 Thing
1962 Bug
1974 Baja Bug
1973 Blue/White Thing
1978 Sage green Westy (Mom and Dad's) got me hooked |
dweller Samba Member
Joined: May 31, 2007 Posts: 819 Location: Chapel Hill, NC
Posted: Sun Nov 09, 2008 5:07 pm Post subject: |
sortof off topic: but this weekend i traveled to a family reunion ~400m roundtrip. And at the end of it, we decided for a group photo or two. Someone picked a spot in front of a historic building on the porch, everyone agreed. One problem, too many cars parked where the camera person would have to shoot from, so cars were moved. I was the last vehicle in line, but didn't feel like moving the bus as it wasn't in the view.
Next problem, no tripod, and someone would have to be left out of the group to take the pic.
I eyed the bus poptop, and told my brother to set his camera on the sloped top, set on timer and a few folks got into place. Test shot was perfect. It was just one of those moments where the height, slope and distance were all synched.
Next thing i knew, 6 or more cameras were lined up on the bustop, and everyone was posed and dozens of pics were taken of 2 dozen family members all smiling at my bus
point of the story: it's an expensive tripod, but pretty handy as a gadget in a pinch.
dp _________________ 77 Westie 2.0L FI ... slowly restoring bit by bit... |
MalibuLX3 Samba Member
Joined: October 02, 2005 Posts: 821 Location: Rochester, MI
Posted: Sun Nov 09, 2008 5:18 pm Post subject: |
whip618 wrote: |
Here is a set of homemade awning brackets that use regular tent poles, the brackets slide into the jack points and when the awning is taunt enough just snug down the cap screws. It isn't a huge awning but it does the job and is easy to set up.
Phil |
Pictures of of awning??? _________________ 1978 Westfalia |
Olde Volks Place Samba Member
Joined: February 03, 2005 Posts: 335 Location: McDonough, Georgia
Posted: Sun Nov 09, 2008 5:54 pm Post subject: |
We all say it is 12" in length |
Posted: Sun Nov 09, 2008 6:11 pm Post subject: |
The outside the bus table bracket is a good one to add and I have one .
And the tiki bracket is another and I will have to get them , also a front mount reciever bracket is another GREAT idea and I have one of them as well.
Type in rain fly on the home page here and see what Jonce Fancher has to offer as far as add ons go for the bus you will love it.
I have the long fly and a matching window block with screens and it is top quality workmanship. |
fastmc25 Samba Member
Joined: January 01, 2004 Posts: 1202 Location: East Tennessee
Posted: Thu Mar 25, 2010 3:37 pm Post subject: |
I built mine today......... it has some slight variations but works great.... I'll be using them this weekend....
_________________ Peace,
Paul
1973 Type181 Kubelwagen (Thing 2 ) 2110cc
1971 Transporter (Pickle) 1914cc
1961 Deluxe Beetle (Christine) 1776cc
1973 Adventurewagen Baja Bus (Clyde) 3.4L
1970 Formula Vee Beetle 2276cc
I identify as: “A Pissed Old GI ” |
skid Samba Member
Joined: January 16, 2009 Posts: 1329 Location: Vancouver, BC
Posted: Thu Mar 25, 2010 4:37 pm Post subject: |
fastmc25 wrote: |
I love this idea, I've been wanting to make something like that to hold dripping wetsuits. _________________ '71 Westfalia |
payaso de la mar Samba Member
Joined: January 21, 2010 Posts: 87 Location: Chihuahuan desert
Posted: Thu Mar 25, 2010 5:13 pm Post subject: |
i swoon at the brilliance of some of the ideas i see on here......!!! y'all are a hell of a resource.
Phil, i'd also love to see more pix of your lower awning attachment brackets, esp in action.
i haven't gotten there yet. but i'm planning on welding up an "L" shaped bracket that fits into my jack points to carry our folded portabote low along the side. Portabote makes something similar for larger RVs but i wanna be ale to take my 'bote where the bus can go, and not have to drag it off the top to pop it (to pop the bote or the Westy). _________________ '79 Westy |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Tue Mar 30, 2010 2:41 pm Post subject: idle stick |
idle stick made from plumber's helper handle and crutch tip
for winter warm ups and locking the other door
notched end for unlocking the door
Aloha
tp[/img] |
Krautski Samba Member
Posted: Tue Mar 30, 2010 5:22 pm Post subject: |
rear bumper mounted hammock stand, pictures will follow. _________________ BUS FOR SALE
Quote: |
I stopped reading after volksaru and busaru |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22450 Location: Escondido CA
chabanais Samba Member
Posted: Tue Mar 30, 2010 5:56 pm Post subject: |
Nice but I'd be afraid of bending the gutters. _________________ "I spud therefore I yam." |
Posted: Tue Mar 30, 2010 6:01 pm Post subject: |
Maybe I still wouldn't risk it.
notchboy wrote: |
chabanais wrote: |
Nice but I'd be afraid of bending the gutters. |
Not with PVC. It would give before the metal. |
static Samba Member
Posted: Tue Mar 30, 2010 6:36 pm Post subject: |
When you come to the next VW Camper Family gathering, you will see that most of us are now using the PVC lantern hanger thingies.
Our gutters are doing fine, though our minds are often in the gutter.
http://www.vwcamperfamily.com |
Posted: Tue Mar 30, 2010 6:38 pm Post subject: |
They won't bend or damage the gutters at all.. .... they worked great this past weekend....they had oil lamps on them for 2 days... no problems at all... _________________ Peace,
Paul
