Corn1849 Samba Member
Joined: December 04, 2006 Posts: 116 Location: Wood River Valley, Idaho
Posted: Sat Jul 12, 2008 10:05 pm Post subject: Sliding Door-Interior Panel Question |
The P.O. of my '89 Westy used a bit of "the handyman's secret weapon" (read:duct tape) to keep the sliding door panel from catching the edge of the opening when sliding the door open (the panel clip was missing at the interior right edge, around the mid-point).
I ordered a couple of the "hidden head" door panel clips, but realized after removing the panel.... that the hole in the door was not a match for this clip. The existing panel hole goes clear thru the vinyl finish, not like the holes for the hidden head clips, which only go thru the masonite backing. The hole thru the metal was different too.
I recall that my '84 westy had a handle close to this location (you'd use it to pull the rear latch of the door shut.
MY QUESTION: Does a '89 have a handle, or is it some other type of panel clip? A Photo, please.
Thanks _________________ Now: '89 Westy
Then: '99 EVC
Before then: '84 Westy
Way before then: '64 Bus |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4098 Location: East Kootenay, British Columbia
Posted: Sun Jul 13, 2008 2:13 pm Post subject: |
I believe you are referring to the screw located just below the catch on the rear end of inner panel. On both my 90's there is a screw with a finish washer that extends clear through panel and into sheet metal. I guess the Germans put a through screw here so as to get a tighter grip. One of mine panels is shredded along that edge from PO not replacing that screw after removing the panel for X reason. Dumb A**! Lots of vinyl repair gloop now! _________________ Currently:
Posted: Sun Jul 13, 2008 9:59 pm Post subject: |
Thanks for the reply.... I just looked in the Bentley Manual (why didn't I do that first ) It shows the screw, a washer and a cap. _________________ Now: '89 Westy
Then: '99 EVC
